Question about Home
How to remove doulton pedigree toilet seat - Home
3 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: Toilet seat connectors mounted on toilet is loose
There should be a way to tighten the bolts without going that far Here's two things:
Look at the lid, with the seat down. The bolts are sometimes covered with a snap-in palstic cap or flap. If so, pry up with a screwdriver. Then use a screwdriver and wrench to tighten.
If the bolts appear to be cast as a part of the hinge assembly, you should be able to reach around the seat to the back side (no pun intended) of the toilet, and tighten with a wrench.
I sometimes use a 'mirror trick' to get a better idea of what's back there. Just use a small mirror and hold it to where you can see the bolt and not on the back.
Hope this gets you going (oops, another unintentional pun).
Best regards, --W/D-- please feel free to rate this solution..thanx!
Posted on Aug 01, 2009
  • 3 Answers
SOURCE: What is the best way to remove stuck toilet anchors
try rotating the entire toilet counter clockwise so the bolts are in the insert slot of the toilet flange and rotate the nut and the bolt head should line up and pop free of flange.
Posted on Oct 31, 2009
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
How do I remove toilet seat?Appears to be 2 bolts with top access only.
rak soft close toilet seat - YouTube
? 0:31
https://www.youtube.com/watch?v=RLssM9BYJjg
Oct 9, 2013 - Uploaded by Paul Hooker
rak soft close toilet seat. ... How to remove and change a Villeroy & Boch toilet seat with top fixings ...
Rak Series 600 Back To Wall Toilet - YouTube
Nov 29, 2015 | Home
How do I remove expansive cap holding screw so I can replace broken toilet seat?
Porcher 70018 Bathroom Toilet Seat Round Front ... - Fixya
www.fixya.com/support/...porcher_70018_bathroom_toilet_seat.../popul...
Popular Porcher 70018 Bathroom Toilet Seat Round Front White questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair tips ...
Aug 25, 2015 | Porcher 70018 Bathroom Toilet Seat Round...
ROYAL DOULTON ANTIQUE PLATES
sorry but we are not in the antique business .
May 21, 2015 | Royal Doulton Carmina Dinnerware...
How to remove a parisi nahm soft close toilet seat
there is 1 of two ways.
easy way is have a look where the seat mounts to the toilet and see if there is a cover that you can lift up and find a screw under it. there might be 2 pins on each side of the toilet seat hinge that you depress for you to remove the seat from the hinges to access the screws.
failing the above method the toilet has to be removed to access the screws / wingnuts from under neath. send closer picture of hinge on seat if you like.
Jul 12, 2014 | Toto Aquia II Dual Flush Toilet
How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Jun 01, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Oct 30, 2009 | Kohler K-3384-2 San Raphael Elongated...
Home Logo
77 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
