Question about Craftsman Garden
Lt4000 rear axel came out after pulling rear wheel off how do i reinstall the axel
  • 109 Answers
Take off the transmission and go into it, there is a retaining clip there on the inside that keeps the axle in , sorry, keep all oil and filter it and reuse it, and refill the tank thing too, its hydrostatic oil.
its not that hard, just go slow and look up some diagrams and use Hondabond if you can for the sealent, let dry overnight before refill
Posted on Apr 21, 2015
Cannot get rear axle out on a 2010 flhtc
Hi Anonymous, push the axel all the way back in. Safely and securely blockthe front of bike with wood so that front wheel is 3" to 6" off the ground, then jack the rear end of frame so you can see axel has negative pressure in swingarm slots and you pull axel out with your fingers. Or if you have a cycle jack even better. A long phillips screw driver/drift and a plastic mallet should do the rest. Please visit website below for a better how to:
How to remove install rear wheel tire of Harley Davidson Motorcycle Law...
Good luck
Apr 05, 2014 | 2010 Harley Davidson FLHTK Electra Glide...
Mtd removing rear wheels from axel
Be very carefull, if you pull the wheels hard enough the half shaft will pop the circlip on the inside of the gearbox and come away with the wheel, this will then require a gearbox strip down, leave it soaking in penetrating oil and try again.
Jul 11, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
How to replace bearing in a 1991 chevy 1500 4x4 rear axel at driveshaft?
To replace pinon bearing you need to pull wheels and the brake drums off next pull cover off the back of the rear end (make sure you have a drain pan under rear end) next turn dive shaft till you see a small bolt remove bolt pull center pin out push axle in pull c clips out pull axels out remove four bolts holding ring and spider gears remove gears assembly next remove drive shaft remove bolt from pinon push pinon in remove seal and bearing
Jun 27, 2011 | 1991 Chevrolet K1500
Do i have to pull the axel all the way out to replace the rear brake pads and take the wheel off.?
To replace the Rear pads you do not need to remove the axle. To remove the rear wheel you need it all the way out.
Feb 19, 2011 | 2004 Harley Davidson FLHRCI Road King...
Rear wheel bearing
if its like the 99 winstar:
safely support the van, remove rear wheel, remove brake drum, remove grease cap. remove caged locknut assembly (38mm socket i think.) then pull the hub assembly from the axel. you may need to cut away the inner race if the bearing falls apart. clean axel, apply alittle anti size compound, then push on the new hub assembly. tighten down the hub nut to specifications (should be on the leaflet in the new bearing package), install dust cap, install drum, install wheel, lower and drive :)
May 25, 2010 | 1998 Ford Windstar
How to replace rear axle seals
if the seal (s) is leaking you may have a bad bearing... to change.. remove the rear end cover, reach in pull the c clip on left or rt side. pull the axel out the side, use bearing puller to pull the old bearing, install new replacement bearing seal, put in axel, replace clip, reinstall rear cover, sealing properly, fill with rear gear lube to level of fill hole. get a chiltons manual for pictures and more detailed help.
Mar 10, 2010 | 1987 Chevrolet Caprice
Rear Axel Seal Leaking, How do I pull the axel to repair?
You will need to remove the differential rear cover,drain fluid, remove wheel, brake drum, (rotor) . Unbolt center diff. pin, carefully remove (don't loose shims) push axle in remove lock keeper, then slide out axle, replace seal, put some grease on it, slide axle in reverse all to install.
May 22, 2009 | 1999 Jeep Grand Cherokee
Rear axle seal replacement
Drain axel of Fluid, Roemve Diff Cover (Push IN on Axel to reseal at Wheel side) Remove KEEPERS From Insied END of axel then Pull OUT on WHEEL END of Axel. use Proper Seal removal tool to remove seal. Also Use PROPER Install tool for SEAL INSTALL Reverse Procedure to Install. In hopes this helps you Out.
Please RATE Me Also LoL Thank You.
Mar 24, 2009 | 1999 Ford F150 Regular Cab
Leaking left rear wheel seal.
Loosen differential cover and let oil drain. Remove cover, remove E clip lock from axel. Pull axel out. Remove bearing seal. Install new seal and reinstall axel. Reinstall E clip lock and new cover gasket. Fill with 75-90wt gear oil. Now I know that sound pretty straight forward. But there are some things to remember. The E clip lock can be difficult to remove sometimes. The most important thing is the seal, you will need to make sure it gets seated correctly and not torn when installing axel
Jul 26, 2008 | Chevrolet Silverado 1500 Cars & Trucks
Replace rear axel bearing on 4x4 5.3 Litre gas engine
Loosen differential cover and let oil drain. Remove cover, remove U lock from axel. Pull axel out. Remove bearing seal then bearing. Install new bearing, seal and reinstall axel. Reinstall U lock and new cover gasket. Fill with 75-90wt gear oil. Now I know that sound pretty straight forward. But there are some things to remember. The U lock can be difficult to remove sometimes. The most important thing is the seal, you will need to make sure it gets seated correctly and not torn when installing axel.
Jul 12, 2008 | 2000 GMC New Sierra 1500
Garden Logo
55 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
