Question about Refrigerators
How do I clean the insides of the maker. It requires dismantling.
    Top Expert:
  • Refrigerators Master
  • 10,875 Answers
Unscrew it and use clr to clean the ice maker and rinse with clear water or spray with clr and rinse with clear water,throw out first batch of cubes,it is non toxic
Posted on Apr 18, 2015
How can i dismantle a laurastar s4 iron?
not really-- use the correct iron cleaner and if that doesn't work, the damage done dismantling the iron will require a new unit any way
May 11, 2016 | Irons
Tip
How to repair a DCC-1200 Cuisinart Coffee Maker
Problem #1 - DCC-1200 makes steam - not coffee. Reason: the check valve is plugged - water will not flow.<br /><br />Solution #1 - Remove the check valve located inside one of the 2 silicon tubing hoses inside the coffee maker...and clean the valve. You must remove the bottom of the coffee maker (problem #3). Note: the check valve is not plugged due to hard water minerals. It plugs up from coffee grounds and coffee residue. Thus...use the charcoal filter, and clean with 50% white vinegar on a regular basis.<br /><br />Problem #2 - Removing the check valve located inside the tubing. You must cut it out and thereby destroy the tubing. Replacement is required.<br /><br />Solution #2 - purchase one foot of 3/8" SILICON tubing over the Internet from Rebel Brewer at <a href="http://www.rebelbrewer.com">www.rebelbrewer.com</a>. Silicon is required to handle the high temperature.<br /><br />Problem #3 - removing the bottom plate. It is secured with four "custom" torex screws that cannot be removed with a normal torex tool. (not designed to be easily removed). <br /><br />Solution #3 - I used a 1/4" drill bit and drilled off the heads of the screws. The bottom is easily removed. I was able to snap it back into place. You can use some silicon caulk at the 4 corners for a more secure fitting.<br /><br />Good Luck - not too difficult<br /><br />Camanokid
on Apr 15, 2011 | Cuisinart DCC-1200 Coffee Maker
White substance inside lens
It is highly unlikely that anything has entered the lens.
You would not need to dismantle to clean.
Wipe clear with the lens from outside.
Wipe clear the eye piece as well.
Otherwise is the recording head that needs to be cleaned.
Apr 27, 2014 | Panasonic NV-GS17 Mini DV Digital...
Have a lcd42f1080p tv have marks coming on the inside of the outer screen,can you advise please.
The set uses a display panel and IF the glass is not bonded to it but apart the only way to get to that area is dismantle the set and REMOVE THE ENTIRE DISPLAY UNIT (CALLED A DISPLAY PANEL) to clean whatever is in there out. Sometimes moisture condenses and gets on the inside of the outer screen.
If a shop looks or you call the maker they will know if that is possible or not and ITS NOT A DO IT YOURSELF JOB.
Dec 14, 2012 | Televison & Video
Remove haze inside headlights 2003 buick century
Are you sure it is inside? I don't think the assemblies can be dismantled, since they are a sealed unit. I don't know of any that can be taken apart, so a problem on the inside of the lens would require replacement. But any store with an auto shelf or section stocks headlight lens polishing kits for cleaning the outside of the lens or assembly and bringing them back to new condition.
Sep 29, 2012 | 2003 Buick Century
Jura-Capresso Impressa Z5 - left coffee spout is clogged the left spout only lets drips of coffee coming through yes we: 1. use only dry beans 2. have the water harshness setting below 10 (we only use...
As the coffee is dispensed, it is normal to have some residue left in the tubing and spouts. It is the reason that the machine will require cleaning on a regular basis using the Jura tablets that dissolves the coffee film. In the case the spouts get clogged, the best approach would be to dismantle the spout assembly. Since it may not always be possible, I found that filling a cup with a coffee cleaning solution such as Puly Cleaner (pulycleaner.co.uk) and having the spout dip in the solution overnight can help. Probably that dissolving a Jura cleaning tablet in a cup of warm water would provide similar cleaning power.
Dismantling the spout is rather straightforward. You start with removing the front logo by rotating it counter-clockwise. Behind it you will find a T15 Torx screw. Removing it will allow removal of spout cover by pulling the top part lightly towards you and then sliding it down below the spouts. Grab the spouts by the sides and wiggle downwards until it comes loose. You can now clean the spouts but will most likely need to soak it. See the video showing removal of the spouts @ youtu.be/9QlRGY0eX3s
Jun 08, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
I have a Lavazza Point Expresso Machine and it started leaking water out of the front. I believe it needs a gasket, but can't seem to get the parts to come off to get to it. I have used an Alen Wrench,...
When replacing the o-rings inside the boiler the operation should be carried out by a certified technician for these machines. When the boiler is dismantled it is recommended that all o-rings and springs in the boiler be replaced as these are ware parts. When the boiler is apart this is also an opportune time to do some manual cleaning to the internal parts. This is an easy task but as I said before must be carried out by a certified technician. Special tools not readily available to homeowners are required to rebuild the boiler once dismantled. I am sure there are many repair facilities around but location wise I am not sure. I have heard that espressozone.com are nice and will do repairs. Perhaps try them. You may also try contacting a lavazza rep and they may be able to point you in the right direction.
Apr 09, 2011 | Lavazza Espresso Point Capsule Machine
Where is the voltage regulator located on a 1991 lexus ls 400
The voltage regulator for the alternator is located inside the rear housing of the alternator. It can only be accessed by removing the alternator and dismantling it. If the regulator is faulty it is repair by replacement usually by swapping for an exchange unit from an auto electrician. If the alternator is not charging it may just be a case of the brushes inside the alternator being worn out and requiring replacement.It will still be required to remove and dismantle to carry out their replacement.
Oct 17, 2010 | Lexus LS 400 Cars & Trucks
Very little water is dripping into the carafe
Try to run vinegar undiluted through the coffee maker first. If this does not help, you may have a plugged valve in the coffee maker or a tube/hole where the coffee maker water should drip through. if this coffee maker has a dispenser(where you put your cup against it and the coffee comes out) then there is likely a plugged up valve. This will require dismantling the coffee maker to clean it. Usually coffee makers get plugged up because coffee leaves a residue that requires scrubbing at time to remove.
May 26, 2010 | Dualit Expresso + Filter Espresso & Coffee...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
