Question about Pentax Optio S Digital Camera
Where do I get the file:fwdc110p.bin ?
Need firmware upgrade for Optio S4..
  • Mikesue Dec 10, 2007
    Despite charging several batteries fully and pressing menu and the power button at the same time, my camera still refuses to operate, and shows just A90 on the screen. It all started when I thought that the batteries weren't fitting properly because the camera said they were depleted!
    I sent it back to Pentax who were going to charge about £110 to repair it - so I decided it wasn't worth it. They said the case was damaged, but it looks OK externally. I read elsewhere that A90 signifies a motherboard fault. Although I have given up I am still interested in having one last go. The camera may not be much by todays standards, but I really liked it!
    Where is this elusive file?
  • Anonymous Apr 12, 2008
    optios,A20
    Problem Solver:
Http://www.badongo.com/file/707791
You can download the file from the above site - I think this might be the exact reference. Then go to the most recent entry on this site for the secret menu process http://forums.steves-digicams.com/forums/view_topic.php?id=82905&forum_id=24&highlight=A90
Rember to place it on your card at the same level as the DCIM file, not inside it like I did at first. It came zipped so you will need to use Winzip. I will now try and polish this a bit on that site while it is still fresh in my mind.
Posted on Feb 01, 2008
SOURCE:
D3 will not show option to do firmware upgrade from 1.0 to 2.02
Copy just the AD3_0202.BIN file to the top level of a formatted CF card. Insert the card and select Firmware from the Setup menu.
Repeat the process using just the BD3_0202.BIN file.
Full instructions are here.
Oct 23, 2012 | Nikon D3 Digital Camera
WRT120N no .bin or .img file in firmware update download
Hi Friend
in order to upgrade the firmware please follow the steps:
1. Click the link (http://homesupport.cisco.com/en-us/wireless/linksys/)
2. Enter the model number of the router and hit enter.
3.Click Download Tab
4.Now enter the hardware version of the router (which you can find by turning the router upside down)
5.Now you can download the firmware which is a .bin file and save it to the desktop.
6.Open the router page and click Administration and click Firmware upgrade.
7.Select the file from the desktop by clicking Browse and start upgrade.
8.Turn off the router for 30 seconds after upgradation and turn it on..
i hope this will resolve the issue.
Regards
Chiranjeet
May 21, 2010 | Linksys WRT120N Router
A90 error Optio S4
Gerrit
So is jou probleem uitgesorteer ?
Apr 17, 2008 | Pentax Optio S Digital Camera
ERROR A90
OK Guys...After fidgitting for hours on this with the bits & pieces on this forum & on others...here's how I got it to finally work:
A- I have a Pentax Opio S hence I had to get the "fwdc110p.bin" file here:
http://www.pentax.de/mediapool/attachments/photo/100/104/46139/fwdc110p.zip
Optio S4, S4i & S5i shall use another file. Don't really know for S4 but for S4i & S5i, there on the Pentax customer service website at:
http://www.pentaximaging.com/customer_care/software_firmware?sfFlag=f
B- Drop this file on your SD Card at the root directory (same level as DCIM folder) or as described by the following link and then close your camera to OFF:
http://www.pentaximaging.com/customer_care/show_firmware?firmId=1020
Attention: Do not load this file yet onto the camera i.e. the menu+power on procedure, follow step C first...
C- Open the now infamous "Secret Menu" in order to re-initialize your camera prior to re-installing the new firm ware:
Simultaneously press MENU + Flash symbol button + Power ON...a white screen with data written in black should show.
Then a sequence of buttons must be pressed: 2 times the focus button (flower, mountain, MF symbols button) followed by 2 toggles to the Right of the "OK" button...then press MENU once and voilà...ze Secret Menu appears !
Using the down toggle of the OK button, go to "SYSTEM INITIAL" and press OK. Press another OK to re-initialize your camera.
Once this has been completed, turn your camera off.
D- Load the firm ware by opening your camera with the MENU+Power ON procedure...finally this should be posting "Complete" after the "Loading" message, instead of the "Error!" that we initially kept on having.
Your camera should be working perfectly ! Only thing, is that you will have to redo your personal settings on it from scratch...but hey, this is much better than to wait for months to get your camera back from Pentax and save that money for your next photogenic trip !
Jan 30, 2008 | Pentax Optio S4i Digital Camera
A90 just appears after switching on.
I had the same problem.
After starting up 20 or 25 times with the fwdc110p-file the problem was fixed.
