Question about APC SURT1000XLI 1000VA 700W 230V UPS (SURT10000XLI) UPS System
What is the minimum battery voltage required by this UPS i.e. 12 volts or 24 volts?
  • APC Master
  • 15,973 Answers
12 volt 7.5 a/h spec shows rbc-31
Posted on Apr 18, 2015
What voltage should come out of a 24 v 3 pin charger? single 12 v pin with two ground pins?
It depends on how it and the wheelchair are wired and how the voltage is derived.
Presumably the 24 volt wheelchair requirement is provided by two 12 volt batteries connected in series and these could be recharged in series by a 24 volt charger and a pair of wires or by a 12 volt charger providing a 12 - 0 - 12 using three wires where one 12 is a positive in relation to the 0 and the other is a negative in relation to the zero making a potential difference of 24 volts.
There could conceivably be circuitry within the wheelchair that requires only 12 volts for recharging and causes the two batteries to be charged separately, though while this method could be desirable and offer some benefits it would be considered unnecessarily expensive and complicated for most commercial purposes.
As usual you really need to know what is supposed to happen or is designed to happen before fault-finding can begin. One of the wires could be a safety ground wire but most likely it is used to provide some sort of feedback to the charger from, perhaps, a thermal switch close to the batteries so charging will cease if too much heat is generated.
Nov 02, 2015 | Pride Jazzy 1113 ATS Indoor Power...
My ups has failured only giving an alarm indicating that batdisconnected
Check the connections on the batteries. One or more may be loose or corroded. Also check the fuse for the batteries. It may have blown.
Sep 25, 2014 | Powerware 9120 UPS System
Kohler cv15s
Your battery may bad. Unhook it,check voltage, charge it 24 hours. Check voltage, should about 12 volts. Let set 24 hours, check voltage , if not 12 volts, no good.
Aug 20, 2013 | Craftsman Garden
20,000 watts capacitor meter reading 13.9 with 2 battery & 250 alternator
Hello! The required voltage is 24 volts...which means two 12 volt batteries connected in series...It sounds as if you have two 12 volt batteries connected in parallel...Which doubles the amps and leaves the voltage at 12 volts...Connect the negative of one battery to the positive of the second battery...Then from the positive of battery #1 to the negative of battery #2 is the required 24 volts for the Kole...Guru...saailer
Jan 17, 2012 | Kole audio 20 Farad Digital Car Capacitor...
How do you check the battery status?
Check battery voltage using Volt meter=> it should be about 12.6 to 13.8 vdc.
Pull the battery out... checking the deforming at the case ..such as "swelling"... if yes .. replace the battery.
Replacement battery is about 10-20 dollars on e-bay (watch for shipping charge and size. and terminal connection sizes )
The average life of battery on UPS is about 5-7-10 years wi)th UPS plugged in (Charging
One I had my local Autozone checked my 12 VDC -8 AH ... ask them to set CCA at about 100 AMP...
for 12 VDC -14 AH ask them to set CCA about 200 AMP.
For a 12 VDC -75 AH (group 24) they set the load on their tester at about 700-900 CCA.
You can also buy a manual battery load test at Harror freigt tool for about $20 US dollars (On sale)
Feb 18, 2011 | APC Back-UPS ES 350 - UPS ( external ) -...
My apc ups do not charge batteries it is su 3000 working wel but do not charge batteries
Your battery lifespan is probably over, (3-5 Years) or the battery could have a dead cell in it, my suggestion is to replace the battery. it should be a 12 volt 7 amp hr battery or a 24 volt pack that you will have to get from the manufacturer
Oct 22, 2009 | APC Smart-UPS® UPS System
Want to replace batteries in my ups
APC BX1000 UPS.
First analyse with local UPS service engineer to find out the problem is related with UPS.
It requires 12 Volts batteries for this UPS Usage.
The batteries required are 2 Numbers.
Buy these batteries from authorized APC Vendors and these batteries are having 1 year warranty.
In case of any problem, these batteries will be replaced at free of cost.
To close this solution, please get in touch with Authrzed UPS Service Engineer.
Jul 11, 2009 | APC BX 1000 Back-UPS XS 1000 (APNBX1000)...
Battery voltage not known for UPS-DELTEC PRR 2200i
It uses 4x12v @ 26AH batteries in series, making a total of 48v (more like 52v if charged).
Jan 19, 2009 | Compaq UPS T2200 XR UPS System
I have a UPS DELTEC, Model PRR 2200i. I want to know the battery voltage, is it 24 volt or 48 volt?
Sir, just open the ups, and you can see the battery inside. after you open, pull out the battery, then look for the voltage rating, it is located on the battery itself
Good luck,
UPS 1800VA
You can increase the capacity of the batteries from the original equipment, but you cannot put more load onto the UPS. Your runtime may be increased, but you may have trouble fitting the car batteries into the case. Some UPS's have external connectors for external battery packs. Find one of those and add the batteries to it. Make sure that you maintain the DC voltage which the UPS requires. It may be 12 volts or 24volts. Two 12 volt batteries in Series.
Oct 16, 2006 | HP (A2997A#002#017) UPS System
APC SURT1000XLI 1000VA 700W 230V UPS (SURT10000XLI) UPS System Logo
276 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
