Question about Panasonic RP-HJE350E-P Advanced Ergo Fit Earphones Anti-Touch Noise Cord- Pink Headphones
How to fix a rusty earphone tip/chipped earphone tip?
My earphone sound is scratchy and I have to rotate it ever so often to get the perfect sound. This is because either the tip of the plug is chipped, or it is just rust. If you look at the picture, is it rusted or chipped? How can I fix it? http://i.imgur.com/8tqRe9U.jpg Here's a pic. The orange part on the tip is either chipped or rusty. How can I fix it? I'll only buy a new pair if I need to, but I see a chance of fixing this pair of earphones. Also, the brand of earphones I am using is Panasonic.
  • Panasonic Master
  • 2,861 Answers
Your picture doesn't look either rusty or chipped. You could clean the plug with a "magic eraser", but it's more likely that the wire itself has become damaged, and will need a new plug installed by shortening the wire a few inches. The plugs are quite inexpensive, and available at any electronics store.
Posted on Apr 18, 2015
Testimonial: "I already tried cleaning the plug with a napkin drenched with some soap and water; it didn't work. Also, I have no clue on replacing the plug with a new one."
  • Jay Plesset Apr 18, 2015
    "magic eraser" is slightly abrasive. Soap/water on a napkin won't clean possiblr corrosion off. Magic Eraser will.
  • Panasonic Master
  • 5,631 Answers
Buy a new one
How can I fix my phone cause now it let me listen through my left earphone only.
that should indicate to you that it needs to be properly diagnosed and/or repaired by a technician in a phone repair shop
Oct 04, 2016 | Cell Phones
Samsung galaxy s3 headset icon shows and when
try cleaning up the headset hole in the phone using a cue-tip for ears. dry . and if the headset icon doesn't disappear un-plug and re-plug the jack eventually power off / on restarting the phone. see if this helps ;) good luck!
Oct 02, 2014 | Cell Phones
The sound is coming out perfectly in the right earphone but it is barely coming out in the left earphone
Then you need to adjust the earphones plug in, adjust it gently and it will sound right on both earphone. It is the plug that is causing the problem. Adjusting it will solve the problem for you.
Jan 11, 2011 | ILuv Audio Players & Recorders
Hi i have a 1st gen 16gb ipod touch. When i insert the earphones into the socket i either get no sound, very poor quality sound, or ok quality sound which disapears when i move. i think this is because of...
Some devices such as yours have a 4 conductor jack, (used for earphones and microphone) and most earphones have a 3 conductor plug. They are not compatible. This would be my first guess. Second is earphones and earbuds get tossed around, put into pockets, etc. The cords can get damaged, and not be visible from the outside as the wires inside are very delicate. I would try a set that works in a different device.
Dec 02, 2017 | Apple iPod touch 1st Generation (8 GB) MP3...
JVC HA-S700 Cable Problem
You might want to check out my tip on dealing with dodgy plugs/cable on headphones.
Jul 08, 2010 | JVC HAS700 Headphones
Don't get sound fron ONE of PCX 250 earphones. Am
See my tip on replacement of cable and plugs on headphones it help decide what to do.
Apr 24, 2010 | Sennheiser PXC 250 Consumer Headphones
Scratchy radio volume dial
Use an electronic contact cleaner. You need to shoot it inside the pot through the openings. Then rotate many times. This will remove oxidation on the contacts inside. If you don't use a contact cleaner, turn of f the radio and rotate many times the potentiomer left-right-left-right ...When you turn it on again, you will see the scratcy sound will be reduced but it will come back eventually. The more often you rotate, the less noise it will make. This is a very common problem, nothing to worry about.
Oct 19, 2009 | Audio Players & Recorders
Low and bad quality sound by headphone port
sounds like an internal problem
like a bad connection
if you have the skill, you could pull it apart and resolder the parts around the earphone output jack
hope this helps!
Jun 27, 2009 | iRiver X20 MP3 Player
Earphones
Common problem with mp3 players, not just iRiver. Unless you are unusually careful with them - as in, sit still and don't move, this is something you can expect going forward. If you are experiencing the -sound out of only one earphone problem- then the mp3 player itself is faulty and needs to be replaced. If it just sounds scratchy, then sit still and don't move. Sad, but true. 3 times in 4 months is a bit excessive.
-Tha Mp3 Doctor
Nov 27, 2008 | iRiver E100 Digital Media Player
Philips Pet706 portable dvd will no longer play sound without earphones
try connecting it to small external multimedia speakers (usually played with computers) that come with a small jack simmilar to that on earphones.
Aug 13, 2008 | Philips PET702 Portable DVD Player
Panasonic RP-HJE350E-P Advanced Ergo Fit Earphones Anti-Touch Noise Cord- Pink Headphones Logo
174 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
