Question about Samsung Televison & Video
Need lost codes for samsung tv using a zenith universal remote ZP505
    Top Expert:
  • Samsung Master
  • 74,136 Answers
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. Code list for Zenith remote control is given.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 18, 2015
SOURCE: programming
push the tv button then hold down the code search button till the light becomes solid. point the remote at your tv while it is turned on and push the channel up or down til the cannel changes. once it does push the mute key to save. so u know this works like that on all device and if you pass up the right on from pushing the button too fast you can just push the opposit direction rather than waiting for full circle. also be aware that there are multiple codes for some devices and some work better than others.
Posted on Aug 26, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
whytfang
  • 170 Answers
SOURCE: I NEED THE CODES
Here is the user manual...this should help...
Here you go...it took a while but I found it cause I ROCK....that'sright say it with me....He...Rocks...hehe...but anyway here is the linkaddress if the link doesn't work...
http://safemanuals.com/user-guide-instructions-owner-manual/JENSEN/JER-321-_E
I hope this helps...good luck and thanks for rating my effort....the Fang
Download the completeuser guide (3257 Ko)
Posted on May 20, 2009
the q guy
  • 393 Answers
SOURCE: Philips Universal Remote #CL034- Need tv codes.
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
let me know if this helps
Posted on Jun 25, 2009
  • 1126 Answers
SOURCE: zenith universal remote codes
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=zenith&dv=universalremote&md=zn501s&kw=&st=&ar=&dt=&so=&pg=2&file=others/zenith/zn501s-manual.zip
Unfortunately, there is no code sheet included in this user guide. However, Code Search is covered on page 10.
Posted on Sep 11, 2009
Testimonial: "thanks, took 2 minutes and i was back in action"
I have lost the book to code a Zenith TV Could you help me find the code Please? I had it coded to another TV which died so now have a Zenith & now I cant find the book on how to code the Universal...
I couldn't find the manual for the remote you specified, however, as long as it is a Philips remote, you should be able to use any manual to find the code. If you know how to program the remote but just need the codes, you can get the codes here:
http://www.p4c.philips.com/cgi-bin/dcbint/get?url=/sca/sca/091116/091116160956_30167.pdf&ofn="H15022.pdf"
Dec 20, 2010 | Philips 313923812851 Remote Control
I need codes
Hi stimmdua,
There are a number of codes for your remote that work with Zenith TV models. They are:
002 008 115 215 405 407 601 701 713 903 916
For your reference, here is a web address that includes all the codes for your remote, along with programming instructions:
http://www.universal-remote.net/philipsmagnavox.html
I hope this helps - please let me know if I can be of any further assistance.
Dec 12, 2008 | Philips Magnavox Learning Universal Remote
Philips universal remote control. I need TV zeneth code
zenith remote codes 10017, 10463, 11265, 10178, 10092,
does these help?
Dec 01, 2008 | Televison & Video
Need ESA code to program our Zenith Universal remote 425
I own a One-for-All universal remote (model URC-4220) , and my booklet says the setup code for an ESA TV ( without a built-in DVD or VCR) is 0171 or 0812. I can not guarantee these numbers will work with your remote, but it is worth a try.
The alternative choice, is to purchase the same remote that I have, which cost less than 10 dollars at Walmart.
Jul 08, 2008 | ESA EF402E 20" TV
RCA universal remote code
i lost my book with my codes . can you tell me the correct code to my rca to my zenith television
Apr 10, 2008 | RCA RC-U703SP Remote Control
Need all codes for the universal remote zenith zn bb5
I used the code provided by Philips Universal remote. It works great. One thing you have to ignore the first digit. Just use the last 3 digits only.
Mar 02, 2008 | Zenith ZN-BB5 Remote Control
Televison & Video Logo
74 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
