Question about Dymo LabelWriter 450 Turbo USB Label 1752265 Thermal Printer
Ghin program unable to open dymo. system error 5
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
This sounds like Microsoft issue. However you can try several things to try to solve it.
1. Please make sure that you have full admin rights on the PC, especially to the AppData folder, which is located C/:Users /User name/ AppData/
You need to grant accesses also to the folder Local, where all Dymo related files are stored.
2. You can try to re-install the Dymo Label Software by using the LWSupport uninstall tool, located in: C:\Programs\DYMO\DYMO Label Software\Support. Just double-click it to start the driver removing. Please note that before that, you need to close all running programs.
After that please delete also the Dymo folder under C:/Programs
Then navigate to C/:Users /User name/ AppData/ Local/ and delete Dymo and Sanford folders.
After you do that, you can uninstall the application from Control Panel/ Uninstall Programs.
Restart your PC and download the newest version of Dymo Label Software by clicking on the following link:
http://dymo.li/dls851win
Please make sure, that the device is unplugged during the installation.
I hope this will solve the issue. If not please contact us directly :
http://global.dymo.com/Default.aspx?locale=n
Kind regards,
Silviya T.,
DymoSupport
Posted on Apr 22, 2015
I can't connect to ghin.com
Check your connection
Aug 17, 2013 | ghin.com
DYMO LabelWriter 400 Turbo Installed but gives error message when sending prints
First of all, on Dymos you need to use original Dymo roll,.
Dymo rolls have a tag at the back, non original ones does not have it.
Before reinstalling driver you also need to run the dymo uninstaller utility that you find at Dymo website.
I will post the links for download.
Oct 03, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Paper "30252 address" is not supported
Here is the fix for Win7 provided by Dymo tech support:
1. goto Devices and Printers
2. select Dymo Label Writer
3. On the top where you see Print Server Properties, open it and find "30252 address"
4. delete "30252"
5. delete Dymo Label Writer printer
6. disconnect USB cable and then power to Dymo printer
7. connect power and then USB cable back to Dymo printer
8. reboot PC
9. try printing label again.
Jan 31, 2013 | Dymo LabelWriter Thermal Printer
Unable to install Dymo 400 on a Window 7 computer
Dymo is not compatible with win 7 so try to find out the correct version to install it
thanks
May 18, 2010 | Computers & Internet
Printing error print system exception error
I had this problem with the LabelWriter 450 Turbo and it was a .Net Framework problem.
1. Uninstall the Dymo Label software
2. Click this link to download .Net Framework 4.0 http://www.microsoft.com/downloads/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
3. Reinstall latest version of your Dymo Label software (w/o printer connected to PC)
4. Reconnect label printer when prompted by installer
This should fix the problem
Dec 24, 2009 | Dymo LabelWriter Thermal Printer
Can not install DYMO LabelWriter Software
Sounds like vista to be honest. Either way i think you need to just give that special permissions to access folder. Try that and restart your computer.
Jul 10, 2009 | Dymo LabelWriter 400 Thermal Printer
This is the error message when openning the Dymo Software on Server 2008. We have openned this same softare successfully on other 2008 Severs. Exception EPrinter in module Labels.DLL at 0000643E6
http://global.dymo.com/enGB/Troubleshooting/LabelWriter_320.html
From this site.
    • The error message: "Exception Eprinter in module LABELS.DLL at ...." is displayed.
      or
      The error message: "Access violation at address ... in module DYMOLBL.EXE" is displayedA. This problem can occur when DLS 7.x was installed over DLS 6.x, without first uninstalling DLS 6.x.
      Solution:
      Delete the file Dymolbl.ENG.
      DLS will still work, however, all default settings will be incorrect.
      The settings will need to be set correctly.
      On the DLS menubar, click Preferences and set the preferences as desired.
      The default values are:
      Default label file folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Label Files"
      Default address book folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Address Books"
      Default clipart folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Clipart"
      B. An incorrect printer has been selected in the DYMO software.
      Solution:
      1. Start the DYMO Software.
      2. Click on File and point to Change printer.
      3. Click the LabelWriter model connected to the PC (e.g. Dymo Turbo)
      C. Occasionally, double-clicking the print command button in the list manager is not handled properly by the software.
      Solution:
      Single-click the print command button.
      D. An incorrect driver has been installed.
      Solution:
      Run the DYMO Driver Uninstaller
      Restart the PC and install the correct driver.
      To remove and reinstall the printer driver:
      1. On the Windows taskbar, click Start, point to Settings and click Printers (& Faxes).
      The printers window is displayed.
      2. Double-click the LabelWriter icon and delete any documents waiting to be printed.
      3. Close all programs.
      4. On the Windows taskbar, right-click on Start and click Explore.
      Windows Explorer is started.
      5. Double-click the file C:/Program Files/DYMO Label/Support Files/LW Remove.exe
      6. Unplug the LabelWriter's USB connection from the back of pc and click OK.
      7. Choose Select all and then remove.
      Once the driver has disappeared from the printers dialog box, click Close.
      Restart the PC.
      8. When Windows has restarted, on the Windows taskbar, click Start, point to Programs, point to DYMO Label and click Uninstall DYMO Label.
      9. Reconnect the LabelWriter to the computer and reinstall both driver and software.
Jun 16, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Dymo lextra tag xr
I was able to find the following error codes, however I realize they are for the Lextra tag QX50. I was unable to find codes for the Xr, so I e-mailed Dymo and will post a comment on this as soon as they get back to me.
For now, here are the QX50 codes, just in case they help:
LetraTag QX50 Error Codes trnsp.gif Question An error is dispalyed on screen when I attempt to print a label with my LetraTag QX50. How can I resolve this?
trnsp.gif Answer Error
Solution
Error 1
(Tape jammed or low battery)
  • Replace the cassette
  • Replace batteries
Error 2
(Big Font cannot be selected with characters in memory)
  • Select another font size
  • Select Big Font before entering text
Error 3
(Big Font cannot be selected with: box, underline, 2 line, or lower case)
  • Select another style format
Error 4
(Memory buffer is full)
  • Delete some of the entered text
Error 5
(Text is bigger than defined length)
  • Specify a longer tape length
Error 6
(2 line cannot be selected with the format)
May 04, 2008 | Dymo LetraTAG Thermal Label Printer
DYMO DUO LABELWRITER
The labels have a 2 yr warranty, so contact Dymo customer support and if they can't help you return the printer to the retailer you purchased from for a new printer. The Dymo LabelWriter DUO is an expensive printer that Dymo stands behind.
Feb 16, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo LabelWriter 450 Turbo USB Label 1752265 Thermal Printer Logo
126 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
