Question about Garden
Still working n checking, but no luck. My Saber still won't turnover without a jump. I've changed the silinoid and bypassed all safety switches. (Seat|clutch)
  • 2,899 Answers
Or a new battery...
Posted on Apr 18, 2015
    Top Expert:
  • Garden Master
  • 52,099 Answers
Then I would suggest a new starter .
Posted on Apr 17, 2015
3 Suggested Answers
  • 4134 Answers
SOURCE: I have a 1995 John deer sabre. It won't start unless I jump It. I've changed the silinoid, bypassed the seat safety switch and the clutch. Everything has juice. What's my next step?
You're saying that it will start if you use a booster battery (jump start)? If it starts and runs but then needs a jump again next time you want to use it, then you have either a bad battery or a bad charging system.
Posted on Apr 14, 2015
  • 51198 Answers
SOURCE: I have a 95 John deer Saber. I have an electrician issue. I have a new cellinoid, bypassed the seat safety switch and also the clutch safety switch. It jumps off and runs great. What's my next move?
fix the faulty wiring or switches as they are a part of the safety for the machine
Posted on Apr 15, 2015
My toyota fork lift turnover real good but wont start,checked to see if getting propane from propane bottle to pump ,cracked line and its getting propane but won,t start
check the safety switch under the seat, check for spark , check if it is in neutral, check if the hand brake safety switch is working
check that the gas inverter is operational
Apr 25, 2017 | Toyota Cars & Trucks
Yard king runs but ignition key to starter faulty, need to jump directly to starter
check the safety switch on the brake/clutch pedal bypass it with a paper clip to test it
May 09, 2012 | Garden
2004 chevy tahoe won't turnover or start by being jumped
The ignition start circuit is the path from the ignition key in cranking mode to the solenoid on the starter. The path travels through a starter relay and a neutral safety switch before it reaches the starter.
This must be the circuit not working on your car.Make sure battery and starter connections are tight.Check for power at the starter solenoid terminal with a testlight when someone turns key to crank. If you have power there, they sold you a defective starter. If you have no power there then it could be the relay or the neutral safety switch.
Nov 28, 2011 | 2004 Chevrolet Tahoe
TURN KEY WON'T START BYPASS SELINOID IT
There are a few things it could be. You need to do a check of the coil, safety switches and the ignition switch. You can check the starting solinoid (coil) by jumping from the hot terminal on the main contacts to the terminal that gets its power from the ignition switch (caution, do not go to the ground terminal if it is a four wire solinoid) . If it turns the engine, then you need to check the ignition switch. This is easier with an electrical multimeter. Remember to check the safeties. I have observed that the seat safety switch is the most common electrical component to fail.
I hope this helps.
Sep 02, 2011 | Craftsman Garden
Have a Husky yth180 mower. Battery was going bad and wouldn't start so I jumped it to finish mowing. Replaced battery and still won't turnover. Jumped starter and does turnover. All switches...
hi there dolson894
here is web site for owners manual
http://lawnandgarden.manualsonline.com/manuals/mfg/husqvarna/yth180.html
download owners yth180 manual it has a wiring diagram in it - may help
sounds like a starter solenoid problem, check for good grounding of the negative bat cable and grounding of the solenoid to the frame , check for 12 volt at the solenoid tab ( not the heavy contacts)
this wire solenoid tab wire comes from the S marked terminal from the main switch and power from the battery is taken from the HOT post of the starter solenoid up to the B terminal of the main switch, from there when contact made between B + L + S @ SWITCH voltage sent to solenoid for start
basic connections for switch in start mode is B + L + S
run / light B + L and Makes A + Y
run B + L off G+ M +L
check seat switch and brake switch - bypass with jump wire if need
across white to wjite wires on brake switch
see what hapens , the try a jump wire across the seat switch wires green to green and retry
if stil no good - replace solenoid as you mentioned with a jump cable straight on start motor turns over good
check out website
cheers hope it helps pauly46
dont forget the thumbs rating
Jun 07, 2011 | Husqvarna Garden
I have a 1976 gmc pickup that i can not get to start. I have replaced the ignition switch and the key switch. I had the starter checked and it is okay. There does not appear to be any power to the starter....
you need to check the ign wire to the starter for power. check wire under dash for power and if you have to run a new wire from ign switch to starter selonoid. switch is on top of steering column under dash.
Jan 29, 2011 | Chevrolet 1500 Cars & Trucks
It will not start with key i have to jump across silinoid i have puy in a new starter bat and silinoid
When turn the key to start,check to see if there is voltage to the small wire to the solenoid,if not,check the neutral safety switch,and then,the ignition switch.
May 04, 2010 | 1985 Ford Ranger
Military here and working on a foreign car and not a hummer haha. have a 1998 montero sport. bad starter, replaced and now can arc silinoid to fire starter which would only spark before i replaced but will...
Check the condition of the power and ground cables, Bypass the cables with a set of jumper cables, connect the NEG post to the engine with the black cable, and POS to the Starter Solenoid with the red cable. then try it if it starts the cables are bad or poorly connected.
check the battery voltage in stand by and cranking, try jump starting the truck. if the truck will start with a jump the battery could be bad.
If the starter solenoid is separate from the starter then it is possible the solenoid is bad.
Hope this is of some help.
Ed
May 08, 2009 | 1998 Mitsubishi Montero Sport
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
