Question about Tetra Pond Bp4000-uv Koi Pond Bead Pressure Filter W Uv
Filter works fine, except one side where it clamps down is leaking. Other than that it works great and I don't want to replace it. Any ideas?
  • 16,194 Answers
Is there a gasket or o-ring that is damaged or bad? IF not you can run a bead of silicon around it where the surfaces join and let it dry before you put it together. This would make a gasket.
Posted on Apr 18, 2015
Fuel leak after changing fuel filter
Is the leaking at the fuel filter, or somewhere else?
Did you replace the rubber hoses on both sides of the filter? If not, check to see if they broke when you pulled old filter, replace any that did.
Did any old rubber stick to the metal pipes, when you pulled out the old hoses? That can keep new hoses from sealing, even with good torque on hose clamps.
Make sure your hose clamps are tightened properly, with some bulging rubber at the openings in the clamp, but not cutting the rubber into ribbons. It is possible to over-tighten hose clamps, and shred hose rubber. If you see ribbons of hose rubber sticking up out of the metal clamp you have done that. Replace the hose, and the clamps, and make sure the metal pipe is clean, before you carefully tighten the clamps.
Aug 07, 2013 | 2007 Dodge Sprinter
Hoover optima washing machine is leaking very badly . I have stripped the machine down and cannot find the leak . Inlet pipes clear. Cleaned soap drawer and two feeder rubber pipes don't seem to be a...
Hi,maybe the draw dispencer is damaged,I wouldnt think it is the drum seal,what I would do is tilt the washing machine so that the top of the machine is leaning against the wall so that the front of the machine is of the ground,then while you get underneath the front on the floor with a torch get someone to put water in the dispencer and see if you can see where the water is leaking from,I hope this was some help,all the best.
Mar 21, 2017 | Washing Machines
Where is the fuel filter location for a 1996 crown victoria
It's front of the driver's rear tire,usually.If not,it'll be on the other side of the car.
Turn off the key and remove.
Open hood and release fuel pressure at the rail with the schrader type valve.
Don't use a bulb type trouble light under there as it can ignite gas easily.
Pry off the old clips after loosening the hold-down clamp. Turn head away as you slide off the hose on the tank side of filter.
Install new filter in holder,attach hoses and install new clips then tighten hold-down clamp. (:^)
don-ohio
Oct 25, 2011 | 1996 Ford Crown Victoria
How do i change the fuel filter for a 2000 blazer. i try to do my own work. I did the diagnostic test at Auto Zone and the two codes that came up were PO 171 and PO 174. The truck does not acclerate good...
Hi, I have pasted instructions for replacing the fuel filter below, but that may not be the problem. A lot of things can cause those trouble codes. I recommend you also clean your MAF sensor and check for vacuum leaks. Check all hoses attached to the intake manifold for cracks--especially the big air inlet hose. The MAF is accessible from the air filter housing. Remove the air filter and look into the big pipe toward the engine. The sensor sticks down into the airstream. Use a spray can of electric parts cleaner to spray the sensor several times. Do you touch or wipe the sensor. Please let me know if you have more questions, and thanks for using FixYa.
1. The filter is in front of the fuel tank on the right side.
  1. Properly relieve the fuel system pressure.
  2. Remove or disconnect the following:
    Negative battery cable and fuel filler cap, if not already done
  3. Raise and support the vehicle.
    Fuel tank shield, if equipped Quick connect fittings from the filter Filter feed nut and the clamp bolt Filter and the clamp from the filter
To install:
  1. Install or connect the following:
    NOTE The filter has an arrow (fuel flow direction) on the side of the case, be sure to install it correctly in the system, the with arrow facing away from the fuel tank.
    Filter and clamp with the directional arrow facing away from the fuel tank, toward the throttle body
    Tighten the fuel feed nut Tighten the filter clamp assembly bolt Fuel quick disconnect fittings to the filter Fuel tank shield, if equipped Fuel filler cap Negative battery cable
  2. Start the engine and check for leaks.
May 08, 2011 | 2000 Chevrolet Blazer
WHERE IS THE FUEL FILTER ON A 88 NISSAN PATHFINDER
Fuel Filter REMOVAL & INSTALLATION CAUTION
NEVER SMOKE WHEN WORKING AROUND OR NEAR GASOLINE! MAKE SURE THAT THERE IS NO ACTIVE IGNITION SOURCE NEAR YOUR WORK AREA! 1970-83 Carbureted Engines The fuel filter is located on the right inner fender in the engine compartment. It is a disposable cartridge type.