Dec 12, 2007 | Pentax Optio S Digital Camera
How to upgrade the firmware on a BEFSR41
Firmware upgrades may erase all previous settings to your router's configuration. Before upgrading your firmware, make sure to record your settings. 1. Unplug and disconnect all computers from the router except for one. This computer must be plugged into the router directly. There can be no other network activity on the router during the upgrade, so be sure to power off all other computers. 2. Go to http://www.linksys.com/download 3. Select the model number of the Linksys router you have (BEFSR41) as firmware upgrades vary by model and version. You can find your router version underneath your router after the model number. For example, ?BEFSR41 Ver. 3?. 4. Click the Downloads for this Product button. 5. Once you arrive on the download page, click the Firmware button. 6. After the firmware page opens, click the link that says ?Click here to download the latest firmware...? and download the firmware file to your computer. 7. Once you download the firmware Zip file, unzip it. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. 8. After unzipping the firmware files, one of them will be called TFTP.EXE. Double click on it. 9. When the ?Upgrade Firmware? window opens, you will have three prompts. The ?Server? field is for the IP address of your router; by default this would be 192.168.1.1. 10. Enter the routers password into the ?Password? field; by default the password is admin. 11. Browse for the file in the Firmware Upgrade utility program by clicking on the button next to file with the '?' symbol on it. Look for the file named 'code.bin' in the folder where the firmware files were extracted to. 12. Highlight the code.bin file and click on the Open button to direct the TFTP loader program to put that file into the "File" box. 13. The full path should be displayed [example: c:\linksys\code.bin]. 14. Click on the Upgrade button to begin the upgrade process. 15. The upgrade should take about 1 minute, and you will be prompted after the upgrade is complete and successful. If you are still having troubles, contact Linksys Technical Support.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Freeze Up
http://www.badongo.com/file/707791
Important!!! Insert a fully charged battery or connect to an external power source.
C- Open the now infamous "Secret Menu" in order to re-initialize your camera prior to re-installing the new firm ware: Simultaneously press MENU + Flash symbol button + Power ON...a white screen with data written in black should show.
Then a sequence of buttons must be pressed: 2 times the focus button (flower, mountain, MF symbols button) followed by 2 toggles to the Right of the "OK" button...then press MENU once and voile...the Secret Menu appears!
Using the down toggle of the OK button, go to ROM UPDATE then go down to "SYSTEM INITIAL" and press OK. Press another OK to re-initialize your camera.
Your camera should be working perfectly! Only thing is that you will have to redo your personal settings on it from scratch...but hey, this is much better than to wait for months to get your camera back from Pentax and save that money for your next photogenic trip!
Sep 13, 2005 | Pentax Optio S Digital Camera
USB Connection problem Optio S4
have you turned the camera ON after connecting the cables? Next, does this USB port on the computer work with other USB devices such as memory sticks? My O555 has a USB socket that feels really "fragile" and I fear I will damage the socket with improper insertion (alignment seems touchy). I bought an external USB card reader and am really happy with that. You don't use up battery power transferring your files. Much better solution, IMO.
Sep 08, 2005 | Pentax Optio S4 Digital Camera
256 Sandisk SD card problem with an Optio 33LF
Optio 33LF Firmware Upgrade Information & Instructions: This firmware corrects "camera freezing & cannot display images" issues with Sandisk & Black's 128MB & 256MB Secure Digital Cards. This problem is occurred because Sandisk changed the manufacturing location from the Philippine's to China during production of the Optio 33LF. They also change the electronic chip used the SD Card which caused a compatibility problems with Pentax, Minolta, Palm and other digital device manufacturers. In turn this also caused a problem with Black's SD Cards as they are manufactured by Sandisk. Therefore, we had to release a Firmware Upgrade for the Optio 33LF to correct compatibility issues with these SD Cards. HOW TO CHECK WHAT THE CURRENT FIRMWARE VERSION: Confirm the current firmware version by pushing and "HOLDING DOWN" the "Right Arrow & Right Zoom" button located at the back of the Optio 33LF. While continuing to hold the "Right Arrow & Right Zoom" button turn the POWER on the Optio 33LF. The current firmware version will be displayed on the LCD. If the firmware version reads "Current Version 01.01.05.04" then your cameras firmware is up to date. If you do not have the current version, then please refer to the information listed below. Please be sure to upgrade your camera. You can download the firmware from the following link. Please be sure to follow the instructions listed below. Firmware Download: http://www.pentax.ca/support/digitalsoftware/fwdc113p.elf Firmware Update Instructions: Please refer bellow to learn how to upgrade the firmware on the Optio 33LF. Should you have any problems please contact our customer service department. I have included our contact information bellow. PLEASE NOTE: 1. It is very important that the batteries do not deplete during the firmware upgrade as this will damage your camera. Therefore, please check your battery indicator prior to the firmware upgrade. FIRMWARE UPGRADE #1. Save the attached firmware "fwdc113p.elf" to your Desktop. #2. Put a Secure Digital Card in your Camera. #3. Format the Secure Digital Card to be sure that no other information remains on the Card. (Refer to page 86 of your Operating Manual) #4. From your Desktop right click on the firmware "fwdc113p.elf" and select "COPY" #5. Double Click on "My Computer" you should see your "REMOVABLE DISK" #6. Right Click on the "Removable Disk" and select "PASTE" Once the "fwdc113p.elf" file has been copied to the Secure Digital Card, be sure to properly disconnect your USB device if you are using Windows Me, 2000 or XP. For instructions on how to disconnect a USB device with Windows 2000, please refer to the Optio 33LF Operating Manual. Now that you have the Firmware on the Secure Digital Card. #1. Be sure the Secure Digital Card containing the Firmware Upgrade "fwdc113p.elf" is in the camera. #2. Be sure that your batteries are fully charged as you do not want the
Sep 08, 2005 | Pentax Optio 33LF Digital Camera
Pentax Optio S Digital Camera Logo
5,649 people viewed this question
Top Pentax Cameras Experts
Ekse
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
