Question about GE Refrigerators
Making ice very slowly - GE Refrigerators
  • GE Master
  • 5,323 Answers
Would check for faulty water inlet valve
Posted on Apr 22, 2015
Making ice slowly even after filter change
Hi there
It sounds to me that the fridge is "too loaded" and may be "working too hard". Try to lighten the load and put the power up one hack.
kolbrun
Jul 03, 2012 | LG LFC25760 French Door Refrigerator
Ice maker producing slowly
if your ice maker is making ice slowly there really is nothing you can do.but if you think its a real promblem go to homedepo/loes and aask im sure they have an answer/solution.
Jun 21, 2012 | Magic Chef CTF1925 Top Freezer...
My ice maker is making ice but very slowly. I have checked the water line to make sure water is flowing and that the line at the ice maker is not blocked in any way. Could it be a faulty selenoid switch?
for how long very slowly?in every 2 hour the water become ice but the ice produce in your ice maker is maximum of 15 pcs small cubes,its means depend on the tray if is big or small. if you use your ice in every 30minute or your family is using an ice by 1bottle its means the ice produce is not enougth for your family.and the tray becomes empty after you use at the same time. but if the unit is hard to make an ice or frozen your frezer side its the unit is have a problem but is not to easy to repair by if your self coz the part inside is hard to remove.
Dec 17, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice cube maker makes ice cubes ever once and a while, the condenser fan turns slowly. is this why it doesn't make ice cubes and the frezzer side is not cold enough? condenser fan going out? monogram...
Good day,
The ice maker speed of production is determined by the freezer temperature. If the freezer temperature is warmer than normal then the cycle thermostat in the ice maker will take longer to reset for the next harvest, causing low ice production.
More important, the condenser fan motor running too slowly can cause the compressor to run overheated and cause serious and expensive damage.
If in your opinion, it is running too slow, the issue should be addressed as soon as possible.
Aug 05, 2010 | GE Monogram ZISS480DRSS Stainless Steel
Ice maker makes ice really slowly
perhaps there is not enough water being brought to the ice maker from the inlet valve. you may have to change the valve.
Oct 24, 2009 | GE GTS22 21.8 Cu. Ft. Top-Freezer...
IT WAS VERY SLOWLY DISPENSING ICE MADE SOUND LIKE IT WAS BOGGED D
The ice maker has a builtin heater in the mold that heats up prior to the ice dumping. If the heater is defective your symtoms sound correct.I would suggest replacing rather than repair
Sep 29, 2009 | Refrigerators
Ice maker is making ice too slowly
Dirty condenser. Clean under the ice box.
IM manual and other stuff
Aug 30, 2009 | Refrigerators
Won't make ice
Have you changed your water filter lately. On many side by sides there are built in water filters that will slowly stop making ice and giving water because the filter is in need of changing...if this is not the problem write back and I will walk you through the other possibilities...
May 18, 2009 | Electrolux Refrigerators
Makes ice very slowly to none...
You need to turn the freezer side to a cole=der setting to allow ice to freeze faster.
Mar 12, 2009 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
