Question about Remington Garden
How to replace the chain on a remington electric chain saw
3.25 16"/40,6cm I got the old chain off but I can't get the replacement chain back on. it seems too short even though its the right length
    Top Expert:
  • Remington Master
  • 42,804 Answers
Loosen of the cutter bar or remove it altogether
place the chain on the bar ( right way as it will not cut if on backwards) place teh chain over the drive sprocket and refit the bar
use the adjuster to move the bar out until you can pick the chain off the bar about 1/8 of an inch
any looser and it will jump off in operation
Posted on Apr 18, 2015
Trouble starting
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Apr 19, 2014 | Remington Electric Chain Saw
Oil leak on Remington electric chain saw model #111174-01
Use the following IPL as a disassembly/reasembly guide and to determine which oiler part has failed.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/107625-02/107625-01-EL-8-BD.pdf
Once identified attempt to find a replacement here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
Remington is no longer in production. Eventually eBay will be the sole replacement part source.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 22, 2010 | Remington 16" Electric Chain Saw
Chain replacement.
Input "M12510US" in the model number here (if not your saw the procedure should be similar):
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
See pages 7 through 9, for use as a guide.
HTH
Lou
Are you aware RemingtonPower is no longer in production? Replacement parts are becoming difficult to find.
Jan 23, 2010 | Remington Electric Chain Saw
Which chain saw blade do I use to replace the blade
Remington.com
Items 13 and 14 on your IPB
6" Guide Bar $12.98 and 6" Chain $11.97
Remington Power has stopped production and many replacement parts are NLA. I suggest you waste little time ordering these. HTH
Lou
Dec 18, 2009 | Remington 111409 - 01 6" Branch Wizard...
Remington chain saw, electric: jammed and now the
I went here:
Remington.com
  • Typed "M30016US" into the "Model #:" window, then clicked search.
  • Click the M30016US - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown" think you want item 18, 113004-01, Internal Gear
  • Click the 113004-01 - USE REPLACEMENT PART # 122513-01 "View Part" link.
Results follow:
Part #: 122513-01 Price: $24.00
Description: KIT, INTERNAL GEAR (MOD) 747 B/O
If this is what you need I suggest you order it soon.
RemingtonPower has stopped production and replacement pars are almost exhausted. Sooner or later a part you need will be NLA. HTH
Lou
Nov 10, 2009 | Remington M30016US 16" 3.0 Peak Hp Modular...
I have a Remington Electric Chain Saw and have lost the manual. Where can I get one? Model No. M15014US 14'' Bar 114731-01S Chain 114735-01S I have tried searching the Web for one and can't get a...
Remington.com
Enter M15014US (your saw) in the “Search for your unit by Model” window. You can find both an Operator's Manual and IPL. I recommend you download both.
Item 4 lists available bars for your saw, a 14" bar for your saw is pn 114731-01S, $17.85 if available.
Item 5 lists available chains for your saw, a 14" chain for your saw is pn 114735-01S updates to M14SC
, $12.95 if available. You can probably take your chain to a neighborhood chainsaw shop and have a replacement made cheaper.
Remington has ceased production and replacement parts are limited to what is on hand. HTH
Lou
Oct 29, 2009 | Remington Electric Chain Saw
Replacing Remington Electric chain saw blade
Where the bar meets the body of the saw there is an adjustment lug that will either push the bar outward tightening the chain or may be retracted allowing slack in the chain. When backed off (loosened) sufficiently, the chain may be removed for replacement. In order to use this feature, however, there are two bolts that secure the bar to the body that must be loosened prior to any adjustment and tightened bach up after making adjustments to the chain. The above will be enough to remove and replae the chain. If you are taking off the bar (that the chain runs on), you will need to remove the two bolts that were just loosened for the chain adjustment (above).
Regards! --WoobieDog--
Jul 07, 2009 | Remington 16" Electric Chain Saw Assembled...
What kind of chain oil to use for a 10in remington electric
According to the manufacturer... "Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil." So, I suggest for any Remington electric chains saw not to use bar and chain oil. I hope this helps...
Jun 25, 2009 | Remington Electric Pole Saw
Remington 16 in. electric chain saw
Go to www.masterparts.net Remington chain saws are listed by bar length and model number. There is a parts list with each saw.
Oct 27, 2008 | Remington Electric Chain Saw
14 inch electric chain saw throws chain off
If a new chain ::
make and model is important here, as are guide bar length
a particular chainsaw, may be available with 12,14,16,18,20,22,24,26 inch guide bar,
likewise different saws (even from different makers) use the same size of chain
a chain for this saw may be sold in a variety of lengths or
may be sold in the longest length only and require links removed to suit smaller bars.
back to the store, with the saw, for confirmation
If an old chain::
stretched way beyond safety, replace
Sep 27, 2008 | Remington Electric Chain Saw
Garden Logo
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
