Question about Radio Communications
I held down both volume buttons and now I can't connect headset
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 50 Answers
2 Suggested Answers
SOURCE: No volume on the headset
buy a new one.
they're cheap pos's
Posted on Nov 17, 2007
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
I bought LG 730 Bluetooth Headset, unfortunately the language has been changed. Let me know how can I change to English
Ion know if I'm to late.....but Ive only had the headset for 2 weeks I somehow changed the language on my headset......I did try to live with it honestly......i just started trying combinations Lmbo.......
ANYWAY I HELD DOWN THE VOLUME UP AND DOWN BUTTON AT THE SAME TIME AND THEN PRESSED THE CALL BUTTON........
SHE THEN SAID ENGLISH PROMPT AND THAT WAS IT......
Apr 12, 2015 | LG hbs-730 Tone Stereo Bluetooth Headset
Razer Chimaera 5.1 Headset turns volume down until mute by itself
Did you ever get a reply for this? I have the same issue. Sometime I'll replace the batteries or recharge it and it works great for a little while then suddenly starts auto turning the volume down...
May 05, 2012 | Razer Radio Communications
I AM NOT ABLE TO PAIR JABRA BT135 WITH MY BLACKBERRY 9700. WHAT SHALL I DO?
Hi,Instructions on how to pair blue tooth device with black berry.
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Have a nice day .
Feb 16, 2011 | Jabra BT125 Headset
I can't get my Jabra BT150 in pair mode
Hold down the main button until the light stays lit
Mar 23, 2010 | Jabra BT150 Wireless Headset
My Plantronics Voyager 510 will not go into pairing mode.
i actually got this to work with my iphone 3G S. i pressed the little black button then saw a blue light flash, and then i pressed and held the + volume button and the call control button until it started blinking blue and red and my iphone picked it up instantly. it did take a couple of times to get the headset to go into pairing though
Jan 16, 2009 | Plantronics 510 Voyager Headset - PLN-510...
User manual of bluetooth headset H200
Press and hold down the button on the front of the bluetooth (has little phone symbol). Wait until it is blinking blue, means it's on. Keep it held down longer, it will be a constant blue light, no blinking. That is pairing mode. That is when you should search for the device via your phone and it will come up as H200. Pair, put in 0000 as your code. Should connect. Hold down the button on the bluetooth while on and it will blink red once and that means it's off. While connected to your cell it can answer your calls, hang up calls, up/down volume, ignore calls, and call the last person called. The pairing thing took a while for me to figure out, I have the manual and it doesn't say anything about waiting until it's a constant blue light. Make sure you keep holding it down until the blue light is on, NOT flashing, it will start flashing but keep it held down until it stops flashing and is on.
Hopes this helps!
T
Sep 20, 2008 | Computers & Internet
Vibration when some one is calling
Quoting "SRALPH" from HowardForums.com
http://www.howardforums.com/archive/topic/779306-1.html
With the power off:
1) press and hold the volume down button, which is the closest one to the mic
2) with that button held, simultaneously press and hold down the power button until the blue led flashes.
This will deactivate the vibrate function and it should stay deactivated until you power up the headset with the volume up button pressed and held in during power up
Apr 28, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra Vibrate Feature
from the manual at http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
Call vibrate*
• Call vibrate is automatically activated when you turn on your headset.
• To disable the call vibrate feature, press the answer/end button and
press the volume down (-) button at the same time.
• To reactivate the call vibrate feature, press the answer/end button and
press the volume up (+) button at the same time.
Dec 19, 2007 | Jabra BT350 Bluetooth Headset Headset
Motorola H500 Wireless Headset Pairing Problem
If you turned it on and it was steady blue most likely you held the call button too long. The steady blue means it's ready to pair with a phone. Try repairing again and if you still don't hear anything, play with the volume buttons to the top and buttom of the headset the volume may be down. If that doesn't help I don't know what will.
Aug 20, 2007 | Motorola Mobility H500 Wireless Headset
Radio Communications Logo
157 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
