Question about PANDIGITAL Tablets & eReaders
Says my sd card is unmounted or no files are on it. what happened to my files?
    Novelist:
  • 174 Answers
When you remove an SD card from its slot, you should *unmount* it first so you don't lose data. If you just pull it
out without first unmounting it, you could corrupt it and lose
data. This might have happened in your case or not. If you didn't remove it, try this.
Go to Settings>Storage>External SD, touch Unmount.
Then remove your SD card and using a Q-Tip and some
solvent like alcohol clean the copper contacts. Then slide it
back into the slot. The device should *Mount* it automatically.
If it still doesn't work, you could try hooking your device up to a computer via its USB cable and see if your computer can see any files on it. If it can't see any then somehow they could have gotten erased. Try loading them back. If they won't load and you get error messages, the SD card itself may have gone Kaput.
Posted on Apr 18, 2015
2 Suggested Answers
  • 6702 Answers
SOURCE: How do set the trio stealth to use an external SD card
I show you one of the many links about using an SD card on an Android tablet or phone:
How to install Android apps to your SD card by default fixedByVonnie
Posted on Jan 11, 2015
How can I kept my files on the sd card
The files are probably saved to a virtual image of the SD card. In order to actually get them written to the card, you would have to tell the operating system to unmount, eject or otherwise remove the SD card before physically removing it. Usually a restart or shutdown will do the same thing. The operating system will then write the image to the SD card, and if it is not doing a restart or shutdown, may tell you it is safe to remove the card.
This is done to increase the lifetime of the card. Every time you write to it, it wears out a little. Consequently, the system waits until you are done working with the file before doing the writing so it doesn't waste writes on stuff that will be edited right away.
May 01, 2016 | Samsung 10.1 Galaxy Tab 4 16GB White
All of a sudden my dragon touch has lost all of the apps were on my sd card what can i do
Go to Settings>Storage>External SD and look for the *unmount* option. Touch *unmount*. This will electroncally close the SD Card connection so it can be safely removed from the slot. Then remove it from the slot. Then clean the brass contacts with a little piece of toilet paper. Then slide the SD card back into the slot.
The device should automatically *mount* the card. If it doesn't and there is a mount option shown then touch *mount*. If it still doesn't work then chances are your SD card went bad. They do that sometimes.
Jun 23, 2015 | Dragon Touch Tablets & eReaders
How do l mount a sd card on my zeki tablet TBDG734B
Mounting is done automatically by the device in most
Android tablets.
For an Android, all you have to do is insert the SD card in the slot and it will be mounted automatically. If you want to remove the card, though, you need to *unmount* it. You can unmount in Settings>Storage>External SD card and will see the unmount option listed below it. Touch it and then you can remove your SD card without the possibility of corrupting the files.
Apr 17, 2015 | Tablets & eReaders
I inerted a 32gb SD card and nothing happened so I popped it out anthem I could not get it to pop ck in tablet said new SD card???
When you insert an SD card in the slot the tablet will *mount* it automatically. This means it connects to it and formats it and adds some files and folders so it can utilize it.
Before you remove it you need to go to Settings>Storage>External SD and touch the *unmount* option.
If you don't do this there is a chance the card can be corrupted and can become unusable. If the tablet said new SD card then you might have to go into Settings>Storage>External SD and touch the *Mount* option.
If it's a new SD card chances are you didn't hurt it. But if it's a use one on which you had a lot of data stored and you didn't unmount it before removing it you could have damaged the file structure and your only option to get it back would be to put it into a card reader on a laptop or desktop and reformat it.
Apr 14, 2015 | Dragon Touch Touch R10 10.1 Google Android...
Jan 11, 2015 | Tablets & eReaders
How do I add an sd card to my prontotec axius?
Hi
Insert the SD card into the SD card slot on side of Tablet the correct way round. Taking note of the angled side of the card in relation to the diagram on the Tablet case. Start Tablet, go to settings, storage, scroll down to SD card & mount the card. Once the card is mounted it's ready to use. Remember to unmount the card before removal to reduce the risk of data loss. Hope this helps. Regards Bob
Jul 27, 2014 | ProntoTec ntoTec 7 Inch Android Tablet Pc,...
I have a proscan PLT7223g tablet and trying to download app from goolge play store and I'm getting error code 911 What is this and how do I fix it
You can avoid these errors if you have a stable internet connection. If the internet disconnects in the middle of the download then the error might occur. You can also try going to settings, applications and locate the google play store and tap it . On the play store tap clear cache. One of the reasons that the error occurs is if the download manager was moved to the sd card. Make sure also to check that. You can unmount the SD card and try.
Jan 16, 2014 | Tablets & eReaders
Sd card corruption
You may have fried the bios on the SD cart! If so you can't retrieve it!
Jan 01, 2013 | Coby Kyros 7" Touchscreen Tablet
What does code 912 mean? i get this when downloading apps from apps store
There are a few reasons why you would get a 912 error when downloading apps.
  • Downloading apps directly to an SD card
  • Play Store (app store) needs to be updated
  • Bad cache
The following methods could help solve the problem
Clear Cache and Reboot
  • Go to Setting >> Go to Application Setting (In some devices application setting is named as apps).
  • Go to, All the apps > >Find the Google Play Store >> Clear Data and Cache
  • Once you have clear everything, Next you need to Force Stop the application
  • Also, try to clear Cache and data of Download Manager and Google Service Framework.
  • Now, Restart your device and try to download the app.
Unmount SD Card
  • Go to Setting >> Storage >> Scroll down and select "Unmount SD card"
  • Open Google Play Store >> Download the app again that was giving you the error message
  • After successful installation, Go back to Settings >> Storage >> tap on "mount SD card"
  • If above steps didn't work, also try removing your SD card before installing.
Move app to phone
  • Go to Settings >> Go to Apps >> Select, All the apps
  • Scroll down and select the app that was giving you the error during update
  • Select "Move to phone"
  • Open Google Play Store and update the app
  • After successful installation, you can move the app back to SD card
Feb 01, 2018 | Tablets & eReaders
Tablets & eReaders Logo
53 people viewed this question
Top PANDIGITAL Tablets & eReaders Experts
Colin Stickland
Colin Stickland
castletech
castletech
Are you a PANDIGITAL Tablet and eReader Expert? Answer questions, earn points and help others
