Question about Radio Communications
I have had this handheld CB radio for years and it stopped working. When i turn it on it beeps and the screen lights up but no sound.
When I push the transmit button to talk tx does not show and I am unable to communicate. Is it possible to reset to factory settings as we have played with that many buttons to try and get it to work?
  • 693 Answers
Hi Corinne!
I concur with Brett's theory on this.
Batteries do have a finite lifespan.
IF you could tell me the make and model of your handheld, I'll give it a shot on where you can obtain new batteries for it.
(EDIT)
Armed with this new information, (assuming you're in Australia) I would suggest these batts as a replacement. They're 2000 mAh and REAL close to your OEM batteries of 1900 mAh. http://www.panasonic.com/au/consumer/solar-lighting-batteries/household-batteries/eneloop-rechargeable/bk-3mcce4ba.html
Hope this Helps and good luck!
-Steve
Posted on Apr 18, 2015
Testimonial: "Sorry it's a Uniden UH720SX. it uses recharaable AA Batteries and I have tried that to no avail."
  • Radio Commun... Master
  • 3,554 Answers
Check batteries they may need to be replaced with new batteries. Had similar experience on my daughters uhf walkie talkies.
No sound when turned on
The manual may be viewed here.
Have a look at the video below for a quick rundown of features and use.
If you're in the US, this is NOT a "CB" radio. It is a UHF radio operating between 476.425 Mhz and 477.400 Mhz that seems to be popular in Australia. Transmitting on this radio in the US and quite possibly a number of other countries, too) will result in violation of FCC rules & other laws; as the frequencies it works on are not available for the general public. You will likely be interfering with other users / agencies that have paid large sums of money for licenses to use these frequencies.
Check with your country's communications laws before attempting to transmit - even if in Australia - as there may be laws governing their use there, too.
I hope this helps & good luck!
Jan 22, 2013 | Uniden Radio Communications
Cobra handheld cb radio stops working when inserting external power source
If it works with batteries but no via the external input for power either the socket for that is bad or the source voltage is not there when connected that way
Dec 04, 2012 | Cobra HH-38WXST CB RADIO 40CH 10 WEATHER...
When we push the button to talk, we get a low frequency squeal, and the other CB radios receive a squeal. We have tried adjusting the sqelch, no fix. It seems to disappear sometimes when you turn it on and...
Hi,my name is John. Welcome to FixYa. Do you hear voice in radio? May be to close to each other. Let me know how it goes. Good luck and thanks for Choosing FixYa ..John sounds like feed back from speaker.
Nov 06, 2010 | Cobra Road Trip 40-Channels Handheld CB...
I am to trasmitt and receive while ignition key is off but when i turn key on i still am able to transmitt but i receive a lot of stastic. I have replaced the antenna and co ax and redone the ground.
Hi, my name is John. That noise you hear is probably coming from switch,such as ,seat belt warning,door,light, key switch , exc. Try running your CB wire strait to the battery, and see if it stops. If not, Radio Shack sells a noise limiter that goes in line with your connection, don't know how much. Do you have your noise limiter or noise blanker switch on the radio?...hope this was very helpful....
Aug 29, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
The weather/alert light stays on when cb is turned on, is it supose to be on when not listening to weather and is this radio supose to sound an alarm when put out a weather alert? the light blinks is it....
Hi Bill
We have the same radio.The weather light is suppose to stay on as long as it has a stable wx signal and it does beep and blink when it gets a warning from noaa. This unit is working just as it was designed to and mine is a great radio.
Thanks
Ray
Aug 11, 2010 | Radio Shack TRC-447 CB Radio
I have a Maxon handheld cb - it squeals when keyed can not talk.
sounds like you are getting a feedback squeal.. try taking a wire and attaching to you handheld and grounding it to something.. that might work.. i know i have to have my mic on my cb grounded to my radio or i get a feedback squeal...
Jan 02, 2009 | Maxon HCB-10C CB Radio
Cobra Cb handheld radio model: HH-35 doesn't work
Open up the back of the radio and check the solder joint from the antenna connector. I had same problem and it was this.
Mar 23, 2008 | Cobra HH 38 WX 40-Channels Handheld CB...
Kenwood TK370N UHF FM HANDHELD RADIO
By keeping the PTT button pushed, if you get a rapid beep and the red led is blinking, sounds like a bad battery. Batt voltage is a nominal 7.5v. anything lower than 6.25v and the low battery beep starts. A rapid beep, and no red led blinking, an error in the transmit freq.
Mar 01, 2008 | Kenwood Radio TK 260 360 270 370 2100 3100...
Radio Communications Logo
142 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
