I have a Bonaire split aircondition & heating system. When I use remote controll change mode doesn't work heating mode. Other mode are working properly but heating mode doesn't work.
    Top Expert:
  • 42,740 Answers
Check the ambient temperature as there is most probably a lock out feature that will not allow reverse cycle to work if the system cannot remove the cold from the evaporator
To understand the system , when in cool mode the outside unit is called the condenser and in effect removes the heat trapped by the evaporating gas in the evaporator to the atmosphere
in the heating mode the roles of the evaporator and the condenser are reversed so that the evaporation of the gas in the now evaporator out side is now compressed in the inside unit and the heat from that compression action is released into the room
read the manual for the unit or talk to an ac specialist and have it explained
Posted on Apr 18, 2015
Remote control malfuction
04Feb14
In some states and provinces of Canada, the Lloyds 'remote' CANNOT be programmed into cable vision providers!!!!!!!!!!
One provider 'Shaw Cable' has never heard of Lloyds.
What's up with this.....having to use Lloyds remote to adjust volume and mute, while using Shaw's remote to channel change.
That's just awful. Archie Bunker has it bedda.
Feb 04, 2014 | Klimaire Universal Mini Split Remote...
Hi, I have a Daewoo air conditioner split (model dsb-070L/dsb-091L/dsb-070LH/dsb-091LH, I'm not sure about the exact model number). The remote is not working anymore, and I don't know why;...
Hi Josematamoro
Did you find a solution to your problem. I have the same problem and not sure what to do. I have contacted a airconditioning maintenance person who said he would try and look for the part to fix it.
Cheryl
Jul 31, 2011 | Heating & Cooling
I have a Vulcan Bonaire ducted heating system with Comfort Control in a holiday house, installed in 2006. It was working fine last time we used it about a month ago. Today every time I try to turn the...
hi,
The heating coil itself have some problem that's why the circuit breaker clicks off by sensing over current drop. Check the heating coil and replace it.
ok
Jun 11, 2011 | Heating & Cooling
Hi I have a starway split system air conditioner and the remote is no longer working - I have purchased an Ultra Univrsal Remote and need to know the code to make it compatible with the starway air...
In my experience, the related remote is better than universal remote, as it's not designed for particular unit, but for multi.
Anyhow, take universal remote, power on your a/c.In front of your a/c, press setting and then < or > continuously. In your remote the number will go up or down as 999.........998.997......... or 1101...102........103...104. like that. Stop, when you get response by beep sounds.That is code for your a/c to operate. Helpful?
Dec 30, 2010 | Heating & Cooling
Hi i have recently purchased an amcor sPLIT UNIT AND CAN NOT GET THE HEAT TO WORK AND DO YOU HAVER ANY SUGGESTIONS AND PRESUME IT IS A SETTING i AM NOT CORRECTLY PRESSING ? rEGARDS cRAIG
dear sir
please first make turn on your electrical supply for air con
and then use remote controller and find out there heat mode and select it then make your air con on heat mode ..
i hope it will work on heat mode
hope answer the question
thank you
please vote!
Sep 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
5mint cooling 5minuts heating
The reverse valve and silenoied are bad, you need to change them or replace the condencer.
May 04, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Air con stuck on cooling mode!
Is this a Mini Split Ductless type Heat pump? Has it worked in the heat mode for you before? Have you tried killing and reapplying power to both the indoor and out door sections? Does it have a wireless remote? Are the batteries new in it?
I have to assume a lot because there is a lot of information missing to really know how to help you.
If these items helped would you please grade me accordingly. Thank you and GOOD LUCK.
Mar 03, 2009 | Panasonic Heating & Cooling
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
