Question about Irons
My iron seems to iron like a dry iron unless I press the steam boost. Is this how to operate this iron? I can't find the on/off steam switch on the iron either, please advise.
    Top Expert:
  • Irons Master
  • 50,211 Answers
Sad to say since you did not include make /model we can not look for solution . try google.com and make/ model/ manual
Posted on Apr 17, 2015
Philips 8300 steam generator iron keeps cutting out
I have this iron about 2,5 years, work a few times. when i shut down the steam generator the iron stays on. And now in one hour of work it shuts downs about 4 times. the lights on the steam generator are week. what main board i shuld switch?
Mar 21, 2013 | Irons
I have a swan steam generator iron .s14030n .i have read manual and the steam only works if i keep pressing pump .should the steam come through all the time .when switched to steam .i have done the pu
MINE IS LIKE THAT. PRESS FOR STEAM WHICH CONTINUES FOR A SHORT WHILE. BUT IT IS A PAIN AND TGHERE IS NO WAY I HAVE FOUND ROUNBD IT EXCEPT A SPRAY BOTTLE WITH WATER!
Jan 28, 2013 | Irons
No steam coming out of iron russell hobbs precision heat digit model14773
i know mine won't steam either unless you have the dial set to steam. not sure if your has the same set up but i thought it might help to offer the information
Jul 16, 2012 | Irons
Water leaking out of iron no steam I have a Hamilton Beach Steam Storm Model 14560 Lost manuel
The Use and Care Guide for the Hamilton Beach Iron can be downloaded here:
http://useandcares.hamiltonbeach.com/files/840091300.pdf
If water is leaking out of the iron:
• Do not overfill the water tank.
• If steam ironing, is Adjustable Steam Knob in a steam position that matches Temperature Control Dial steam range? Did the iron have enough time to preheat?
• If dry ironing, make sure the Adjustable Steam Knob is in the DRY IRON position.
Jun 20, 2011 | Hamilton Beach Steam Storm 14560 Iron
It is spitting and am not getting much steam
Probably needs decalcifying. If the iron has a steam boost button then fill it with water, turn it on and wait for it to heat up, hold it over the kitchen sink and repeatedly press the steam boost button. this may clear any blockages.
If that does not work then you can purchase a cleaning solution from a hardware store that is used to decalcify the iron. You fill the tank with the solution and let it pass through the iron to remove calcium deposits. Instructions will be provided with the solution.
Feb 07, 2011 | Rowenta Irons
Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
Jun 24, 2009 | Euro-Pro Shark GI490 Iron
Solenoids workin, steam lines fine, but no steam
take hose off from iron end,press iron button ,breifly! keep tight hold of hose [best to put towel around hose while holding]see if steam comes out.if not hose could be blocked, then take hose from solenoid end and press button .if no steam comes out the solenoid is either faulty or the valve hole inside is blocked,turn off power and take nut off top of solenoid ,check spring and plunger for condition.the small hole may be blocked in the solenoid housing,try a needle in the hole to clear any blockage.
Jun 24, 2009 | Irons
Brown water drips
This may be down to contaminants in your water supply, or any "ironing water" you may be using.
There will be a build up inside the hotplate where the water is vapourised.
To clear this, refer to your manual or simply put on high steam setting, rest on it's heel, and wait for the indicator light to go out, then unplug, and hold horizontal over the sink. Press any steam boost buttons you have untill the iron is cold - and you just get water flowing out.
The best and cheapest water to use I've found - is the condensate from condensing tumble dryers. Which most people just tip away! It is condensed steam - so contains no minerals to fur up irons. If you don't have one - ask a neighbour for a few gallons.
Jun 29, 2008 | Euro-Pro Shark GI490 Iron
My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Nov 08, 2006 | Tefal Ultraglide 1549 Iron
Irons Logo
141 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
