Question about Amana Washing Machines
Why wont my brand new washer turn on? Ive only used it 11 times.
    Genius:
  • Amana Master
  • 1,585 Answers
If u dont get any power into mech i whould give the same advice for if u tamper with it ure gaurentee will b none void let them fix it
Posted on Apr 18, 2015
    Genius:
  • 1,056 Answers
Have you checked the circuit breaker for the outlet it's plugged into? That is the first thing to check, make sure it's getting power. Next is does it show any signs of life? (aka lights on the panel on?) Have you tried changing settings to see if it one combination or another? Once you have done some of the basic troubleshooting, contact the store where you purchased the washer and talk to them; since it is almost new (as you stated) it should be under warranty. The store should handle it, or they have a service shop they could be working with.
Dont know which fuse operates fuel pump
) Unplug the main relay and then turn the key from off to ON(II).
2) Use a jumper wire or paperclip to jump terminal 1 to terminal 7 in the main relay plug. Does the fuel pump run?
3) Now use the jumper wire or paperclip to jump terminal 5 to terminal 7 in the main relay plug. Does the fuel pump run?
Jan 05, 2014 | 1994 Honda Civic
1993 buick regal wont crank over brand new battery as well! i have installed an after market cd player but ive done them meny times that its wired correctly. im so confused at why it wont start didnt...
Starter problem. Make sure your connections to the starter are tight, both the battery cable and the starter solenoid wire. Will probably have to take starter off and have it tested.
Sep 30, 2011 | 1993 Buick Regal
Okay, my fisher and paykel gwl15 is almost brand new. i moved it into my new house tonight. I tried washing my laundry and it starts to fill but then stops at the light that says "wash" and wont...
Sounds like you have low water pressure or a blocked hose inlet screen. take the hoses off and check to see if there is any debris in the screen on the washer hose connection. Make sure the hoses are not kinked and the valves are turned up all the way. Also check to see if you have those special flood proof hoses with the automatic water shut offs. I have had those not work properly many times.
May 18, 2011 | Washing Machines
04 yfz 450 wont start with electrical start
i have a 04 yfz 450 quad. the compression ratio like yours is extremely high. ive had my battery go bad and found that another battery other than factory would turn over the engine, but would not start. i paid the 100 dollars for the factory battery and it fired right up. because of the high compression you need a high cranking battery.
May 04, 2009 | 2004 Yamaha YZ 450 F
[[ACER WONT TURN ON]]
You might of fried the whole motherboard when it sparked. Check if there is a fuse. Bridge the gap, and it should turn on. If not PULL THE PLUG.its something else that went wrong.If you don't, it smells really bad. Ive learn't from experience...
Jul 28, 2008 | Acer TravelMate 2300 Notebook
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Cannon Powershot LCD Screen
If you can get a replacement screen (ebay from a broken camera with working LCD screen?), it's not too hard:
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Jan 02, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
K5 wont turn on
leave it 4 a while let it sleep then buy new 1 coz its spoilt saf
Nov 22, 2007 | Samsung YP-K5 MP3 Player
Washing Machines Logo
49 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
