Question about Kenwood Car Audio & Video
Vow many rca s go to my 4 channel kohl amp if I want to bridge it to 2 Kenwood 12s
blueextc3221
  • 15935 Answers
SOURCE: need specs and wiring options
  • 105W x 4 Channel Max. Power Output at 2o.gif Stereo
  • 60W x 4 Channel 0.1% THD at 2o.gif Stereo @13.8V (RMS Continuous Power)
  • 40W x 4 Channel 0.1% THD at 4o.gif Stereo @13.8V (RMS Continuous Power)
  • ChannelFlex Crossover
  • Adjustable High-Pass Frequency (50-200Hz, L/R Independent)
  • Low-Pass Frequency (120Hz)
  • Adjustable Bass-Boost Level (45Hz, 0-9dB, F/R Separate)
  • High-Current, High-Speed Output Devices
  • High-Efficiency, High-Energy MOS-FET Power Supply
  • Audiophile Grade Component Selection
  • Intelligent 7-Way Discrete Protection Circuitry
  • Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
  • High-Level Input - Add on Capability
  • Epoxy Composite PCB
  • 2o.gif Stable Design
Each 6 1/2" speaker will see 40 Watts
Each 6"x9" will see 521/2 Watts
Yes your solution is correct. Front wired in stereo, bridge rear.
Posted on Dec 29, 2008
  • 4 Answers
SOURCE: Amp Goes in protect whne bridged cuts out
do u have an crossover
Posted on Feb 03, 2009
  • 323 Answers
SOURCE: the amp is only putting out on 1 channel
I do believe this is caused by one of your amp fuses. Depending on which + on the amp is being used. That channel has a blown fuse. have you tried running + and -, + and - to both channels to see if both subs worked? If one sub doesn't then it's a blown fuse or scarred fuse and needs to be changed.
Posted on Feb 10, 2009
SOURCE: KAC-9104D output terminals
ok i have the same amp and 1 2ohm dvc sub and was woundering the same thing but from futher research and askin sum xsperts. What i found out is that it is only one channel and even tho there are 2 (+) and 2(-) they actually connect inside the amp makein it one . so if u wanted to wire sumthing parralel u wouldnt have to hook wires from one coil to the other on the speaker , u can just hook it up to the amp. so basically both +'s and negatives on the amp are actually one within it so all the power if you only use one set of them and if u wanna add more subs its just easier to add to the amp by using the xtras .
Posted on Feb 15, 2009
  • 9 Answers
SOURCE: KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Posted on Jun 24, 2010
I have an alpine mrv-f307 4/3/2 channel. I have it hooked up to 2 12in Kenwood subs. Right now standard 2 channel each sub having their own. I heard doing a series hook up and bridging the subs to the amp ...
Bridging an amplifier refers to combining the power of two channels to run one speaker at higher power. If it is wired correctly, your amplifier is running with 4 channels bridged into 2 speakers now.
Mar 11, 2015 | Kenwood Car Audio & Video
Can a 4 channel amp run door speakers and a (1) sub as well
No only 2 speakers with the other channel bridged.
Aug 28, 2012 | Cars & Trucks
I have a 8 0 4 phonix gold amp and two 12s i blew the 12s and i bought some but they are 4 ohm how should i wire them?
You will have to wire each sub to an individual channel. you cannot bridge the amp, because it is not stable at 2 ohms. You could bridge it if you wire the subs in series, but you will get more power by committing each sub to an individual channel.
Mar 20, 2011 | Phoenix Gold Octane-R 2.5:2 Car Audio...
ON MY Pioneer PRS-X720 Car Audio Amplifier WHEN I TRY TO HOOK UP THE BRIDGE LITTLE SOUNDS COMES OUT THE SPEAKERS I HAVE TWO 12S MTX THUNDER IN THEY ARE IN A 2OHMS BOX BUT WHEN I HOOK UP JUST ONE CHANNEL...
From the specs this amp can only handle 4ohms when bridged but can handle 2ohms when it's not bridged
Specifications
  • Continuous Power (20Hz-20kHz, 0.04% THD)
    • 2 ch: (4 Ohm) 100Wx2
    • 2 ch: (2 Ohm) 200Wx2
    • 1 ch: (4 Ohm) 400Wx1
  • Maximum Power (EIAJ)
    • 2 ch: (4 Ohm) 250Wx2
    • 1 ch: (4 Ohm) 750Wx1
  • Frequency Response: 10Hz - 50kHz (0,-1dB)
  • Total Harmonic Distortion: <0.01% (1kHz, 4 Ohm)
  • Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
  • Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
Hope that helps.
Nov 08, 2010 | Pioneer PRS-X720 Car Audio Amplifier
Can i bridge a Sony Xm-1652Z 2 Channel amp to 2 subs it gives me 2ohms
No - it is not 2 ohm mono stable
  • 1000W max power
  • 165W x 2, 20Hz - 20kHz, @ 0.04% THD + N, at 4 Ohms
  • 200W x 2, 20 - 20kHz, @ 0.15% THD + N, at 2 Ohms
  • 400W x 1, 20Hz - 20kHz, @ 0.1% THD + N, at 4 Ohms
  • OTL (Output Transformerless) circuit
  • Pulse power supply
  • Line & High Level Inputs
  • .3-6V Level Adjustment Control (RCA Pin Jacks) 1.2-12V (High Level Input)
  • 80 Hz, -18dB/octave Low Pass Filter Switch
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
How do i set the rca settings for my kenwood kdc-217
Theres no way to change the rca settings. More than likely they put out 2 volts which is more common. Some newer more expensive models put out 4. What size remote wire you using? Try using a bigger (smaller #) gauge wire. That will give it a boost if your using the one that came with an amp kit. What kind of speakers? What kind of amp? If amp is mutli channel and only one sub then you will need to bridge the amp. Try different combos of + and - to see which gives the best. Also make sure everything is turned up on the amp and set to low pass frequency.
Jun 22, 2010 | Kenwood KDC-217 CD Player
Amp and speaker wiring
if the 12's are single 4 ohm coils then i would run them parrelle to the amp bridge to one channel. this will be 2 ohms bridge and will be the best and most power.
Jan 29, 2010 | Autotek SS500.1 Car Amp
I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS @ 1 Ohm Mono
1 x 650W RMS @ 2 Ohm Mono
1 x 500W RMS @ 4 Ohm Mono
Fully Unregulated MOSFET Power Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
Amp turns off
You did not specify the model you have - however the Flex series is only stable with a load of 4 ohm mono (bridged) and 2 ohm (stereo).
You are driving the amplifier to work too hard, and it is shutting itself down.
Re-wire using one subwoofer (bridged) or wiring the subwoofers on seperate channels.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 08, 2009 | Car Audio & Video
My Kenwood 800watt amplifier
Sounds like you have overloaded your amp. When you bridge you MUST make sure that you still have the proper speaker load. One 4 ohm speaker on one channel is fine, but when you bridge that same 4 ohm speaker, it gives you a 2 ohm load on each of the two channels that are now bridged. If you made the mistake of wiring two 4 ohm speakers in parallel (plus to plus and minus to minus) then when you bridge you will be driving a one ohm load on each channel. This is very close to a dead short. Stop using your amp at once until you get your speaker load correct. This will damage your amp and it will cause you to have to go to a repair shop to fix it. DO NOT RUN YOUR AMP ANYMORE UNTIL YOU FIX THIS. Good luck.
Jan 22, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
52 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
