Question about Cameras
Says running out of memory have 5g sd card - Cameras
  • 4,198 Answers
There will be some sort of setting to store photos in external memory rather than in internal memory. suggest finding user manual for whatever model number and make it is and looking for this type of setting change
Posted on Apr 18, 2015
Internal memory running out despite internal SD card nearly empty.
You might try reformatting the SD card with a card reader connected to your PC. Also, your tablet has it's own memory limit, if you are saving stuff on the tablet memory instead of the external memory card you might be pushing into the tablet's limits. Get a handle of your memory limits by downloading ES File Explorer if you have an Android tablet to navigate internal and external memory.
Sep 29, 2015 | Tablets & eReaders
Tip
Unlocking SD Memory Card of Nokia 2690
Nokia 2690 is a mobile phone made by Nokia Corporation. Nokia 2690 have 25 MB internal memory, microSD memory card slot with hot swapable. Many user faces problem in unlocking the password of SD memory card. As the SD memory card contains valuable data like songs,images, files, etc. To protect the SD memory card from the unauthorize use, its is protected by secure password or lock code. Some time the password gets forgotten or it gets blocked technically resulting in faliure to unlock the SD memory card. To unlock the SD memory card password you need the utility called FE Explorer. After installing the FE Explorer in the phone, insert the card in to the phone but do not access it. After running the FE Explorer open the path C:system. There is a file called mmcstore. Rename the mmcstore file to mmcstore.txt. Transfer the mmcstore.txt to the pc or laptop and open it in notepad. After opening the file there is a password to unlock the SD memory card of Nokia 2690. Using FE Explorer we can remove the password of other micro SD memory card like Kingston, SanDisk, Verbatim.
Please download the software from the link provided below :
http://fexplorer.en.softonic.com/download/25347
Also visit the help link provided below :
http://www.mobiclue.com/recover-memory-card-password-from.html
on Jun 14, 2011 | SanDisk 2GB microSD Memory Card
Tablet claims to be out of memory but uninstalling apps doesn't free up any space. Even with 32GB SD card is says not enough room for new apps.
Memory in this case doesn't refer to the memory in your SD card, but in the phone or tablet itself. Biggest culprit is photos and music.
Uninstalling apps should free up space. Reboot phone after removing items to record the true memory available.
Sep 22, 2015 | Samsung Galaxy Tab 4G 10-in 32GB WhiteWith...
Says memory full put a new sd card in says thats full too cant move anything to sd card
If you look carefully, what usually occurs is that it is the internal memory that is getting full. It is very hard to fill an SD card unless you have a LOT of pictures and videos saved. Some apps are written to allow them to be moved to and run from the SD card, others allow their data to be stored there, but unfortunately, most still seem to insist that they run exclusively on internal memory. This prohibits the ability to free up internal memory and eventually results in your having to decide which apps are more important than others. Cleaning up the memory by deleting data caches helps, but until the phone manufacturers either increase internal memory or insist that apps writers take advantage of SD cards when available, this problem will continue to haunt us all.
Mar 13, 2015 | Cameras
I have an android LG phone kit kat version, i have files on my sd card and even internal storage that when i click on then to open it says can not find a app that can open file
Please read this site. Just to make clear what you can do with internal memory, SD cards and so on in any Android device.
Be aware the SD card is only an external device to keep your files close to the device. You can't open them and you can't run any app from it.
To open files in the internal memory, toy need to have enough free internal memory to let the app that wants to open the file can run, and some extra space. If the memory is full you need to clear memory, by moving apps or data to the SD card.
How to transfer files and apps from Android phone Android tablet to SD...
Sep 18, 2014 | Cell Phones
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
How to unlock micro sd memory card, when i forgot my password
Recover an SD Card Password b> Secure Digital (or SD) memory cards are one of the most popular forms of digital media storage. When using SD cards with a mobile device, you can set a password to protect unauthorized users from viewing the files. However, sometimes, you may lose the SD card password. If you have access to the mobile device, recovering the password is a simple process. If the mobile device is not present, the only way to recover the password is to reformat the device.
Download and install a file explorer application, such as FExplorer, X-plore or Best Fileman onto the mobile device. http://download.cnet.com/f-explorer/3000-2094_4-75758737.html Run the application on the mobile device. Select the "Find" option. Type "MMCSTORE" in the space provided. Connect the mobile device to the computer via either a Bluetooth connection or the connection cable that came with the mobile device. Send the "MMCSTORE" file to the computer. Rename the "MMCSTORE" file "MMCSTORE.txt" on the computer. Open the "MMCSTORE.txt" file on the computer. Write down the password located in the "MMCSTORE.txt" file. b> Using a PC b> Download and install the SD Formatter program from the SD Association website. http://www.sdcard.org/consumers/formatter/ Insert the SD card into the computer's SD card reader. Run the SD Formatter application. Select the SD card from the drop-down menu and click the "Format" button. Formatting the SD card will reset the password. However, the process also will remove any data that is stored on the card. Allow several minutes for the SD card to format. Hope this helps.
Sep 14, 2011 | Kingston 2GB Secure Digital Memory Card
My cam has a virus and i want to delete it
HERE'S THE ANSWER TO YOUR PROBLEM:
Your camera cannot get any virus. Your SD card / memory card might. Here are possible solutions to your problem:
1. Run malwarebytes antispyware on your SD Card / memory card.
2. Run AVG or Nod32 to eliminate any virus on your card.
3. Or, consider reformatting your memory card. Go to Menu - Settings - Memory.
NOTE: If you want to reformat your memory card, make sure that you have back up files or copy of the files inside your memory card.
Your problem is solved! Thanks.
Jul 13, 2011 | Sony Cyber-shot DSC-W180 Digital Camera
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
