Question about Westinghouse LD-4655VX 46" LED TV 1920x1080, 120Hz, HDTV, LED Edgelight
Tv cut off for no reason and will not come on. makes a clicking noise now.
    Top Expert:
  • Westinghouse Master
  • 6,702 Answers
Where the defect is, and what it could be is not important when you don't have enough electronic skills to do the repair yourself. Could be one or more defective capacitors or a bad connection on the main board or even on the power supply. I would check there, but not skilled? Then consult a tech and ask what it will cost you, before you ask for repair. Repairs can be expensive, new TVs come in all prices and these are dropping still.
Posted on Apr 18, 2015
    Top Expert:
  • 75,178 Answers
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
    Genius:
  • 1,585 Answers
Capasator prob sounds like
Phillips 60pl9220d 37
The power supply may be failing.
Nov 22, 2013 | Office Equipment & Supplies
My TV keeps switching its self off, it makes a clicking noise as if its trying to switch on. Then cuts out.
Do to the clicking noise your tv makes is a very common idicator that your power supply in the tv is failing. Its an easy fix lots of DIY videos on youtube but may cost you a arm.
Apr 29, 2013 | Philips 28PW6506 28" TV
My tv keeps saying stand bye and it won't cut on all its doing is making the click noise and the red light keep blinking
Try unplugging it for 30 seconds and see if it resets. If not, take the model # and get on the internet for the manual and go to trouble shooting page. It should answer your questions
Feb 13, 2013 | Televison & Video
Washer is making different noises during wash and rinse cycle
could have been the motor,you might also smell like a shellac kind of smell,when the motor overheats,also how old is it and what's the brand name and model number.you can feel the motor,if it's hot then it is cutting out for some reason.
Dec 20, 2017 | Washing Machines
TV wont cut on it makes a clickin sound but dosnt come on . if I keeppushin the button it comes on after a while.
Your TV most likely has faulty capacitors in the power supply section of the TV. This is a failry common problem.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
2c07611.png The number one cause for the symptoms above are faulty capacitors within your Plasma or LCD TV. The number one reason that these parts fail is that TV manufacturers often times use lower grade capacitors in their efforts to reduce costs. After several years these lower grade parts will tend to fail first. To insure that these parts will not fail again its imperative that they are replaced with high temp, high quality, low-ESR caps. You can find the parts online from sources like Digikey or you can get complete reair kits incuding the parts, repair instructions, and support from www.TvRepairKits.com
Dec 15, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
I hear the fan almost non stop while the tv is on.
You have a bad color wheel. The color wheel is located in front of the lamp, as the light shines through it as it spins. It is made up of different colored segments of glass, and one of the segments has came loose and causing the vibrating humming noise. The reason I know it isn't a fan is because the fans will continue to run for about 30 seconds after the set is powered off. The click you hear is the relay cutting off the fans. The color wheel cuts off as soon as you press the power button to cut the set off. I've replaced many of these at our shop for the same problem.
Jul 29, 2010 | Samsung HC-P4752W 47" Rear Projection...
Samsung Tantus Model 553W HDTV1080i, when you turn the tv it just has a black screen and makes a clicking noise like it is turning on and off
Samsung has had a issue with several models, with power supply going out. The clicking noise is what lets you know it is the power supply, it is teying to cut on but has not power from the board so it cuts off. I would call Samsung and see if your model happens to be listed as the models they are covering the power supply for, your exact model number is HCM553WX. If that model is not on the list of covered models, you can ask Samsung what to do, because parts for your tv are no longer available. Hope this helps. You can reach Samsung at 1-800-726-7864
Mar 31, 2010 | Samsung PCH521R 52" Rear Projection...
Sony Wega KDF - 42WE655 - back of TV is making clicking noise
yes you have a bad lamp fan google for part# it is easy to install
Jun 09, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
2 tv's when I try to cut them on they make a clicking noise
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here, a common fault is PSU, but part must be tested before replacement.
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Mar 15, 2009 | Toshiba 27A62 27" TV
Tv turns on and turns off after 5 seconds
jim if know how to soldering iron ,resolder your tv especially the power supply
Jan 26, 2009 | Televison & Video
Westinghouse LD-4655VX 46" LED TV 1920x1080, 120Hz, HDTV, LED Edgelight Logo
48 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
