Question about Ricoh Office Equipment & Supplies
Please i have Ricoh MP 1500platen cover and 1600. ADF DF 2000 i installed the ADF of mp1600 on the 1500 and its not working,it works fine on 1600. Any setting on sp mode for this to work.
It recognize the ADF but wen you insert a paper on the ADF it will initialize but does not make the pop sound to show it has recognize paper. any settings pls
2 Suggested Answers
EmmettPinger
  • 63 Answers
SOURCE: Ricoh Aficio MP 2000 ADF (auto document feeder) is not working
tape is on the underside of the ADF causing a sensor to not tell the machine that the ADF is in the lowered position. look under where the hinge area goodluck
Posted on May 01, 2009
Hello sir i have a question adf is not working
So my first question is: Have you shut the machine down, unplugged it from the wall, waited 30 minutes then, plug the machine back in, turn it on and listen for the ADF solenoids to cycle indicating it has calibrated and is functional?
I know it sound like the old "ctrl-alt-del" used on pc's only more involved. Please try this and let me know the results.
Oct 19, 2015 | Ricoh Aficio Mp 2000 Copy Machine
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP1600
I do find the error code for a different Ricoh model (Aficio 1018).
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%201018
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
Hello, Our Ricoh Aficio 2000 is saying to remove paper from the ADF but as far as i can see there is no Paper. Tried switching it on and off again but to no avail. Any suggestions?
Hello!
Swithing off and on do not solve your problem.
Make sure that you do not have any sort of paper in the ADF.
If you are sure that you do not have any paper, you probably have a faulty paper sensor.
Not the best help i know...
Jun 24, 2011 | Ricoh Aficio MP 2000 Black and White...
We have a network ricoh aficio mp 1600 pcl printer we recently upgraded to windows 7 printer and copier are working ok but scanner is not working is there a problem with the scanner driver for windows 7
please go to www.ricoh.com and instal the scanner drivers of windows-7 other wise you can instal the scan to folder which dos not required any drivers or you can install scan to mail this also does not required any drivers - thanks
Mar 10, 2011 | Ricoh Aficio MP 1600L Black and White...
My copier ricoh aficio mp 2000 makes a continuous creaking like an broken or consumed gear. what's the problem?
MP2000s often have creaking and squeaking issues. Typically it's the brass bushings that ride on roller shafts, so if you can isolate it to an area and clean and lube the bushings, you might be able to fix the noise.
Aug 12, 2010 | Ricoh Aficio MP 2000 Black and White...
Jams when duplexing on ricoh mp161
if you are talking the origanal in the DF check for staples or ppr clips inside the DF, or if it is jaming the copies try fresh ppr clean the rollers.
Apr 08, 2010 | Ricoh Aficio MP 161SPF Color Copier
Error c620
SC620 B Communication error between BICU and ADF The BICU does not receive a response from the ADF main board for 4 seconds or more. The BICU receives a break signal from the ADF main board. • Poor connection between the BICU and ADF main board (DF connector) • ADF main board defective • BICU defective
Apr 07, 2010 | Ricoh Aficio 2020D Copier
Close ADF cover 4732 on a Ricoh IS330DC. How do I fix this.
I'm not familiar with this model, but if it says to close df cover, then either the cover is not closing all the way, a plastic piece on the inside of the cover that actuates the switch or sensor is broken or the switch itself is out of position, dirty or broken. Good luck Colin
Jun 28, 2009 | Ricoh Aficio 1013F Copier
Apr 22, 2009 | Ricoh Office Equipment & Supplies
43 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
