Question about Dryers
What else should I check if the receiver and remote are OK?
    Genius:
  • 1,617 Answers
Make sure you set the fan on high with the pull chain, if it has one. Also, if you have an on/off switch on the wall, make sure it's on. What make/model of fan do you have?
Posted on Apr 18, 2015
Remote not working
It could be many reason for remote is not working ,check the battery with replacing it with fresh new one , check the antenna for remote receiver and then check the connectors to remote receiver control unit under driver sit for loos connection ,if all seems ok you might replace unit
Feb 23, 2015 | 1996 Toyota Camry
Remote will not operate integra receiver
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 08, 2014 | Audio Players & Recorders
Humax code for one for all remote
0382,0381,0724 are the codes to check. For more codes check this.
May 22, 2013 | One For All Televison & Video
My DTC 6200 converter/decoder was working fine. A few weeks ago I have disconnected it, pull the power cord out of the AC outlet, put the decoder in a safe place. Then when I finish painting, I hook...
Hello
Check out these with your Motorola converter
[1] Verify that the AC power cord is connected to the DCT*
and an AC outlet.
[2] If the DCT* is connected to a switched outlet on another
unit, verify that that unit is powered on.
[3] Press the POWER button on the DCT* front panel instead
of the remote control. The batteries in the remote control
may be depleted
[4] The DCT* may have received a software update and
may not power on while the new software is being
installed. Try again in a few minutes.
OK.
Oct 21, 2011 | Arris DCT6200 DTV Receiver
I have SR 307 onkyo A/V receiver home theatre system. the remote control has stopped working. i checked with a local dealer and that the remote is okay and something has wrong in the receiver,
Did you check the remote with another Onkyo system at the dealer ??. If its OK try resetting the system. Remember you will loose all your stored presets ( FM and customized settings ) and the Amp will go back to factory settings.
While in standby mode hold down the DVD button and press the Standby/On button., the display will show Clear and the Receiver will go into standby mode. Turn it on and try the remote once again.
Jun 01, 2011 | Onkyo TX-SR307 A/V Receiver
My GPX DV1020 remote will not turn on the dvd player. Can you help?
be sure your remote is ok. check the remote as follow:
-use a pocket radio that is set/tuned on AM-frequentie band.
-hold the remote near the receiver of the radio while pressing every botton one by one
-you should hear a high pitch sound if the remote is ok
-when all botton do the high pitch that means the dvd IR-receiver is bad. usually it can't be, those are tough....
if you dont got the pitch the remote is bad. test especially the power botton of the remote.
If it is the remote please write back. I will show you how to do some simple actions to get the remote back going..
succes
Aug 29, 2010 | Televison & Video
Remote stopped working with the receiver. I changed the batteries and still there is no control. Remote is Yamaha RAV280. Thank you for your help.
do this quick test to make sure remote is working OK , take a digital camera and point it at the eye or the remote , while looking thru the screen of digital camera press any button at the remote, if it blinks , remote is working ok . let me know AJ
Nov 11, 2009 | Yamaha RX-V463 Receiver
No power
Crystal for system micro should be in front panel display and near the lcd display .while your there check solder connections in display board
Aug 05, 2009 | Yamaha RX-V420 Receiver
Sherwood rv 6030r does not turn on.
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If the remote is OK, then the problem with the Remote Sensor or related components of the receiver.
Dec 25, 2008 | Sherwood R-945 Receiver
Unable to select function (vcr-1, dvd, tv etc) from remote
i think u have loose parts in ur remote...if you know how to solder check for loose parts ok...
rate me fixed ok
Jan 01, 2008 | Denon AVR-3806 Receiver
Dryers Logo
41 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
