Question about RCA Televison & Video
I have an Olivia 537b12 TV. Recently we cut the chord and are now looking to put up an RCA Digital Antenna. The problem is, it's not giving us any stations. Do I need a converter box?
    Master:
  • 294 Answers
Check antennaweb.org for your location to make sure you're in a good reception area for digital TV signals. You also need to make sure your input source is the tuner or TV.
Also, have you been using this Olevia regularly? They got smacked with a batch of bad capacitors; sometimes that can lead to some inexplicable behavior.
Posted on Apr 18, 2015
SOURCE: Does a CT-27614A need a digital converter for antenna?
Yes.
Posted on Mar 03, 2008
WhIzAtIt
  • 136 Answers
SOURCE: 2006 RCA TV Digetal Receiver
You WILL have to get an upgraded antenna and converter to be able to watch the new HDTV standard. There is no back door or any other way around it. Point blank get a new antenna and converter.
Posted on Jun 10, 2008
  • 4234 Answers
SOURCE: digital converter box hook up
Can you describe how the DVD and VCR were connected prior to the converter box when they were working? I need to know that in order to guide you properly.
Thanks,
Dan
Posted on Jul 24, 2008
joboo1
  • 257 Answers
SOURCE: Is this TV a digital tuner? or will I need a converter box
Hi, If you have an outside antenna you will need a converter box as this tv has an NTSC tuner which is analog.
Posted on Feb 02, 2009
  • 12 Answers
SOURCE: I have an RCA converter box hooked up to an RCA tv
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Posted on Feb 27, 2009
I recently purchased both a digital converter box and a antenna from RCA. I perform a channel search and it finds nothing. Please help.
antenna hooks to converter input then that connects to the TV tv has to be set on antenna or air .
Mar 05, 2015 | Televison & Video
How to get rca indoor antenna to pick up free digital channels on my Samsung television
Indoor antennas are not very good if you live far away from the TV transmitter. Antenna aim has to be more precise than before with analog TV's. If you can put up an outside antenna you'll probably get them all.
Mar 18, 2013 | RCA Ant121 Indoor Passive Antenna
I'm trying to hook up an indoor antenna to my polaroid flm-3232 do I need a digital converter box or does the tv have the necessary components?
You have an analog TV, meaning that the tuner in your TV is analog only. You must buy a digital converter to see broadcast Digital TV via your external antenna and it will be attached to the antenna input jack or other jack depending on how it comes out of the converter.
One bit of advice, there is no such thing as a "digital" antenna, they are all analog. Even a 50 year old, outside antenna aerial that you see out in the countryside will pick up the new Digital Broadcasts to be converted by a Digital Converter and displayed on a 50 year old TV.
Oct 21, 2012 | Polaroid FLM-3232 Television
I have a sony str-DE695 and I am trying to hook up my speakers/record player to it. The record player has an RCA chord with one white and one black end. The speakers has the same chord but with one red and...
the inputs should be marked phone (if on the reciever the colors are red/white and the colors of the rca ends are black white put the black plug in the red and white plug into the white input..if the stereo doesn't have rca speaker output ports you'll need to cut off the speaker rca's and strip the wires bare then comnnect usually copper (red) silver (white) or pos (silver) neg (copper.
Sep 26, 2012 | Sony STR-DE695 Digital Audio/Video Control...
The tv isvhf and uhf in otherwords no picture how to receive digital on anolog system or get a pic on my tv anologly
Only one av plug in maybe plug in your analog TV scanner into av slot I have one to wondering if antenna plug in none but av one slot maybe antenna into from analog digital stream or RCA analog might give me antenna to directly off my RCA digital box
Sep 16, 2012 | Vector Vec135 Tough Brite Storm Tracker...
My tv comes on and has "unusable signal" floating on it
What is your signal source, OTA or cable? Did lightning or another type of power surge recently hit? Make sure you have the TV on the desired input.
If OTA check your antenna direction and that you have the Channel Setup (from the menu) set to Antenna. Also check if you have the right antenna to get stations in your area. Antennaweb.org gives the most likely channels and directions. tvfool.com will give more detailed information and more stations. Both sites assume outdoor antennas but the direction information is always good. Look for new construction or big trees that might block the signal. Do you have multiple TVs sharing the same antenna? You might need an amplifier.
If cable, check the Channel setup. Check for someone recently damaging your cable installation (cutting the wires, trying to split the signal to get it for free) Splitting the signal to multiple TVs may also be an issue, get an amplifier of the correct type. Some cable systems may require a bidirectional amplifier.
If you recently had a power surge, see if the TV works with other inputs.
Tuners can be replaced if the TV is worth the labor costs for you.
I hope this helps.
( My household had three tvs and a digital to analog converter that lost their tuners after a nearby lightning strike. We chose to replace the TVs since two were over 15 years old and the third was also out of warranty.)
Apr 13, 2010 | RCA L46WD22 Television
TV connection gets very good picture but VCR gets only bad ''grainey'' pic and bad sound. I used RF cables. Will using RCA cables solve the problem? Thanks Guy Daly dalyguy@hotmail.com
You could use 75ohm satalite cable for the RF cables it will give you better signal than the old style co-axial cables most people use. Simply put new co-axial plugs on the new cable and connect that. It will also cut down on electrical intereferance and noise if you use it right up to the antenna. Makes a hell of a difference if you are watching digital TV!
Jun 06, 2009 | Panasonic Televison & Video
RCA TV with Guide Plus that no longer receives guide at night
Please clarify what you are getting. Is the Guide Plus coming up with no programs listed? If so, it may be that you lost power and the set has to be turned off overnight to "reload" the program schedule. If that is not the problem, have you recently changed to digital through a digital receiver? You need to have your analog antenna connected to receive the program listings. You may have to install a splitter to have both the digital antenna and the analog antenna connected. I have an RCA with Guide Plus and ran into the same problem, but solved it by reconnecting my analog antenna and leaving the set off overnight to reload.
Feb 15, 2009 | Televison & Video
I recently acquired my grandmothers tv = an 2004 model RCA #27F350T and wondering if it is digitally ready for Feb. 19 - we are currently using an outdoor antenna with a booster.
I could not find a "RCA model #27F350T", but there is a RCA model 27F530T, and according to the users manual for that TV, it is not Digital ready. You will need a converter box if you wish to continue receiving antenna based broadcasts. Your users manual can be found at the following link.
http://tv.rca.com/RCATV/Assets/pdfs/27F530T_1620181B_IB_e-04.pdf
Jan 04, 2009 | RCA 27F530T 27" TV
Need a smart antenna to go with the Digital TV converter box
First, you don't need a Smart Antenna, the manual is simply stating that your converter will use one if you have it. Any standard antenna will work, so there is no need for a coupon to pay for a new one, whether indoor or outdoor depending on your location and distance from each channel transmission tower. Since you don't give details of what antenna you are using, I will assume you have rabbit ears for each converter. Rabbit ears are notorious for poor reception and any metal or persons nearby will change the reception quality. I would recommend a roof mounted external antenna with splitters for the 3 converters if you have the option. If not, use an amplified internal antenna and mount it closest to the channel towers you will watch most and as high as possible. If you can find a smart antenna, which is an amplified indoor/outdoor antenna with a control cable for changing the direction of reception, for a decent price, you can use that but keep in mind that to use the control feature you will need one for each converter. Also, check antennaweb.org for information on digital channels in your area and their direction and distance. Antennaweb.org will also tell you if any digital channel in your area uses VHF frequencies. If they don't then a UHF only antenna will work fine.
Jul 16, 2008 | RCA Universal Remote Control
Televison & Video Logo
43 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
