Question about Bissell 3522 PowerForce Bagged Upright Vacuum
My son sucked up some ear buds, and the roller stopped turning. How do I get it going again?
    Master:
  • Bissell Master
  • 850 Answers
Hi, this is Jim with Crucial Vacuum,
Try manually rotating your vacuums brush roll to see if you can remove the ear buds without completely destroying them. If this proves difficult use a scissor to cut them out and untangle them from your unit. Better to have broken ear buds then a completely broken vacuum.
Since you're checking the bottom of your vacuum anyway make sure the belt is still wrapped around your brush roll. Often times when objects like this are sucked up into your vacuum they can loosen a few essential parts to keep your vacuum from performing optimally. Look to see that the belt has a good bit of tension. You want to be sure the belt is on there nice and tight.
I hope these tips can be of help. If you're looking for replacement parts to your Bissell 3522 you can purchase them directly from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=3522&order=relevance&dir=desc
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Posted on Apr 20, 2015
  • 3 Answers
Or you can take it apart if the ear buds are expensive and get the buds off the roller; and while it is apart do a good cleaning on the machine. kill two birds one stone. Good luck
Posted on Apr 19, 2015
    Top Expert:
  • Bissell Master
  • 10,875 Answers
Dig them out and cut the wire,spin it backwards
Posted on Apr 18, 2015
ON THE SHARK ROTATOR PROFESSIONAL, WHERE IS THE RESET SWITCH?
do you mean how to make it run again after , example my carpet had a long string and i accidentally sucked it up well, until the machine stopped ? if this is sounding familiar try to check the brush roller remove whatever you find and it should turn itself back on
if that is not the situation please let me know i will be happy to find additional info for you if possible
Dec 06, 2016 | Shark Vacuums
Suction stopped. Roller and belt working-in fine order. Checked hoses have not found any blockage. Blowing out air or sucking so little can't feel it with hand on hose end. Help!
Either a blockage or the main air filter is blocked , some it can be washed and others it must be replaced
I would check the owner manual and look at the filter, foam ones can and usually have instructions where they install to wash them.
Dec 11, 2012 | Hoover Tempo Widepath Upright Vacuum -...
Dyson DC17, front roller motor stopped
Are you sure it's dead? The motor will turn off if there's too much resistance. Unplug the vacuum, remove the obstruction, plug it back in and then firmly press the beater brush on/off button which is located next to the main on/off button.
Apr 04, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I accidentally sucked up a thin belt that wrapped around the bristles and stopped the bristles and now the bristles wont turn
You need to remove the thin belt from the roller if you haven't already. Check the ends of the roller to make sure there is nothing there stopping the roller from turning. You can try turning the roller with your hand using minimal force.
I believe this unit has a switch on the front of the handle for the brush motor. It may cut off if the roller gets hung up. Have you tried turning this on?
In summary try cleaning everything off of the roller and then check for the switch that I mentioned. Let us know how you make out and good luck!
Mar 13, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My eureka 437 stopped sucking
I believe the filter on your vacuum is clogged. Bagless vacuums require the filter be brushed or washed and dried, If they are not, the filter will clog, resulting in the reduction of suction. Clean filter about every 3 months or sooner if the same problem happens again. Hope this helps.
Aug 20, 2009 | Eureka Vacuums
Uprightvac 3500SA roller is not turning
When you lower the handle on the electrolux, you will see a little button on the top of the base . This is a reset button, turn the vaccum on and push the resrt button and it should start working again.
Mar 19, 2009 | Electrolux Epic 3500 Vacuum
Bissell 3522 PowerForce Bagged Upright Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
