Question about Refrigerators
Water supply weak before changing filter. Pressed desert filter button. Held on for over 3 minutes. Water comes out but weak pressure. The refrigerator has been in place for atleast 2 years.
    Genius:
  • 1,585 Answers
Most mechs have gause filter up inside inlet valves check them remove with pointy pliers and clean
Posted on Apr 18, 2015
Samsung fridge #rf260beaes/aa iceemaker stopped working. I changed filter and hit reset and still not working
Hello Gary Traver,
Page 13 of the USA model... (similar)
shows the steps to follow to RESET the water
after a FILTER CHANGE...
by... Pressing the "FRIG" & "POWER Cool" buttons
simultaneously for 3 seconds.
It is also possible the water line was kinked or the water turned of...
The instructions say t turn off the WATER before
starting the process (
I would rather not move
the refrigerator... so that step always gets SKIPPIED)...
(sometimes high pressure makes it difficult to get the
filter BACK IN... and the solution is to SHUT the water
supply off... (ergo the need to check that).
Not seen in these instructions...
running the water through the new filter... (to clarify)..
((my water looks pretty yucky coming out of a new filter.
5 seconds... 5 second... (intervals... for 2 minutes)..
May be... the USA instructions I found here are
CLOSE ENOUGH )...
http://www.searspartsdirect.com/partsdirect/user-manuals/rf260beaespaa0001-samsung-parts-manual?manualIndex=0
Hope it helps...
Carnac the Magnificent
Jul 27, 2017 | Samsung Refrigerators
I have an american style hotpoint fridge freezer MSZ902DF which has had a water filter change as blue light on but despite following process the light has now turned to orange. Can anyone advise what we...
Refrigerator - Water Filter Indicator Light Will Not Shut Off After you change the filter the RESET WATER FILTER must be pressed and held until the red light goes off.
Note: If you do not hold the pad in, the light will stay on. Also, if you hold the pad in for a long period of time, the light will go off and then come back on.
If this does not turn the light off, having it checked by a service technician is recommended
Here is a list of refrigerator manufacturers and how to reset the filter change indicator light:
Amana- Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire- Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric- Press and Hold the Reset Button for around 8 Seconds.
HotPoint- Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air- Press and Hold The Water and Lock Buttons until the Water Filter light flashes.
Kitchen Aid- Press and Release the Light Button 5 times Quickly.
Maytag- Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung- Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool- Press and Release the Light Button 5 times Quickly.
Mar 04, 2015 | Hotpoint Refrigerators
Maytag refrigerator MFI2568AES. "Change Filter" light will not turn off. Held down filter reset for 3 seconds - did not work. Held down the light and lock buttons for 3 seconds - did not work. Wha
Hello Don;
My name is Peter. I am a retired field service refrigeration technician.
Your filter reset is just a independent timer set for six months. It is not tied into your water filter. You should change your water filter when your water dispenser flow is slow and/or you start to get small ice cubes. Depending on the usage, your water filter can last 18-24 months or more.
Unplug your unit for about 10 minutes to let the unit power down, then plug it back in.
Dec 31, 2014 | Maytag Refrigerators
After installing a new mwf filter no water comes out of the dispenser. It worked before changing the filter. With the filter bypass plug installed - still no water. I held the dispenser for more than 3...
the inlet valve has jammed shut & needs to be replaced it's just coincedence that it happened when you changed the filter unless the taps turned off it has to be a faulty inlet valve.
Feb 18, 2011 | GE 3 Ge Mwf Smartwater Water Filter Fits...
The water won't come out of the fridge when the button is pressed. I thought it was because I needed a new filter but that's not it I changed filter the fridge is making ice fine, but no water from the...
most likely the water line that supplies water inside the freezer door has frozen up blocking the dispenser. try leaving the freezer door open for 5-10 minutes and allow the line to thaw out.
Jul 04, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Gaggia Evolution Filtering Weak Coffee
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Jan 03, 2009 | Gaggia Evolution Espresso Machine
WEAK COFFEE & NOT HOT ENOUGH
Dec 22, 2008 | Bunn NHB Coffee Maker
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Weak Coffee
Mar 02, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