  1. Using a pair of pliers, expand the hose clamp on one side of the filter, and slide the clamp further down the hose, past the point to which the filter pipe extends. Remove the other clamp in the same manner.
  2. Grasp the hoses near the ends and twist them gently to pull them free from the filter pipes.
  3. Pull the filter from the clip and discard.
  4. Install the new filter into the clip. Push the hoses onto the filter pipes, and slide the clamps back into position. Start the engine and check for leaks. Fig. 1: Fuel filter - 1970-79 85851035.gif
    Fig. 2: Fuel filter - 1980-83 85851036.gif
1984-86 Carbureted Engines The fuel filter is located on the inside of the frame above the left rear spring front shackle. Changing the filter is VERY awkward. Since it is in-line and below tank level, fuel will pour from the fuel lines when they are disconnected from the filter. The only way of preventing this, is to siphon all of the gasoline from the tank before replacing the filter. Another possible method is to clamp and plug the fuel line, but this is not recommended because of the danger of leaking fuel or damage which could occur to the fuel line when clamped. It would, therefore, be a good idea to run the tank almost dry before changing the filter. Once the tank is dry, disconnect the fuel lines at the filter, unbolt the old filter and install a new one. Reconnect the fuel lines, fill the tank, start the engine and check for leaks. Fig. 3: Fuel filter - 1984-86 85851037.gif
Fig. 4: Remove the shield mounting bolts 85851162.jpg
Fig. 5: Remove the shield, if necessary for fuel filter removal 85851163.jpg
Fig. 6: Removing fuel filter - always replace fuel line clamps 85851164.jpg
Fuel Injected Engines WARNING
Never attempt to remove the fuel filter without first relieving the fuel system pressure!
  1. Release the fuel pressure from the fuel line as follows:
    1. Remove the fuel pump fuse at the fuse box.
    2. Start the engine.
    3. After the engine stalls, crank the engine two or three times to make sure that the fuel pressure is released.
    4. Turn the ignition switch OFF and reinstall the fuel pump fuse.
  2. Loosen the hose clamps at the fuel inlet and outlet lines then slide each line off the filter nipples.
  3. Remove the fuel filter.
  4. Replace the fuel filter. Always be sure to use new hose clamps. Fig. 7: Fuel filter - 1986-88 VG30i 85851038.gif
    Fig. 8: Fuel filter - 1986-88 Z24i 85851039.gif
Oct 17, 2010 | 1988 Nissan Pathfinder
Where is the fuel filter located on a 2006 Ford Freestar
Hello there:
if you have your filter great or if not use FRAM G8018 from WalMart for around $8 and then get the fuel line removal tool from Pepboys or autozone for $7. Tool should be 5/16" fuel line disconnect.
  • No need to raise the vehicle.
  • Due to the amount of fuel,that could come out I would use battery powered work light, not 110V AC for safety reasons.
  1. Pull relay #53 from fuse panel under hood. This disconnects fuel pump.
  2. Start engine and let it die. Restart again.
  3. Filter is located under passenger side center seat.
  4. sometimes more fuel will come out than expected. so make sure to Use a clean oil drain pan, or coffee can to catch the excess fuel .
  5. Use tool to disconnect fuel lines. Loosen single screw/clamp. Note the direction of filter.
  6. Replace filter, tighten clamp screw, reconnect fuel lines.
  7. Replace relay. turn the key to the on position for 45 seconds to get the fuel back in the lines
  8. Test by starting car, shut it down, look for leaks. If no leaks start car again, let idle and inspect for leaks again.
Hope this is very helpful for you.
Best regards Michael
Jan 12, 2010 | Ford Freestar Cars & Trucks
1988 volvo 740 gle non-turbo loud fuel pump
Have you tried replacing the fuel filter? It is located under the cars center on the left side ..
You will find it alongside the main high pressure fuel pump on a metal support plate held up with 3 bolts.
Remove the 3 bolts with a 10mm socket wrench to lower the plate. Place a catch pan below the filter to catch any leaking fuel.
Be careful not to get fuel in you eyes or running down your arms. Remove the 2 bolts holding the banjo fuel pipe connections to the filter.
Note the direction of the filter.
Loosen the clamp holding the filter to the support plate and slide out the old filter.
Install the new filter in the same direction as the old one and use new copper sealing washers on the banjo connections.
Apr 08, 2009 | 1988 Volvo 740
Basic service
Here are detailed instructions on the location, removal, and re-installation of your fuel filter. Hope it helps and have a great day!
Carbureted Engines
These vehicles use two replaceable fuel filters. A small one is in the fuel line under the hood; a larger one is located at the rear, just inboard of the left rear wheel.
