Question about Pool & Spa
I am looking for a replacement part the adaptor thst is on the pump has switch nob to direct the water flow. Can that be replaced and if so what is the patt #.
  • 1,631 Answers
Cannot even guess as to what you are talking about?
I do not know of any pumps, that have a valve of some sort on it, to direct water flow? What is the make and model of the part/pump that you are needing a part for. Is this a pump, a filter, or ???
Posted on Apr 21, 2015
Little giant pool pump cover will not work
auto switch is defective? a simple easy replacement can be sourced from any pool supply co
Jan 18, 2014 | Little Giant Pool Cover Pump Water Wizard...
Defrost selector turns but does not change where the air is flowing
Sounds like the switch nob itself is wore out. you may need to replace that assembly, not just the nob but that cluster that has the nobbs on it. good luck
Dec 07, 2013 | 1996 Geo Prizm
Hoshizaki Model KM500MAH
When first turned on, the sump should fill with water. If it does, water solenoid is good. If you have a full sump, and no water pump running, sometimes the "Ice/Off/Wash" switch is bad. Put switch in wash, if pump runs, it's good. Now put in Ice position, if sump fills and pump does not come on and compressor indicates it is in the freeze cycle, replace that switch first. Simplest place to start and lest costly to fix.
Oct 04, 2017 | Hoshizaki Freezers
Air delivery mode control not changing air flow 2009 Pontiac torrent
Need more information to help solve this problem.
You mean speed of air flow or direction of air flow?
-If direction of air flow no change that mean:
1. Cable from the knob to control door is slip off or if the system is control by vacum. The vacum line is leak or slip off.
-If the peed stay same even move the switch to hight or low:
1. Bad switch.
Mai Lor
Feb 22, 2013 | 2009 Pontiac Torrent
Water dispensor is not working. ice maker does work. new filter
If the filter is the only change made.. look at the new filter.. are all the 'seals' etc removed? so water can flow through it? is it installed in the proper direction? .. .. or did you replace the filter because no water was flowing? If that is the case.. and the filter is installed correctly.. something is blocking water flow.. maybe a frozen water line or clogged water line follow the water line from the dispenser end in the door, back to it's source. If the line is white- try to run a thin wire into it to see if it is clogged if it is clear, look for a blockage. If no blockage.. then it is blocked in the 'pump' or valve area or the pump/valve for the water dispenser is bad. there is some kind of lever to tell the water to flow when you put a glass under spigot.. check that- to see if it is stuck ( my ref door light switch likes to get stuck) .. good luck.
Dec 26, 2010 | Samsung RFG297AARS (285 cu ft) Bottom...
Salt water pool cell shows no flow but there is no visible obrstuction in the cell
This could be many things but the first one to check would be the flow switch. This could be salt or calcium build up on the probes. You will need to carefully unscrew the switch so you don't bend the probes. If they are clean, plug the hole in the pipe that you removed it from and turn the system on. Then press the probes together and see if it shows flow. Clean or replace as necessary. When you reinstall, find the arrow on the probe and be sure it points in the direction of the water flow when finished installing.
Oct 02, 2010 | Intex Automatic Salt Water System for ...
Subaru Liberty 1990 2.2 gxawd started overheating due to leaking pump.Replaced pump and thermo.Now sits on normal but rises up hot and drops back down again.This happens about every two minutes in a...
Two possibilities 1: wrong water pump (serpentine belts run water pump in the opposite direction as V belts).So make sure you have the right one. Check box that pump was in and or check at the store you bought it at, Look over the shoulder of counter person and look at computer screen yourself. 2: thermostat put in up-side down,copper nob and spring of stat should be inside of engine so that you can not see it.
Jan 13, 2010 | 1990 Subaru Legacy
No water flow though pool pump
Check and see if all valves are turned in the appropriate positions. Sometimes homeowners forget to switch the valves from spa mode to pool mode or vice versa and wonder 'why isn't my pump pushing water?'. Another thing to consider is what type of pump you have. If you have an owners manual, check and see if you have a flooded suction pump or if it's self priming. You may need to dump water into the trap before seeing water flow through. You may also have faulty valves or check valves. Check your filter and make sure all positioning of valves are in proper place. If all else fails...call a pool professional. These small self performing tips are just something to consider to save some money in the long run in lieu of calling someone that may poke your eyes out with a service call and something as trivial as turning a valve. Hope this helps!
Sep 09, 2008 | Water Pik Flow Valve Assy. Series II...
Pool & Spa Logo
141 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
