Question about PowerPro Power Pro C636 00-07 Audi Air Pump 06a959253b 06a959253a 06a959253e A4 A6 A8 Q7 Tt Quattro 00 01 02 03 04 05 06 07
Wont start . Before it didnt start when hot. Now dont start at all
  • Brad Brown Apr 18, 2015
    Hi Jerome Delaney, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what is this on?
Wont start after running for a while. service lights work, radio, headlights but wont crank. just replaced starter, got new battery about a month ago. after 5-8 hours car starts with no problems.
Hot does make a difference. You say it won't start, but does it crank and not start, or not even crank? If cranks but will not start, any electrical part may fail as it heats, and when you shut it off the engine gets much hotter since coolant is no longer circulating. Thus, a marginal crank or cam sensor, or coil/ignition module may work while cold of while engine is running, but fail when you first turn car off.
Jul 08, 2015 | 2008 Saturn Aura
Hot Starting Problem
hard starting problems when engine hot could be restricted air filter.restricted clogged fuel injectors.engine could either be diesel or gasoline.if engine dont start and starter wont turn over engine. could have bad battery ground cable or battery positive cable could have broken place when cable get hot crack increases cause less current engine wont have enough power to turn over.
Apr 30, 2013 | Peugeot Cars & Trucks
I have a 1991 nissan pickup. The engine started getting hot, as i was driving it lost power and eventually shut off. I didnt see any water leaking so I checked the oil and antifreeze was in the oil. Now it...
I would really be concerned about the antifreeze in oil, sounds like head gasket at least or head, block problem, even if you dont see antifreeze leaking, the engine can burn it and exit through tail pipe-white smoke or steam (beyond just cold start-up)
Jan 28, 2011 | 1991 Nissan Pickup
Acura legend wont start
Run hot wire from battery to coil to see lf that is your problem.
Jan 11, 2010 | 1993 Acura Legend
2000 GMC Jimmy wont start. Seems to crank just fine but wont turn over. Sprayed starting fluid in and it didnt chug or do anything but keep cranking so I dont think it is fuel related. Any suggestions?
check for a spark if no spark and no fuel to feed bar for injectors ,then try spare key if that doesnt work then its dealer only to look at immobilisor
Nov 21, 2009 | 2000 GMC Jimmy
98 jetta will not start on hot days
I have same problems on my 96 jetta. Did anyone get this fixed?
Jun 17, 2009 | 1998 Volkswagen Jetta
Cooling fan problem
The electric fans on some vehicles dont stay on all the time. If the radiator is not burningyou then i would suspect the guage is bad. The engine would throw a code if the fan was not working properly, so im pretty sure that your fan is working properly. I hope that helps you out.
Nov 21, 2008 | 2005 Chevrolet Impala
Starter
when you turn key to crank nothing happens? or does it turn over and not start?
Oct 10, 2008 | 1990 Nissan 240SX
Help
same happened to me tell meif u get a solution
Mar 02, 2008 | RCA H100 MP3 Player
PowerPro Power Pro C636 00-07 Audi Air Pump 06a959253b 06a959253a 06a959253e A4 A6 A8 Q7 Tt Quattro 00 01 02 03 04 05 06 07 Logo
450 people viewed this question
Top PowerPro Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Are you a PowerPro Fish Expert? Answer questions, earn points and help others