Whenever the filter(s) are replaced, take great care to avoid the entry of dirt into the lines. Also, pay attention to the correct installation position. It is possible to install the filter backwards.
FRONT
See Figure 2
  1. If applicable, disengage the filter or hose from its retaining clip.
  2. Using two fuel line clamps, pinch off both fuel lines. Take care not to crush the lines; just clamp them shut.
If the fuel hoses are hard or cracked, it is necessary to replace them.
0900c1528005f267.jpgFig. 2: Front fuel filter used on carbureted engines
  1. Loosen the fuel line clamps and slide them back.
  2. Using a twisting motion, remove the fuel lines from the filter.
  3. To install, use a new fuel filter and reverse the removal procedures. Start the engine and check for leaks. Correct any leaks immediately.
REAR
See Figures 3, 4, 5 and 6
  1. Raise and safely support the rear of the vehicle. Remove the left rear wheel.
  2. Remove the bolts securing the filter and its basket to the fuel tank.
0900c1528005f268.jpgFig. 3: Remove the bolts securing the filter and its basket to the fuel tank ...
  1. Push the fuel filter retaining tab and release it from the basket.
0900c1528005f269.jpgFig. 4: ... then release the basket from the filter
  1. Using two fuel line clamps, pinch off both fuel lines. Take care not to crush the lines; just clamp them shut.
0900c1528005f26a.jpgFig. 5: Clamp the fuel lines shut. If the lines are hard, cracked or brittle, they must be replacedIf the fuel hoses are hard or cracked, it is necessary to replace them.
  2. Using a twisting motion, pull the fuel lines from the fuel filter; remove the filter.
0900c1528005f26b.jpgFig. 6: After sliding the retaining clamps back, the filter can be removed from the linesTo install:
  1. Use a new filter and reverse the removal procedures.
  2. Make certain the retaining tabs are engaged when the filter is installed in the holder. Tighten the bolts until snug.
  3. Install the left rear wheel. Lower the car to the ground.
  4. Start the engine and check for leaks. Correct any leaks immediately.
See Figures 7, 8, 9, 10, 11 and 12
The canister fuel filter is located in the engine compartment. When buying the new filter, also buy new washers for the banjo bolts and the service bolt. Failure to replace these washers invites high-pressure fuel leaks. Replacing the washers is required, not recommended.
  1. Disconnect the negative battery terminal.
  2. The fuel system is under pressure. Release pressure slowly and contain spillage. Observe "no smoking/no open flame" precautions. Have a Class B-C (dry powder) fire extinguisher within arm's reach at all times.
  3. Disconnect the banjo bolts and/or threaded fuel line fitting from the fuel filter. Use of a flare nut or line wrench is recommended for disconnecting and attaching this fitting.
0900c1528005f26c.jpgFig. 7: Fuel filter used on fuel injected Accords through 1989 0900c1528005f26d.jpgFig. 8: Fuel filter on 1990-93 fuel injected Accords 0900c1528005f26e.jpgFig. 9: Fuel filter used on fuel injected Preludes through 1991
  1. Loosen the fuel filter clamp bolt, then remove the filter.
To install:
  1. Install the new filter and secure the clamp bolt.
  2. The upper and lower washers on each banjo bolt and the washer on the service bolt MUST be replaced whenever the bolts are loosened. Install the washers and banjo bolts. Tighten the banjo bolts to 16 ft. lbs. (22 Nm) on all models except 1992-95 Preludes. On these models, tighten the bolt to 20 ft. lbs. (28 Nm). If applicable, tighten the threaded fuel line fitting to 27 ft. lbs. (37 Nm).
0900c1528005f26f.jpgFig. 10: Fuel filter used on 1992-95 Preludes 0900c1528005f270.jpgFig. 11: Fuel filter used on 1994-95 4-cylinder AccordsIt will be necessary to use a crow's foot attachment on a torque wrench to properly tighten the threaded fuel line fitting.
  1. Tighten the service bolt to 9 ft. lbs. (12 Nm).
  2. Start the engine and check for leaks. The engine may crank longer than normal until full fuel pressure is developed. Correct any leaks immediately.
0900c1528005f271.jpgFig. 12: V-6 Accord fuel filter
Nov 23, 2008 | 1985 Honda Accord
Tetra Pond Bp4000-uv Koi Pond Bead Pressure Filter W Uv Logo
876 people viewed this question
Top Tetra Fish Experts
Steve Dearman
Level 1 Expert
ThothMer
ThothMer
Level 1 Expert
Are you a Tetra Fish Expert? Answer questions, earn points and help others
