Question about 2008 F250, F350, F450, F550 Wiring Diagrams
1999 FORD F550 WIRE DIAGRAM FOR TRAILER BRAKE CONTROLLER
WHERE TO LOCATE FACTORY WIRE HARNESS FOR BRAKE CONTROLLER
    Genius:
  • Ford Master
  • 2,494 Answers
You have to buy an electrich brake unit ,instruction are in the box.
Posted on Dec 02, 2015
I have a 2005 ford f550 with factory brake controler & factory trailer wire plug. On the trailer wiring plug I am not getting power to the turn signals or brake lights. The turn signals and brake...
There is a fuse box under the hood that has the fuses that control the wire harness. There are at least 2 boxes, mine were on the drivers side wheel well near the rear of the engine compartment.
Nov 14, 2013 | 1997 Ford F150 Regular Cab
I am installing an electric trailer brake controller on my 2008 Ford F- 150 STX pick up truck and I need to know where it plugs in under the dash
Ford's factory supplied brake controller harness end can be found loosely stuffed under the dash, usually just above the driver's right leg. A Ford harness has a rectangular shaped connector.
Simply connect the brake controller harness connector into the vehicle connector. Zip tie the harness wires to another harness to prevent the wiring from hanging down near your feet.
I hope this helps.
Jul 03, 2011 | Ford F-150 Cars & Trucks
I have a 2001 F150 and am trying to find out where the factory installed plug in is for the brake controller wiring. I have the brake controller and the instructions say to read the truck owners manual...
Hi. There is a grey plug with 6 wires right behind your OBDII diagnostic port on the lower dash board above your accelerator pedal.
The color of the wires on the plug are blue, green, red, white and brown. The wires are as follows:
Blue....electric trailer brake feed
Green....brake pedal switch
Red...12v postitive...always hot
White....ground
Brown....interior vehicle illumination (not used)
The factory wire harness that you will need to attach your brake controller will plug right into this plug. The factory wires are colored the same as above.
After-market and brake conroller wires are colored as follows:
Red.....brake pedal switch
White....ground
Black....12v positive
Sep 01, 2010 | 2001 Ford F150 Styleside SuperCrew
I'm trying to install a Tekonsha trailer brakes and need the wiring diagram
The controller should have wiring diagrams with it. Also try http://www.etrailer.com/faq-wiring.aspx. The truck should have a harness that plugs into the factory harness under the dash. The harness paperwork will describe where it plugs into and what wires go where along with fuse location. If you don't hav the harness, you can get it from the dealer or the site listed above.
Feb 03, 2010 | 2003 GMC Sierra 2500HD
Installing a trailer plug on 08 f550 need ford wiring diagram
if you go to ford they hve on that just plugs into the stock wiring harness
Sep 13, 2009 | Ford F-250 Cars & Trucks
I am looking for the wire under the rear of my 99 explorer to hook up the wiring harness for trailer or boat. HELP
From the factory there is an unused plug in the left brake light harness. You can get a tow light cable from Ford that's JUST for that, and its a 4 flat plug on the end. I 'found' mine in the compartment on the left where the jack is. Just peek in there with a light. It was still in the package. Otherwise call Ford, the thing plugs in and you route it down and there's a bracket to hold part of it under the bumper to an existing screw location.
-Cheers.
May 09, 2009 | 1999 Ford Explorer
Trailer light hook up problem
It sounds like your have may have your brake light and running lights crossed on your wiring harness to the trailer. Good luck and hope this help's
Apr 08, 2009 | 2004 GMC Envoy
Ford wiring
should be located near the hitch.
Jul 05, 2008 | 2003 Ford F350 Super Duty DRW SuperCab
2008 F250, F350, F450, F550 Wiring Diagrams Logo
134 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
