Question about Tools & Hardware - Others
Has just been repaired. New piston and pin. Stapler won't work. Pin comes down but does not go back. Not putting a staple in.
  • 2,827 Answers
I would take it back to the person that repaired it.
Posted on Apr 18, 2015
Help please! I have a Paper Pro high capacity stapler that will not staple. I can open it up and put staples inside, but no staple will come out when pushed down. Oddly enough, if I put ONE staple inside...
are you using the correct size of staple?? (thickness wise) secondly check the spring is pushing as it should, also a fix to get it working is as you put the staple stack into the stapler, seperate them and see if will staple. other than that it's defective and you should purchase a new one.
Oct 30, 2013 | Staples PaperPro 1200: Heavy Duty Stapler
The staples won't go fully into the Wood
1. The wood may be too hard for the staples to penetrate
2. The stapler drive spring may have ghotten weak
3. You may not be holding the stapler nose firmly against the wood while stapling
Jan 06, 2013 | Stanley TR250 H Heavy Duty Heavy Duty...
Pneumatic stapler trigger stuck
The click sound indicates that the headvalve opened to fire piston down the barrel, however piston is already down or is stuck in-place. If the piston/driver is not broken or stuck, push piston to top of cylinder to reset. If only one shot and piston stays down, most likely the check band is broken. Check band is on the outside of cylinder (lower part) is is usually an oring or band of rubber covering small holes drilled into cylinder. Check valve /band is what causes the piston to return to top. If check band is good, most likely piston is bent or oring is too tight. If you open the gun, lube all parts with white grease or silicone paste lube. Good luck
Nov 03, 2012 | Air Tools & Compressors
Staple jams by driver blade in gun and I have to dismantle nose to get it out. Empire Rainco 7-16.
The problem is wear on the sides of the driver blade. With the constant up/down movement of the driver against either side of the nose plate, it eventually narrows enough to allow part of the fine wire 71 series staple to find it's way between the driver blade and the inside wall of the nose plate. A new driver blade cures this completely. Rainco tackers have become a bit rare but the good news is, they're actually manufactured by Fasco and the Fasco driver fits into the Rainco piston by the removal of a single pin to allow the old blade out, replace with the new Fasco blade, re-insert the pin into the piston, then re-assemble the gun and you're away.
Mar 06, 2011 | Nailers Empire Rainco R16 Stapler Driver...
I HAVE A SWINGLINE STAPLER AND IT JUST STOPED WORKING CAN YOU HELP ME TO FIX IT THANKS
When a stapler stops working it is because it has jammed.Try to open it by pulling on the silver bottom part while holding the top black part there is a release on the bottom.Press the release at the back and unload staples.You should see jammed staple in feed,clear it them.Reload with new **** of staples.It should now function.Use a pin or paper clip to clear pull out jammed staples.
Jan 04, 2011 | Office Equipment & Supplies
I need to put in new staples. How do I do it?
This stapler does not swing open like a paper stapler. It has a little square metal piece at its heel (about the size of a postage stamp). Press in lightly on this metal piece as you move it up or down just a bit, to unhook it. Then pull out the piston and spring assembly, insert staples in the hole and replace the piston. You must use T50 staples (of various lengths). T35 and others will not fit. Good luck, Al K
Sep 01, 2010 | Arrow T50P ARROW STAPLE GUN
Cant get staples into it!!!
Sue, First, confirm that you have the right size staples. They are sized in two dimensions - width and length. The most common width sizes are T50 and T35. Your stapler and your pack of staples should have a number such as this. Your stapler will accept staples only of the correct width but of various lengths. The lengths are given in fractional inches - 3/8 inch and 1/2 inch are common.
But perhaps your problem is how to open the stapler. It does not swing open like a stapler you would use for papers. Instead, it has a sort of spring piston that has to be removed from the back-end of the stapler. If you lay the stapler down flat on the table so that the hinge of the handle is at the upper left corner, then what I am calling the back-end of the stapler is the lower right corner. Pick up the stapler so that you are looked directly at this back-end. There is a small metal square at this corner that is spring-loaded and is held in place by a little hook. Push in on this metal square as you move it up (or is it down?) to disengage the hook. Now the piston will pull out easily. Put your staples in the hole (they will only go in one way) and replace the piston. I hope you found this helpful Good luck!
Aug 19, 2010 | Arrow CHROME STAPLE GUN ARROW IND....
Setting staples too deep
The depth is set by the bumper and the bumper spacer. Are you sure these were put back in? the air pressure only makes a small difference on the depth...
Mar 11, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
Senco staple fastener not firing.
Make sure you actually removed the entire broken staple and there's not a piece still wedged up in there somehow.
Try raising the air pressure up to 125 psi and plug it in and unplug it a few times. Sometimes the piston can get jammed, and a smack with the palm of your hand on the side of the cylinder will jar it loose. If that doesn't work, try pulling the trigger as you jam the nose of the gun against a soft piece of 2x4 or something, repeatedly firing and jarring the tool. If this doesn't do it, you may have to open it up to clear the jam and put it back together.
Mar 28, 2009 | Senco Fastening Systems 760102N Pro 25 Xp...
Driving pin won't reset
The check valve is what causes the pin/driver to return to top of cylinder. To check if it is in place, remove the cylinder from the gun and look for an oring/band installed on a groove. This groove should have vent holes drilled thru the cyl. Holes should be clean. Any oring or rubber band can be used here. Just tight enough to stay in place. Other things to check:
Pin/driver should fit snuglly enough to hold it's own weight in cylinder. If your gun uses a plastic ring, it may be replaced with a rubber oring. Just make sure that the piston travels freely but holds its wieght.
There should be a bumper and a washer in the lower part of the gun. The bumper should not have any cuts or missing pieces and the washer should fit snuggly around the driver blade to prevent air from leaking down thru bottom of gun. If air is leaking down thru bottom, there is less pressure to push driver up. Email if you have more questions, good luck with your repair.
Feb 21, 2009 | Campbell Hausfeld 2" 18GA Brad Nailer
Tools & Hardware - Others Logo
43 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
