How do I connect monitor to the computer? - Computers & Internet
    Genius:
  • 1,585 Answers
Hd lead or other but u will nead a lead of some kind
Posted on Apr 18, 2015
Samsung Syncmaster 943b light blinking but screen remains blank, tested cables, message 'test good' flashes on screen then goes blank again.
try to connect monitor with other computer, this way u will confirm weather the fault is in monitor or in computer. if it is in monitor, check for bent pins in connectors which connecting computer & monitor, firmly connect both ends of connecter & tighten the screws. if problem not solves then u need to replace main board of monitor.
Aug 25, 2011 | Samsung SYNCMASTER 943B 19" LCD Monitor
My screen is black nothing shows up 3 months old
-check the cables on the monitor and disconnect and reconnect it
-if issue still persist you can check the cable of the monitor for broken pins (vga cable the one with blue connector)
-if there are broken pins then the cable could be the problem
-if not you can try to connect the monitor to another computer or connect the computer to another monitor
-if you connect another monitor to the computer and it works fine then the first monitor you have is broken
-but if you connected the monitor to another computer and it works then it could be the video card of the computer.
Nov 25, 2010 | HP w19 19" LCD Monitor
When i trun on my computer the monitor will not work. it says Check Signal Cable
This issue can be caused by any of the below possibilities.
  1. Monitor is not on
  2. Computer is asleep
  3. Connections not connected properly.
  4. Monitor settings are not correct.
  5. No Post.
  6. Hardware issue.
Solution:The following is monitor troubleshooting. If your monitor receives a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please refer to document CH000192.
Monitor is not on
Make sure the monitor is on. If no power light (green or orange light) is seen on the monitor display try pressing the power button until it comes on. If no light comes on after several attempts continue to below connections not connected properly.
Computer is asleep
If your computer monitor was on and you stepped away from the computer and upon returning it was black it's likely that the computer is asleep. Try moving your mouse, clicking the mouse buttons, and/or pressing any key (space bar) on the keyboard to wake it up.
vga.jpgMake sure that you are connecting the monitor to the back of the computer in the 15-pin connector as shown to the right or older computer 9-pin connection.
If the computer is properly plugged in, make sure it's getting getting power.
If you are not receiving power from a known working wall outlet and if the power cord is removable, replace it with the one connected to the computer and attempt to power on the monitor again. If the monitor still does not get power or it is not removable, it is recommended that the monitor be replaced or serviced at a local TV / Computer repair shop.
If the monitor is receiving power, check the status light.
If the light is orange or flashing ensure that the monitor is not in a suspend mode by moving the mouse or pressing a key on the keyboard. If the computer does not get a display by moving the mouse or touching the keyboard, turn off the computer and monitor and reconnect the data cable from the back of the computer, and if removable, the back of the monitor. Turn the computer back on; if you still encounter the same issue, continue reading through the other possibilities.
Ensure that the brightness and contrast is turned up or attempt to adjust the brightness and contrast. If adjusting the brightness or contrast has no affect on the monitor continue reading through the other possibilities.
No Post
Does the computer beep when it is powered on and/or does it appear that the computer has activity? If the computer does not beep or beeps abnormally it is possible that the computer itself is experiencing a hardware issue or is exhibiting a No Post.
Steps on troubleshooting an irregular POST or no beeps can be found on document CH000607.
Hardware Issue
If you have followed the above recommendations and are still encountering the same issue, it is likely that the computer may have either a bad video card or monitor. The best method of determining this is to do one or both of the following:
  • Disconnect your monitor and attempt to connect it to another computer. This can be a friend or family's computer and/or it can be taken to a service center.
  • Borrow a computer monitor and connect it to your computer. This will not harm the other computer monitor in any way.
If your monitor works on another computer it is safe to assume that the video card or potentially the motherboard within the computer is bad. Steps in troubleshooting a video card can be found on document CH001028.
If another monitor works on your computer it is safe to assume that your monitor is bad.
Nov 14, 2010 | HP Pavilion Slimline s3500f Desktop...
My monitor is plugged in and everything but it won't display
  5. No Post.
  6. Hardware issue.
Monitor is not on
Computer is asleep
No Post
Hardware Issue
PLEASE ACCEPT IF YOU SATISFAID
Nov 14, 2010 | Samsung 932BW Monitor
DEAR SIR I HAVE ONE PHILIPS CRTMONITOR 107E61 MODEL PROBLEM IS POWERING ON BUT NODISPLY ALL SECONDARY Vg are ok pls help thanks and...
Cause:
  5. No Post.
  6. Hardware issue.
Monitor is not on
Computer is asleep
No Post
Hardware Issue
Nov 14, 2010 | Philips 107E61 17" CRT Monitor
My monitor has turned a greenish color
It's probably the video-adapter on your computer that has a problem, or maybe it's the video-cable that either is damaged, or the cable is not tightly-connected to both the monitor and to the VGA port on your computer.
Connect the monitor to a different computer, to see if the problem "follows" the monitor.
Connect a different monitor to your computer, to see if the problem "stays" with your computer.
Oct 21, 2010 | HP w1907 LCD Monitor
Horizonal line in monitor screen cant seem to adjust
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer. ry the following steps:
    3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer. let me know if this resolved ur issue.. got plenty of resources to help u out.. regards guru
May 01, 2010 | Computers & Internet
Says No Signal but I clearly just pluggd it in and turned it on, and yes my computer is on
The "no signal" message is telling you there is no output from the computer. The output signal switches on the monitor, so if not there, check your cables and connections. If you have another monitor, try connecting it instead, and see if it works.This is an unusual problem, so keep trying. Connect the monitor to another computer, such as a laptop, and see if it works. If the monitor on another computer works, obviously it the first computer. If the first computer works with the second monitor, it's the first monitor.
Mar 31, 2010 | ViewSonic VA903B Monitor
When I put the data cable the screan turns off
It should do exactly that, since that is what information that your computer is sending to the monitor. When it is *NOT* connected,
then the monitor may display a "not connected" message.
Turn on the computer that is connected to the monitor,
and it should start to display some text, as the computer starts.
Also, try connecting the monitor to a different computer (desktop/laptop) to see if the monitor works at all.
Jan 02, 2010 | Samsung SyncMaster 710m 17" LCD Monitor
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
