Question about Craftsman Garden
My craftsman t1600 lawn tractor won't engage the blades it worked good when i parked it in the fall
    Sergeant:
  • Craftsman Expert
  • 187 Answers
"I have an Electric Clutch and my Blades will not engage when I operate the PTO switch."
  • Turn the engine off and remove the key.
  • Check for physical damage; anything look bent?
  • Is the deck belt intact?
  • Spin the pulley on the bottom of the clutch. Does it spin freely?
  • There could be mud or grit stuck in the clutch.
  • There is a drive key between the clutch and the shaft. Has this key been sheared?
  • When you pull the PTO switch does the clutch make a "click"?
When you sit in the seat and turn the key, one click from off to run, you will hear a faint click. That faint click is the fuel shut off valve under the carburetor. It is turning on and off when you cycle the key from off to run. Do not confuse this click with the clutch click.
Leave the Key in the Run position, cycle your PTO Switch on and off. You will hear a click. This click will be twice as loud as the fuel switch click. This louder click is the Clutch engaging. If you do not hear this click, the PTO switch may be bad or the Clutch may be bad. This is assuming your battery is good and fully charged and that your Key Switch is functioning correctly.
PTO Clutch will Not engage or stay engaged.
There is a very fine discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
  • It does not give the air gap.
It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
Posted on Apr 18, 2015
  • Craftsman Master
  • 16,194 Answers
Check the safety switch on the seat.
Craftsman zero turn runs but blades won't engage.
if got elect. pto/ and clutch,could have a wire connector come loose
Oct 21, 2012 | Craftsman Garden
Craftsman 20hp lawn tractor blades won't engage
check to make sure your cable is in tact its called a pto clutch cable about 20 buck on ebay it may be broke inside
Sep 26, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman lawn tractor parking brake won't engage
are you holding the lever while lifting your foot of the pedal?
Jun 27, 2012 | Garden
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
My craftsman 18.0 42" lawn
First check to make sure you can turn each blade by hand, with the mower off. If neither blade spindle is frozen remove the deck and make sure all the pulleys move freely and function like they should. The cable should have been operating a spring loaded pulley arm that applied tension to the deck belt to make the blades function. Some times build up with block that from moving or rust will make it stick.
May 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lawn Tractor dies when cluch/blades are engaged and ...
The way you describe your problem, all of it could be caused just by the seat cushion pressure switch. It is possible to by-pass this by putting a jumper across the terminals, but it is there as a safety feature, preventing you from falling out of the seat and under the blades, or in case of a rollover, it automatically kills the engine. If you by-pass this, it is at your own risk, but i did the same thing on mine. Hope this helps :)
Jun 12, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
May 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
210 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
