Question about Ariens Garden
I have a ariens z 2048 when I engage the pto, it works but won't handle an even moderate load. Has new belt and blades would a bad battery cause this?
    Top Expert:
  • Ariens Master
  • 44,351 Answers
Weak battery will cause deck to cut off for sure the electric clutch uses too much juice for the alternators
Posted on Apr 17, 2015
  • Ariens Master
  • 1,169 Answers
If your engine is running properly then battery has effect on the PTO.
It is more likely that your engine is running on one cylinder and that the extra load of deck is just too much for it.
  • 95 Answers
SOURCE: Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Posted on Jul 31, 2009
  • 1111 Answers
SOURCE: G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Posted on Aug 07, 2009
  • 138 Answers
SOURCE: When I engage the PTO, the blades don't egage.
The first thing we need to to do is verify that there is adequate /(power 12 vdc) going to the electric clutch, you can do this by unplugging the clutch and check both wires 1 should have 12 volts and the other wire shoud read infinity to ground if this checks out replace the clutch, if you dont have 12vdc to the wire replace the relay
Posted on Sep 07, 2009
  • 16 Answers
SOURCE: Cub cadet lt 1050 electric pto want engage??????????
make shure pig tail is hooked right
Posted on Oct 17, 2009
  • 18 Answers
SOURCE: PTO loads engine down and almost quits running!
pto is going bad
Posted on Jun 06, 2010
Ariens ZTR 1540 zero turn riding mower trembles real bad and chokes out when PTO is engaged
look at blades for bent or damage--check pulleys ,belts and mandrels ,bearings for binding or loose bolts
Aug 11, 2016 | Ariens Garden
Ariens model 915111. Blades will not engage. Using a light voltage device. I placed the probe inside the socket which was connected to the pto clutch and it lit up. Can you tell me what part needs
If your receiving power at the PTO clutch and it is the correct voltage ie. 12vdc then you will need a new PTO clutch assembly.
Oct 28, 2014 | Garden
Why will the blades not engage on my 2009cubcadet 1040
PTO switch maybe bad or fuses blown. Or possible a safety switch is bad. If none of those the PTO clutch is bad.
Sep 06, 2014 | Cub Cadet LTX1040 Deck Belt 2009 Only...
PTO cable: Ariens 960160021
Sounds like you are missing a return spring. Your PTO if it's mechanical engage has a tension spring to bring it back when disengaged.
Apr 09, 2014 | Ariens Garden
Mower starts and runs beautifully until i try and engage the cutting blade.It smokes badly... doesn't seem the belt is moving. its practically new, just purchased it in July 2013 and only used it three...
Something is jammed under the deck. If the engine runs good until you engage PTO, the problem is in the deck. With engine off, disconnect belt for deck from PTO, then remove deck and flip it over. With belt off try to spin blade. They should spin freely. If not, you have a bad bearing which are fairly simple to replace, just a few bolts. FYI, draw a diagram or take a picture of belt routing before removal, this will be good to refer to for installation of belt when your done. Hope this helps.
Sep 06, 2013 | Ariens Garden
Husqvarna riding mower
Jim, I believe your tractor has an electronic knob for engagement (if I'm right in you having a matching post about a husqvarna with a knob for engagement. And it also has a PTO clutch off the motor. Having a little slack in the belt is not bad if it's not so much that it doesn't grab at at all. Does anything happen at all when you pull the switch? If nothing happens at all, the switch could be bad, the PTO clutch could need adjustment or be bad, OR you may simply have a very weak battery that isn't supplying enough current to engage the PTO properly under loads. Sometimes the batteries and charging units in riding mowers are very borderline in being able to handle the loads and a weak battery can cause unsuspected problems.
Aug 10, 2013 | Garden
Pto stopped working on areins tractor.
It sounds like your switch is working. Other issues might be a belt that jumped it's track and isn't tight when the tensioner tightens up, or a belt that has stretched beyond working limits, or a bad PTO clutch. You could also have a bad spot in the wire that heads to the pto clutch.
Oct 25, 2012 | Ariens Garden
Blades fail to engage (using pto) after tractor has been running for awhile.
bad wiring to the charging system or the alternator is bad
May 03, 2012 | Garden
Arien 34- Blades won't engage
This mower has an electric PTO on it. I had a Scag and the electric PTO clutch went out on it. Not the cheapest things to change but easy to do yourself with some basic tools. Also, before running out and getting a new one, check the wires to it and to the engage/disengage switch. You may have a bad connection.
Oct 12, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
98 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
