Question about Sunpak Cameras
Digiflash 3000 will not flash even when testing. I hear it warm up, ready light comes on, but nothing.
  • Sunpak Master
  • 15,979 Answers
These are not that expensive to buy, the problem is that the parts and service are more than a new one. In any case they use high voltage and you have to use special tools to measure and service the flash circuit. IT might be the flash tube is bad, the trigger circuit is bad, the capacitor is bad etc.
Posted on Apr 18, 2015
Testimonial: "Can the flash tube be changed?"
How do I use this flash as a slave?
You need to set the flash to slave and the same channel as the master. If the flash doesn't have this function it may be able to be fired optically. Set the master flash to low power and set the off camera flash to optical.
Jul 15, 2015 | Sunpak DigiFlash 3000 External Flash
Sunpak digiflash 3000 manual
I wonder if a little sand got into the threads...
If you simply cannot get it to loosen, have someone try CAREFULLY with a pair of ChanNelLock (brand name) or other brand "water pump pliers", Dorothy. Ordinary slipjoint pliers (the kind that look like two little opposing thumbs) are generally useless for things like this, but parallel-jaw pliers ("water pump pliers") might be able to get in to that little plastic thumbwheel to loosen it far enough to remove.
Really - GENTLY is the keyword here. If they grip the thumbwheel too tightly, it'll distort the plastic and the thumbwheel will never feel the same again.
Once the flash is off the camera, use some aerosol cleaner spray to clean the threads while you work that thumbwheel back & forth. Don't use anything with any lubricant in it, but Freon or plain-air "spray" works well. Whatever you use, it MUST evaporate COMPLETELY and not attack plastic.
Aug 04, 2014 | Sunpak Cameras
Printer ready light never comes on but printer works
I've had this fault myself, If memory serves me right the control panel ( small though it is) we found to be the problem, once replaced the unit the displayed correctly, weirdly all functions of the printer were still available even though we were unable to see the display.
we were able to get config pages etc, and like you say the indicator lights were working- sort of - when they wanted to.
replace the diplay PWB ( its small and reasonably cheap)
Mar 14, 2014 | HP LaserJet 1500L Printer
Bought a Nikon Speedlight SB-600 in August. Tested the flash and it fired ok. I took out the flash a few days ago to use at a graduation and the "ready" light did not come on. Consequently it did...
Hi grwcamp, Sorry to hear about it not working at the graduation. Are in the correct position (I am sure you did but, we must start someplace). Look inside, see if there is battery acid in there.
If with new/fresh batteries it still does not work call Nikon. You have a warranty on it so it should be covered.
Nikon digital 1-800-645-6689
Dec 04, 2010 | Nikon Speedlight SB-600 TTL Flash
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Feb 26, 2009 | HP LaserJet 4 plus Printer
Tv won't stay on!
Check C506 = high failure item # 483512247584 680pf / 2kv
Dec 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Umax powerlook 3000
The UMAX web site appears to have a fairly good knowledge base, especially when it comes to troubleshooting blinking lights. http://umax.com/support/knowledge/index.jsp Doing a search for lights under Support info result a few articles, including this one: http://umax.com/support/knowledge/search.jsp?docs=SC00322
Sep 14, 2006 | Umax PowerLook 3000 Pro Flatbed Scanner
Cameras Logo
299 people viewed this question
Top Sunpak Cameras Experts
Doberman
teddyboy
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
