Question about Refrigerators
My fridge and freezer not working very well, what can I do?
Need to know if there are any common issues? should i get repaired or buy new
    Top Expert:
  • 6,702 Answers
What Jorge and Bill say, makes sense. On the other hand when old freezers don't perform well, they consume lots of power. New freezers cool better with less power. You could save hundreds of kilowatt a year with a new freezer for their better insulation and higer efficiency.
Posted on Apr 18, 2015
    Master:
  • 408 Answers
A technician would first make sure there is good airflow on the ondensor and evaporator, the outside and inside radiator coils. The condensor would be the first thing to look at, it is under the fridge where the fan blows on to, it gets clogged with dirt and lint, it needs to be clean and the fan is inspected for good spinning speed. This condensor is what disipates heat removed from the inside of the fridge or evaporator. The evaporator gets cold and absorves heat and if there is no airflow across the evaporator, the evaporator will ice up into a chunk of ice, then no airflow at all across it.
Start by cleaning the outside condensor then if necessary, chec the inside fridge's airflow.
    Top Expert:
  • Refrigerators Master
  • 42,818 Answers
Most problems of not freezing very well can be attributed to poor door seals or doors not being closed properly
another problem is if people use the fridge to air condition a room by holding it open too long while they look and talk. This looses all the cold from the fridge and so the recovery time is much longer
check that the settings have not being moved by food as it is put on the shelf
fridges the lower the number the colder and freezers the higher the number the colder
other that that get a fridge technician to advise on repair ability
I have a Whirlpool Refridgerator model WBM39MS. It stopped cooling and I had it repaired. The Repairman replaced the electronic control box. Repairer claims that the compressor is working. It now seems...
Hi Lollipop, partially working fridge? A fridge either works or not, cold air is made in freezer then distributed to fridge via a vent. In your case WBM Series fridge, top mount freezer blows air down a vent (back centre of chiller compartment). A common fault with the WBM Series is both the PCB and Interface Panel (PCB beside compressor back of fridge, Interface is display panel front of fridge).
So if freezer is cold and fridge not, try a fan motor. If compressor doesn't work either comp is faulty or PCB has blown(has a burning smell).. Hope this helps you and maybe many other ppl.
Jan 21, 2010 | Refrigerators
Punctured a hole in the freezer compartment
That type of damage is usually fatal to the unit. It is difficult if not impossible to repair in most cases depending on the metal used to make the evaporator, and what kind if equipment the repairman has. You can't fix this yourself, consult a local repairman, explain what happened, and the model of the unit, and ask if repairable what it might cost. Or just buy a new one. And NEVER use sharp objects in an effort to remove frost buildup. Turn it off, put your stuff in a cooler, and use a heat source such as a bucket of hot water in the unit with the door closed
Jul 18, 2009 | Haier ESR042PWW 4.2 Cubic Foot...
Freezer not blowing air - bad smell in fridge
Your automatic defroster coil is open and needs to be replaced along with the fan in the freezer that blows the cold air around and also blows air into refrigerator.
Bad smell down below is food rotting in that section because it is not cold enough.
Mar 22, 2017 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Freezer is not freezing its cold like the fridge but thats it. tha fridge is running
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Refrigerators
Freezer is working but the firdge part is not cooling.
Apr 01, 2009 | Samsung Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Fridge freezer won't work after moving overseas
It may need to be re-gassed and repaired. But before you do its plainly been damaged in transit so you will be able make a claim agianst the transport company. Don't be shy call them and ask how to make a claim.
Dec 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Top fridge not working at all.
hi thanks for the question the problem is the fan motor in the freezer yes have it repaired thanks the appliance doc
Sep 17, 2008 | Fisher and Paykel E522BRXFD Stainless...
Fridge freezer KIM 29473GB/01
Liners are not able to be replaced. Will need to buy a new unit if the liner is a problem.
Oct 07, 2007 | Bosch KIM29473GB Bottom Freezer...
Refrigerators Logo
265 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
