Question about Samsung Televison & Video
Hi, I have a samsung flat panel tv model UN29F4000, has sound and looks like no picture but if looked at in the dark you can see a faint image. Powersupply board changed with same results. Thanks
No sound, faint image noticed in a dark room, in a lighted room the screen looks black
    Top Expert:
  • Samsung Master
  • 74,243 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Posted on Apr 18, 2015
    Top Expert:
  • Samsung Master
  • 6,702 Answers
Looks like the back lights are not working. The older TV sets had fluorescent tubes, the newer have LED's voor back lighting. I would look there, or visit a repair shop. Or when the TV is old, start saving up for a new one.
I have sound but no picture
Do the flash light test----with set on in a very dark room with the light directed at the screen do you see a faint image or not?
Dec 23, 2012 | Sanyo 42 in. LCD TV
Can the lamp be replaced for a Polaroid TLX03210B
You likely have a LCD set there which may likely use a back light inside to light the image, get the room as dark as you can and with a flashlight illuminate the screen from a angle, with set on if you can see the faint image on the screen of the program you have a Backlight issue'
1. Voltage not there or not being switched on for backlight.
2. Actual back light bad.
If the image can be seen with a flashlight one of the above is the issue and your "picture will appear very faintly" also suggests this.
Dec 18, 2012 | Polaroid Televison & Video
Black screen
If its LCD get the room very very dark and turn on--with a flashlight near the screen look closely at the screen to see if you see a very faint image of the picture or not---Most LCD flatscreen's (not Plasma) use what is called a back light to light the screen--light source.
If a faint picture can be seen that way the light is not on.
Dec 17, 2012 | Sceptre Televison & Video
Gpx 32 inch lcd hdtv has sound but no picture
In a very dark room with set on use a flashlight at the screen--if you see a very faint image of the program it may be the back light this set uses for brightness on the screen.
Dec 13, 2012 | Televison & Video
I have a Protron LCD 26" TV model#LT26CIPI...The tv was working great turned it off on night and in the morning turned it back on to sound but no picture just a Black screen...when you change channels
Since its a LCD take a flashlight and have the room as dark as possible and with the light look to see if a very very faint image of the picture can be seen or not---many of these sets use a "back light" for the brightness and if that's not on.......
Dec 11, 2012 | Protron PD-DVR100 DVD Recorder
After i power my polaroid tv on the screen shows for about 3 seconds then goes black what causes that
Its a Lcd so if it stays on turn off all the lights (we want a dark room) and with flashlight look carefully at the screen to see if you see a faint image of a picture there or not.
Dec 06, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
The lights are on, but picture won't come on.
A suggestion: if you have sound look at the screen with set on in a dark room with a flashlight---do you see a very faint image or not?
If no sound or brightness but indicator lights are on suspect another issue--possible power supply board is bad.
Nov 07, 2012 | Emerson 22" Class LCD 720p 60Hz HDTV,...
Picture for about 30 seconds but has sound. TW-5592W82003990
I would first take a look at the screen with set on in a very dark room with a flashlight---do you see a very faint image or picture? That would indicate a back light issue-----Good luck getting a board, I hear the company is again out of business.
Nov 05, 2012 | Westinghouse 32" Flat Screen Lcd Hdtv,...
Sony bravia black screen audio ok
It is a LCD set and if sound get it in a very dark room and with a flashlight and the set on look to see if you see a very faint image on the screen.
Almost all these sets use a back light system for brightness---an inverter of some type to power the lights---either the back light is bad or the voltage for it is not present or being turned on.
Nov 05, 2012 | Sony BRAVIA KDL-52XBR3 Television
Screen black still has sound
Try in a very dark room with set on to look close at screen and or use a flashlight to see if faint images can be seen or not......
Oct 30, 2012 | Proscan 47 in. Diagonal Class LCD Full HD...
Televison & Video Logo
169 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
