Question about Blue BLU Studio 5.5 D610A JB 4.2 Android GSM 3G US Unlocked Quad Core Phone
My blu want stay connected to my car bluetooth. It goes on and off. What to do?
If it connects it will quit while your talking. Some time it will pick back up and sometimes not.
    Genius:
  • Blue Master
  • 1,585 Answers
Check battries
Posted on Apr 18, 2015
Testimonial: "It's not the battery."
Compilot will not transmit my voice.
Interesting device. The first thing to check is your Bluetooth connection. Reinstall it on whatever device you are using, called "pairing". This really is NOT a two way radio, there is no push to talk switch and everything depends completely on your Bluetooth device working with the Compilot. So, if paired, check the volume of the device you are talking to, Bluetooth often is quite a bit quieter than you would expect. Post if you need more help!
Mar 01, 2016 | Radio Communications
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
Bluetooth quit connecting with Moto Razr Phone
Go to bluetooth and see what is listed click on it and remove device. Start over.
May 03, 2017 | Motorola Mobility H700 Wireless Headset
How do you turn the samsung hm3700 bluetooth on? How do you snyc it to your phone?
To turn on the Samsung HM3700 headset, slide the power switch up. (You can see it's location on the image below). The indicator light below the power switch will blink blue 4 times (purple or red means your battery is low). If it stays blue it is ready to sync with your phone.2_29_2012_5_42_10_pm.jpgThere are 3 ways to sync this device to your phone:
  1. Once the headset is on, hold down the talk button for 3 seconds. (the blue light will stay lit for 3 minutes once you enter pairing/syncing mode).
  • Activate Bluetooth on your phone and search for the hm3700 (keep them close to each other).
  • Select the headset and enter a PIN number if asked.
2.) Active Pairing: Once you have held down the talk button for 3 seconds and the blue light is on, press and hold the talk button again to make the blue light purple.
  • The device will try to automatically connect to your phone for 20 seconds. Your phone should not be connected to other Bluetooth devices during this process.
3.) FreeSync is an application you can download if you have an Android (from the Android Marketplace). It allows you to access your headset settings and I believe it can read your text messages for you (text to speech).
For more information the user manual for your Samsung HM3700 Bluetooth headset can be found here: http://downloadcenter.samsung.com/content/UM/201111/20111116163119314/HM3700_UM_America_B_Rev.1.0_110923_screen.pdf
Feb 29, 2012 | Samsung Cell Phones
My motorola h700 wont pair to my htc hero.when i hold the button down on the bluetooth, it lights up blue for 5 seconds then the light goes out
go into settings, look for wireless controls or bluetooth, should ask you to pair with the name of your bluetooth if it wont, turn off the bluetooth in the phone and turn off the bluetooth itself by holding down the button for about 6 secs till the light blinks a few times then goes out. turn the bluetooth function on on the phone FIRST, wait till it says its on, then turn on the bluetooth itself by holding the button down until the light blinks a few times then you get a solid light, it wont stay solid, it will blink a few times then go out blinking from time to time. go back to your phone and find the bluetooth menu and it should ask you if you want to pair, hit yes or whatever option you have and it should start pairing and then connect or you may have to hit the connect option if you have one they dont all connect automatically sometimes so you have to go through all this when you charge the bluetooth or turn it off. good luck.
Dec 14, 2010 | Cell Phones
Is my bluetooth able to connect to my PS3 video game.
if its a bluetooth headset ... other than that no...
if it is the headset you go to settings and accesory settings. Then you go to register bluetooth device. Depending on what it is there are 3 options. Whichever it is click on it. but all i know is how to connect a bluetooth headset. Just press the talk or power button on it until it stays litten up and have the ps3 look for it.
hope this helps
Dec 10, 2010 | Sony Video Game Consoles & Games
HTC Bluetooth Connectivity with JVC AVX800
can't connect my htc phone(3450) with bluetooth earphone
Sep 16, 2008 | JVC KW-AVX800 CD Player
Blue BLU Studio 5.5 D610A JB 4.2 Android GSM 3G US Unlocked Quad Core Phone Logo
48 people viewed this question
Top Blue Cell Phones Experts
Heather MacKessack
Level 1 Expert
William Alequin
Are you a Blue Cell Phone Expert? Answer questions, earn points and help others
