Question about Universal Huawei U9200 Ascend P1 Android 4.0 WCDMA Barphone w/ 4.3"" Capacitive Screen, GPS and Wi-Fi - Black"
My phone shuts down during booting
It continues to turn off during booting,it just flickers then turns off. i tried hard reset with no joy, please can you guys help. thanks alot
    Top Expert:
  • Universal Master
  • 10,875 Answers
Call your service provider
Posted on Apr 18, 2015
My phone Huawei U9200 shuts down completely during booting,i hard reset it but no joy either.
You have to fear it is defect. Visit a phone store and ask them. If it is under waranty bring it back. I hope you did make backups.
Apr 18, 2015 | Cell Phones
Tip
How to reset Kyocera Zio m6000
Soft reset
Dial: ##4357*
Select view
Scroll down to select reset.
6 digit code: 000000
Click Ok
Should reboot.
Dial *228
Hard reset
1. Power down the phone
2. Hold down the volume up, end key, trackball and send key simultaneously.
3. Phone boots. After it vibrates you let go.
To reset Kyocera Zio try the following:
1. Remove battery and put it back after two minutes
2. Press and hold down the home button key while turning on the phone.
3. If by chance the phone starts , do Menu Button > Settings > SD Card USB MASS > Factory Data Reset
If it does not work, try:
Hard reset 2.
1. Power off the phone.
a. Press and hold red END key for 2 seconds >> Phone Options >> select Power Off >> Phone will shut down >> Ok
a)
2. Remove battery for 15 seconds & replace battery.
3. Power up the phone.
a. Press and hold red END key for 2 seconds and wait until the device powers up completely.
b)
4. Power off the phone.
Procedure, cont.
5. Press and continue to hold the Volume Up button using your left thumb.
6. While still holding the Volume Up key, use your right hand to depress the green Send key, the white Track ball and the red End key (sequential order).
7. Continue to hold all 4 until keys completely down until the handset vibrates twice then let go of the keys & track ball.
a. Formatting Data and Cache appears
1. If you do not see the above (Formatting Data and Cache) redo steps 1 through 7.
2. If you get a Fast Boot, Self Test or Blue screen redo steps 1 through 7.
3. Allow the phone to completely reboot. This may take a few moments.
4. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
If still no luck, call Kyocera directlyand report the problem.
on Sep 03, 2010 | Cell Phones
Toshiba laptop will not go psat the toshiba logo
There are a number of stages to go through. For all these please ensure that the laptop is switched off. First, remove the battery, then plug the mains charger lead in and try to boot, if you get past the splash screen than it is the battery at fault, if not then the next step is to switch the laptop off close the lid and turn it over, on the bottom you should see an access door with either one or two screws, open this access panel up and remove the hard drive, turn the laptop back over and try to boot up again, it should go past the splash screen and the detect that there is no hard drive installed, if it dose not get past the splash screen then turn the laptop back over re install the hard drive, try again to boot up, if still no good then try removing one of the memory chips, these are found under the same access panel. Try again if still no go then remove the other memory chip and replace the first one you took out. If no joy after all these steps, then sorry I have no further suggestions. Good luck.
Feb 03, 2014 | Toshiba Tecra R850 Series Black Notebook...
X501 completely shuts down during calls then restarts and says "preparing SD Card" and continues giving error notifications
You're going to have to do a hard reset...THIS WILL ERASE EVERYTHING ON THE PHONE (not the sd card)
Make sure the phone is off, hold the power button, volume down and the back button (third button from the left on the bottom) AT THE SAME TIME, hold and wait, once your in the back menu use the volume button to scroll down to factory reset use the power button to select, use the power button again to scroll down to yes, and power button to select, just wait, with will shut down and turn itself back on, takes about 5 minutes to restore function. (I worked for Cricket for a long time and I know the phone well)
Aug 13, 2013 | Cricket Wireless Cricket - Zte X501 Groove...
Continue reboot loo
There are a lot of possible reasons for this.
1. Fan is bad.
2. Motherboard has gone bad.
Do you still see the Compaq logo when you turn it on?
David
Jun 10, 2013 | Compaq Presario 700 470024-192 Notebook
My son changed th password but forgot it how do i hard reset this nokia lumia 610?
Turn off your phone. Hold volume down+power+camera until phone vibrates and NOKIA logo appears. Then release the power button, but continue to hold down volume down + camera until boot completes. Your NOKIA lumia has been hard reset. All data will be lost.
Feb 13, 2013 | Cell Phones
My kyocera sanyo cricket phone screen is locked how to unlock it
Hard Reset.
1. Turn off the phone
Phone is completely reset as if it came out of the box. You'll need to *228 and reload ALL of your data.
or WARNING: This process will clear all user settings and downloaded apps. Data on the SD Memory Card and My Backup will be retained. Prior to following the steps below, ensure the phone is powered off.
a)
b)
Procedure,
8. Allow the phone to completely reboot. This may take a few moments.
9. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
NOTE: If you receive a self-test screen or blue screen, the hard reset was done incorrectly. Please try again, from step 1.
Sep 12, 2011 | Kyocera Zio M6000 Cricket
Unhooked battery now starts then shuts down
try the spare key and if no joy then call a breakdown truck and have taken to a dealer to re-programme ,but i read a answer from another american mechanic on here and he wrote that you turn ignition on and press the trip meter switch for a while and all the lights and things flicker and buzz and the car resets itself ,its worth a try with this one i think
Feb 12, 2011 | Cadillac CTS Cars & Trucks
Universal Huawei U9200 Ascend P1 Android 4.0 WCDMA Barphone w/ 4.3"" Capacitive Screen, GPS and Wi-Fi - Black" Logo
241 people viewed this question
Top Universal Cameras Experts
Are you an Universal Camera Expert? Answer questions, earn points and help others
