Question about Refrigerators
How to clean the inner workings - Refrigerators
  • Bestway Apr 18, 2015
    Hi Carmen Aubin, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Anything specific you want to check? What is the make and model?
    Top Expert:
  • Refrigerators Master
  • 10,875 Answers
Unscrew the parts dont pry,use bleach and water to clean
Posted on Apr 18, 2015
Admiral ATW4475 Left by prior owner of home. Unpleasant Odor of moistness / mildew? / gunk emanates from tub despite careful cleaning including the inside rim. What should be checked and cleaned?
The basket / inner tub is actually what you see when you look in the unit. The inner tub connects to the transmission and sits inside the outer tub. Unless you take the whole top off and remove the inner basket, it is almost impossible to clean the outer tub. You can try to use the oem cleaning method and this is to run it with no clothes, on the hottest setting with one cup of bleach in the water.
Dec 16, 2016 | Admiral Washing Machines
How do you clean the lint filter?
you can't clean lint filter. It has a built in filter that cleans itself. It is under the inner basket. If you have to, than remove the agitator and inner basket. It is attached to basket on bottom. No need to clean though
Jun 15, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
Our Uniflame Grill has a round outer burner and a round inner burner. The outer burner has a large orange/yellow fllame. The inner burner has a small blue flame. Is it normal for the inner burner to...
Bob, your wife is partially correct. However, both burners should have blue flames with orange tips. Cleaning the burners and the their venturi valves, should solve the problem. When I say cleaning them, I mean removing and cleaning them.
Hope this helped you and Happy Grilling!!
Jun 27, 2011 | Uniflame FG2204C Grill
After cleaning the inside of glass door is still dirty? What should I use to clean it?
you need to split the inner and outer door panels, then remove the inner glass pane from between the 2 sections then carefully replace all parts especially if its a self- clean oven type
Mar 05, 2011 | GE Kitchen Ranges
Speedometer quit working on 2001 883 hugger
Chances are, it is the cable or connection. Remove the speedo cable from the front tire. See if it turns; this is tough to do, don't sweat if you can't get it done. Remove from the speedo side. The inner should come out from the outer. I would bet the problem is, it is rusted up inside. Chances are good it is no longer in one piece. If it comes out, clean both sides and oil. Compressed air is about all you can do for the outer, maybe a bit of sand to scrape it. If you chuck the inner on a drill motor and CAREFULLY drive it while in the speedo (it will coil up like a slinky and get ruined), you can see if the speedo works.
They sell inners only, but trust me, if it's that bad, buy the whole thing. You'll only gum up & bust the new piece unless you clean the outer well, and it's cleanable with something like a small gun cleaning rod, but it's just not worth the headache.
Aug 18, 2010 | 2001 Harley Davidson XL Sportster 883...
My speedometer quit working. The sensor is clean.
The easiest way is to take the speedo cable off and inspect it. If the speedo has a cable, it's a mechanical speedo. Unscrew the cable at the either the speedo or the speedo drive mechanism. Pull the inner core out and examine it for damage or wear. the ends of the cable are sort of square as compared to the rest of the cable that is round. Make sure the cable is not broke or the square ends are rounded off. If the cable looks good, lubricate it with wheel bearing grease and reinstall the inner cable back into it's outer sleeve. If the cable is good and working as it should, that leaves nothing else but the speedo.
Mar 25, 2010 | 2008 Harley Davidson FLHX Street Glide
How to clean the inner blades
compressed air.may have to diassemble to access the fan blades.
Feb 14, 2010 | Heating & Cooling
I want to know how to remove the inner drum on my Samsung top loader to enable me to clean the outer drum.
you will need to remove the agitator by removing 1/4"hex screw at the bottom of agitator,then you need a "spanner wrench" to remove inner tub-basket hold-down nut then you can remove inner tub to clean outer tub
Nov 18, 2009 | Admiral AW22 Top Load Washer
Cleaning between oven glass
You must unscrewed inner door,there is screws around edge door inside,try it.
Feb 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Inner fan
inner fan is working all the time in order to cool off the electronic units, but you may wanna try checking for overheating. this can resault of: - air hole too close to the wall, or jammed by something. - working enviroment is too hot. room temperature and so. - dust and dirt accumulated on the fan, or heatsinc. you can clean it with a vacum cleaner or compressed air.
Feb 22, 2006 | Xerox WorkCentre PE16 All-In-One Laser...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
