Question about Mtd Garden
Can I get a picture of a 46" deck layout for a black mtd yard machine so I can c how the deck engagement cable go
  • Mtd Master
  • 1,169 Answers
Only seen one or two H decks here.
if it is this cable
then it connects to the RH brake assembly and the PTO engagement plate. There is also a spring that connects at the same point on the engagement plate to the right hand frame.
Posted on Apr 18, 2015
    Top Expert:
  • Mtd Master
  • 10,875 Answers
Mtd doesnt use a cable to engage the deck on 46 inch decks,they use an electric pto mounted on the motor,there is a mow belt and a drive belt that go to the deck,there is a drive belt for the tractor,the pto is expensive,make sure the switch isnt bad first,if your mower isnt one of these models,then it was added to the tractor, 13AG619H022, 13AI607H019, 13AJ608H131, 13AQ607H000, 13AS607H352, 13AT608H016, 13AU618H300 models
lester482529
  • 226 Answers
SOURCE: I need a diagram for the deck belt on my Cub Cadet
go to partstree.com put in your make &model #.then clickdeck assembly.hope this helps
Posted on Jul 19, 2009
  • 86 Answers
SOURCE: replace deck belt instructions.
A yard machine is made by mtd,if you have a computer you can do a google search on your yardmachine model to get diagram
Posted on May 12, 2009
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
harlan301
  • 205 Answers
SOURCE: MTD yard machine model 668 (46in) does not engage
check your brake pins on the trany there rusted and sticking. you can also shoot some wd-40 and hit your bake pedal till ti comes loss. now if you still can't use low dear check your variable speed pulley assay. may need to be replaced or rusted too. check for missing spring too. adjustment may be needed
Posted on Oct 14, 2009
  • 3911 Answers
SOURCE: I have a Yard Machine
There is generally a spring loaded tensioner pulley to take up slack as the belt ages and stretches. If this is not adequate, perhaps the wrong belt is on there.
Posted on Aug 12, 2010
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
Where do 4 springs go on 46 inch deck? The deck diagram I have does not make sense.
Hi Nick,
This may be the same diagram you already have, but this is the manufacturer engineering drawing for that deck.
MTD 13RN771H729 Yard Machines Lawn Tractor 2007 Home Depot Deck Assembly...
Aug 17, 2014 | Mtd Garden
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
May 16, 2014 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Belt diagram for 46" mtd yard machine riding mower
You can find the belt diagram for the MTD Yard Machine mower in the MTD Owner Manual. The diagram is on page 21.
Feb 02, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Need a deck belt diagram for MTD 13AL452F120525197-115
I also need a deck belt diagram because a manual didn't come with my 746 SRL yard machine
May 12, 2011 | Mtd 46" Dozer Blade, Fits All & Yard -...
When replacing double stack drive/deck pulley,how do you keep it from scraping deck/20 hp,46 cut,02 model,yard machines??!
MTD part number 950-0960A This is a spacer that goes under the pulley stack. It should help to keep the pulley from rubbing on the deck. Hope this helps.
Apr 01, 2011 | Mtd LAWN MOWER PART # 683-04163B FRAME...
I have a Yard Machine Gold 22 h.p. 8 speed with a 46" deck. Where can I find an online manual that will show me how to remove the deck step by step?
lower deck remove belt from engine disconnect any hangars connecting deck to tractor raise deck lever pull out deck reverse prosess to install
Aug 01, 2010 | Yard Machines MTD Gold 23 HP Garden...
I have a 20 hp MTD Yard Machine with a 46 inch deck. I was cutting some thick overgrown grass today and the belt started smoking. I immediately disengaged the PTO gave it a minute and tried to re-engage...
you should take a picture of how the belt is on there now so you will know how to put it back on. check to see if the blades will spin freely with it not running of course. put your hand under it and spin the blade. if they don't spin you may have something wrapped around the spindles causing the blades not to spin causing the belt to smoke. if the belt is cracked or missing any chunks you may want to replace it. take a picture so you will remember how it goes back on.
Sep 18, 2017 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Replace deck belt instructions.
May 04, 2009 | Garden
I need a belt diagram for my lawn mower>
If you don't have the model number, I just found a diagram for mine by Google, by typing in "MTD 46 inch deck diagram" It took me to a Parts Tree site and right to the diagram I needed. There are slight model differences but for years, the 46 inch, three blade deck has been essentially the same.
Apr 26, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
313 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
