Question about wrangler unlimited 4 door 2007-2010 with subwoofer canvasback cargo liner
New fan will not work. checked fuses and installed new relay
  • Brock Saint Aoro
    Brock Saint Aoro May 02, 2015
    Hi wallace d stewart, which fan? If it is your main coolant fan, change your coolant temp sensor
2006 Chevy Trailblazer low beam headlamps will not work. Here's a list of what I have done. Changed both low beam headlamp bulbs Swapped cooling fan relay and HDM relay -headlamps worked but cooling fan...
Hi Ryan, check the fuse to the low beam, if your not getting power to the relay it will never work, the fact that you have 3 new relays they can't all be duff
Aug 30, 2014 | Cars & Trucks
93 Camry 4-cylinder
check the 25 amp fuse that had fan rad on it . Check the fuses under the dash. Finally replace the fan switch in the head as it may not be communicating with the CPU to put power through the fan relay
Dec 23, 2013 | Toyota Camry Cars & Trucks
I had the radiator to my saturn replaced bacause it was cracked. Now when the engine is turned on, the fan works, then stops. Can someone help?
you will need to change your relay most likely in your fuse box ,,put some glasses on to see the fuse diagram to find your relay ...change it ,,,it is wearing out and causing your fan to kick off and on
Oct 22, 2013 | Cars & Trucks
My beetle 2001 radiator fan no working and aircond also come out without cool air, engin overheating problem. i send to workshop and check wiring and fuse all in good condition. please give advise what...
Because there is no supply to the fan , it is not working. So you need to check the fan with a direct link to test , is working check the RELAY box for the fan relay, next check on the thermistor, the control circuit of the temperature controller to trigger the fan relay. Also check on the fuse to the relay unit.
The AC cooling must be checked only after this circuit is working as a hot engine will not give a good result. cehck the gas pressure, check the pumping pressure to confirm the compressor.
Also the eveporator, condenser, pressure switch must be checked independantly.
Aug 08, 2011 | 2001 Volkswagen Beetle
Cooling fans on aztek no coming on, ran hot wire to fans and works. checked fuses, jumped wires at temp. sensor and fans ran after shutting ignition off for aprox. 30 seconds, replaced temp. sensor and...
there are 4 steps to check and you've mentioned all but one the relay which cuts the fan on'off. At an elec shop you check in this order power to fuse block, fuse & output side, temp sensor, relay, and fan motors. Get a new relay
Apr 28, 2011 | Pontiac Aztek Cars & Trucks
My fan is not working on my 1989 ford escort iv put a new fan on and a new radiator fan switch but still not coming on
There should be a relay--probably in the engine compartment relay box or along the firewall. Try swapping the fan relay with a similar relay, such as the horn relay and see if the fan will come on. You can also check the wiring from the relay socket. Please see my tip at http://www.fixya.com/cars/r6022358-relay_check . If you get stuck, please get back to me.
Nov 19, 2010 | 1995 Ford Escort
2000 impala, heater fan intermittent. When fan is not working also have no cruise or rear defrost.
Could be a relay switch, check the fuse area and look for a larger square looking fuse or have it checked but get used one at wrecking yard,,real cheep there. Relays are fairly expensive new. About $20 bucks each. I've bought some at wreckers for just a few dollars. Easy to install, like a fuse.
Hope this helps.
Dec 11, 2009 | 2000 Chevrolet Impala
My fan also has quit the assembly is new so i
Use a known working relay of the same type and turn on your a/c on high, then put in the relay where the old high speed fan relay was. If it comes on, it's the relay. Try this on low speed as well. If they don't come on when the A/C is on, it could be your pcm/ecu as well. If it doesn't communicate with the sensor, it won't turn on. Check with A/C running to narrow it down. If they work here, look into the engine coolant temperature sensor.
Jul 17, 2009 | 1999 Chrysler 300M
wrangler unlimited 4 door 2007-2010 with subwoofer canvasback cargo liner Logo
18 people viewed this question
Top Jeep Vehicle Parts & Accessories Experts
CrisO
Thomas Perkins
Thomas Perkins
Andrew Gaitan
Level 1 Expert
Are you a Jeep Vehicle Part and Accessory Expert? Answer questions, earn points and help others
