Question about Kenmore Washing Machines
Replaced the heat coil on the dryer of a Kenmore washer/dry stack #417.97802791. Now the washer will not operate. Any ideas?
    Genius:
  • Kenmore Master
  • 1,585 Answers
Make sure the dryer hasnot snaged any wires on mech
Posted on Apr 18, 2015
rickzilla
  • 706 Answers
SOURCE: Maytag haevy duty stack washer dryer unit model # SE1000 series 06
I hope you got this fixed by now but if not I'll put in my 2 cents.. I assume that your dryer is electric and not gas. Assuming that is true then you probably have an open heater element.. similar to this used in electric stoves... There may also be other components that could have failed and in so doing, disabled power to that element. Could be a contactor or temp switch/thermistor.. Hope this helps and that you've already solved the problem...
Posted on Jul 25, 2008
SOURCE: Dryer won't spin on my kenmore stacked model 417.90812991
This is the 2nd time I have this problem.
IF you look thry the drum to the back you should see 3 screw heads. Mine has one screw still in the hole and 2 empty holes.
This requires the drum to be removed (like take the drier apart). Behind the drum is Asmbly-shaft (ball hitch) (item 32 in the parts list). This what the 3 screws screw into.
I spent 2 days trying to put the screws in without removing the drum not possible (no way to hold the drum in place)
The first time I had to replace the drum because it wore the rim through.
I have to get 3 new screws and some thread locker.
I recommend that you check the screws every month, Use a long phillips screw drive
Posted on Mar 05, 2009
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
  • 1937 Answers
SOURCE: The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Posted on Oct 27, 2009
blueextc3221
  • 15935 Answers
SOURCE: Water leak from washer
The element is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Dryer not heating
Check Heating elements if ok check the in line fuse that go to drying element and if it open replace it and clean filter and check pipe that blow out side make sure it not stop up because if in line fuse is open stop up filter and pipe that blow air out side will cause the heating element in fuse to open up. And check for lose wire going to element to.
May 30, 2014 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 24
What is the model number of your unit?
Nov 17, 2012 | Kenmore 98702 Stacked Washer/Dryer
Auto dry not working on stack washer/dryer
If your dryer isn't drying, check for a simple fix first. Make sure the dryer is set on a high heat setting, empty the lint filter, and reduce the size of the load by taking out some items.
Also, check to make sure the clothes are not dripping when you put them in the dryer and make sure a dryer sheet is not blocking the vent.
It could also be a problem with your dryer not being level or the vent hose is clogged. For more tips and solutions, check out these troubleshooting steps in Dryer not drying.
Sep 12, 2012 | Kenmore 98702 Stacked Washer/Dryer
Dryer heats up, but does not dry clothes. Vent is clean
As you can see, your heating element has 5 heating coils. If one or more of these coils have opened you dryer will still work and heat but not at well as it would if all coils worked together. You can check each coil with an ohm meter to verify if one or more is open.
Jan 01, 2012 | Kenmore 64742 Electric Dryer
Free standing kenmore dryer series 90 floor model not stacked not drying
Could be the heating eliment..
A way to check it ---
remove the exaust hose..
Put a mirror to the exaust hole trying to see inside to the eliment(s)..
When running - the eliment should glow hot..
If its not - it migt need to be replaced..
Hope this helps !!
rate me good ;o)
Jul 13, 2009 | Kenmore 98702 Stacked Washer/Dryer
Mar 16, 2009 | Kenmore 98702 Stacked Washer/Dryer
Gas smell from dryer
your igniter needs to be replaced.
Jan 26, 2007 | Kenmore 74842 Gas Dryer
Washing Machines Logo
41 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
