Question about Mattel Pixel Chix Road Trippin' Vehicle
I can't program my dish 500 remote control to my pixel tv
Code for sony bravia
Hi there Gonzalez897! This is Kimberly with DISH and I ran across your post and would like to assist you. Some of the codes that can be used to program the DISH remote to a Sony Bravia tv would be: 500, 590, 640, and 781. Here is the link to our website, containing this information and also the steps on how to program the remote control to your tv.http://www.mydish.com/support/program-to-tv-code-non-basic I hope you find this helpful. If you need further assistance or have additional questions feel free to email me directly at kimberly.escobar@dish.com
Kimberly. Escobar
Social Media Representative
Mar 22, 2012 | DISH Network IR Remote Control
Programming my remote control (which is a dish network remote control) to operate my 42" sanyo LCD
In order to program the remote to a TV set, hold the clear "TV" button in the upper left hand corner four four seconds or until all four of the mode buttons light. Next press in one of the three digit codes below followed by pound (#) Remote codes: 590, 683, 720, 591, 543, 593, 813, 542, 533, 652, 726, 611, 500, 503, 627, 661, 956, 591, 694, 666, 252 After trying each code press the volume and power buttons, if they control your TV set be sure to press the "SAT" button.
Daniel Busa
DISH Network
Customer Service
Aug 28, 2011 | Sanyo 42 in. LCD TV
I have lost the code book. I know how to program it but have no ideas what the code is. The TV is a Sanyo and we have Dish Network for satellite. Any help would be appreciated.
Daniel Busa
DISH Network
Customer Service
Aug 28, 2011 | Philips SRU2103S-27 Remote Control
I'M INSTALLING A NEW REMOTE. IT CONTROLS THE SAT RECEIVER BUT NOT THE SONY TV. IT WILL NOT GIVE VOLUME CONTROL NOR TURN ON OR OFF THE TELEVISION. I'VE TRIED THE SONY CODES TO NO AVAIL. SUGGESTIONS?
rl_harris679
I have provided a link with instructions on how to program the new remote to your Sony TV. The link contains our different receivers. Select your receiver model, then a PDF document will open with the instructions for programming the remote to your TV. It begins with step 5. I hope this helps.
Programming the remote to TV:
http://www.dishnetwork.com/SupportSection/remote-setup
Sony TV codes: 500, 590, 000, 002, 073, 511, 514, 546, 550, 567, 578, 640, 670, 690, 758, 778
Ray Calo
DISH Network
Feb 19, 2011 | DISH Network IR Remote Control
What is the code for my hd 52786 jvc tv trying to program a dish network remote
Try these codes, the bold ones work the most often: 557, 558, 642, 559, 508, 649, 655, 667, 673, 676, 726, 735, 736, 737
If the codes don't work try the steps below:
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once. 3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network Customer Service
Feb 02, 2011 | JVC RM-C14G-1H Remote Control
White westinghouse tv code for remote control? And the procedure to program it.
pepelule
Here are the codes for your White Westinghouse TV: 719, 500, 659, 664, 670, 672, 674
I have also included the instructions for programming the remote to your TV. I hope this helps.
  • Remotes: Basic (Television Only)
    1. Turn the Television On
    2. Press and Hold the TV Power button for three seconds until the LED flashes
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press OK. Note: The LED will flash three times.
    5. Test functionality with the TV
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network
Oct 25, 2010 | DISH Network IR Remote Control
Programme remote to work with sony tv
To program your DISH Network remote to your Sony TV you will simply- press and hold the TV Mode button until all the other mode button back lights illuminate, then release.
-Now while the TV mode button is blinking please enter in the remote code 500 which is the remote code for your Sony TV after entering 500 then press the pound (#) key.
-After pressing the # key on the DISH Network remote, the TV mode button should blink 3 times and then turn off completely. This will mean the programming of the DISH remote to your TV has been completed successfully. While still in TV mode try any of the functions on the remote, such as turning the volume up or down on your TV or attempting to press the power button.
-The DISH Network remote should now be programmed to control your TV.
-If the remote code 500 doesn't program the DISH Network remote successfully you can also try each of the following using the same procedures, 000, 590, 640, 502, 002, or 567.
I hope this resolved the issue for you! Please feel free to contact us if you need any additional assistance.
-Kirstie DISH Network
Sep 16, 2010 | DISH Network IR Remote Control
Control code
leoidalgo
I have provided the remote codes for your Zenith TV. I have also provided a link with instructions on how to program the remote to the TV. I hope this helps.
Remote codes: 501, 652, 766, 500
Program remote, step 6:
Ray Calo
DISH Network
Jan 06, 2010 | DISH Network 142923 Remote Control
What are the codes for the dish 103602 satellite?
The codes depend on which device your are trying to program your remote to. you can get this list at www.dishnetwork.com/tech. when you get your 3 digit code. For instance you have a sony Tv, the code is 500, Press an hold the clear tv button at the top of the remote till all mode buttons light up, then release, then enter 500 then the # key and your remote will now work your Sony tv. If you still cant find the codes repost with brand of equipment you want top program.
Nov 29, 2009 | DISH Network IR Remote Control
Set t.v /remote to work with other components
Do you have a Sanyo Universal Remote ? If not, you program your dish 500 remote for these.
Sep 16, 2009 | Sanyo DS31590 31" TV
Mattel Pixel Chix Road Trippin' Vehicle Logo
62 people viewed this question
Top Mattel Toys Experts
thegtw
Nikki  Mclean
Nikki Mclean
ray gallant
Are you a Mattel Toy Expert? Answer questions, earn points and help others
