Question about Bosch Dishwashers
How do i take front cover off of Bosch SMU4052UC 1998
Has control knob on left & push buttons on right. i have cover off on bottom but is still attached on top
Bob Gemmell
  • 209 Answers
SOURCE: Need to remove top cover of GE WPXQ3090T2WW top load washer
There should be 2 screws holding it on at the rear. Looking from the rear these will be at each top corner. Once these are removed push the lid from the front of the machine towards the rear and it will pop off.
Posted on Sep 13, 2007
  • 1314 Answers
SOURCE: timer runs down to 1 min and just hums water covers the bottom
need more info on problem does it start washing then run down and hum or what
Posted on Dec 30, 2007
SOURCE: Can't reset the time on digital watch
I found the solution at http://www.watchliquidators.com/fossildir/Nike.asp
Hold down the button at the top left (the light) for about 4 seconds. The second part of the time will start blinking. I tried this before, I'm sure, but I must not have noticed the blinking and thought nothing was happening.
Once the seconds numbers are blinking, push the top right button (Start/Stop) to move to the hour or minute. Push the bottom right button (Lap/Reset) to change the time. When you're done, push the top left button (Light) again.
Posted on May 20, 2008
SOURCE: ps3 controller
my ps3 controller wont connet with the ps3
Posted on Jan 03, 2009
SOURCE: trailer brake controller problem
I found the problem. Talking with a technician from the controller company, we determined that it was a fuse problem. I found that the fuse to the CHMSL was blown.
Posted on Jun 30, 2009
I have a Bosch washing manchine nexxt 300 series, when i push the on button it will not come on
Check door switch. If OK then your probably looking at a motor control board problem. Ck connections on it. It is located in the back right corner of the machine.To get to it take the back off and it will be on the bottom left.
Mar 04, 2013 | Bosch Nexxt 300 Series WFMC2201UC
How do I remove door seal from wfmc3200uc/01
Bosch wfmc3200 uc/01 Front load washer how to change door seal.
This video will show you how to change a door seal on this Bosch front loader washing machine.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 17, 2012 | Bosch Washing Machines
How do I fix the clock
Push the main control knob (right side of the unit) either up or down, until the Kenwood's display screen shows "Clk Adj." Press the center of the control knob for about a second to enter the clock-setting mode.
  • 2 Push the main control knob either up or down to set the Kenwood's hour display. Stop when the correct hour shows on the screen.
  • 3 Push the main control knob to either the right or left to adjust the minute display. Stop when the correct hour shows on the screen.
  • 4 Press the "Menu" button located in the bottom-left corner to save the changes you made to the clock. This returns you to the main menu
  • Oct 19, 2011 | Kenwood Car Audio & Video
    How do you set the clock on the Kenwood DPX302
    In the standby mode:
    1. Push the Control knob towards up or down, select "CLK ADJ"
    2. Press the Control knob for about 1 second, the clock display blinks
    3. Push the Control knob towards up or down to set the hour
    Push the Control knob towards right or left to adjust the minutes,
    4. Press the Menu button
    Mar 01, 2011 | Kenwood DPX302 CD Player
    Where is the reset switch on the Bosch 3510 dryer
    The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame:
    The motor tripped?.
    To reset the switch unplug the dryer, remove the power cable and back cover completely. two screws holding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover . On the front of the motor you should see two white wires going into the safety switch for the belt breaking. Push the button on the left to reset the switch (you probably will hear a click) Do not push the right button as that is what got tripped originally . Good Luck Tim
    Nov 28, 2010 | Bosch Axxis WTA 3510 Electric Dryer
    B.m.w. geneve 250 watch what are the four small dials for how to operate them denis
    If it's the same watch I have, the four dials from right to left are day of week, hours left in the day, date 1-31, and possibly a chronograph (mine makes 2 revolutions/minute). On the case, there are three large knobs on the right and two small flush screw-like objects on left. The large knobs (top to bottom) are month selection, time set, and day of week select. Month and day can be selected by pushing the knob to the desired date. On the left, you will need a fine pen or stylus to press the center. Top to bottom, these two buttons control year and date selection.
    Nov 23, 2010 | Bulova Watch
    DVD stuck and wont open
    Which product u use? Each product has that option in order to solve such issues. Is it an old one? There are several places where the hole is. One is near the eject button (upper left, right, bottom right). Near the tray (below or above). Bottom left. Near the volume control. If there is a sticker or something it must have behind that. You can get it in a different way also. Remove the bolts using a screw driver. There are 2 plastic blocks (located left and right near to the front plastic panel.). Push in those small pieces in and pull the plastic fron shield slightly. Then use a flat screw driver to remove the two upper locks (where the plastic panel or shield connected to the metal cover - on the upper edge). Slightly push front and then bottom until you see the disk. Then use a soft hook or something to pull the dvd out. Then Push up until the upper locks fit together with the metal shield. Push the plastic cover in until the side locks are fit together with the metal cover.
    May 31, 2010 | Computers & Internet
    My bosh has been having problems such as when I do 2-3 loads of clothes there will be water still in the bottom. So I have to run a spin cycle to get it out. Or it will eat my clothes my bedding by...
    could be as simple as cleaning the screen trap on pump "the factory doesnt like the consumer doing this'and does not provide instructions in owners manual. you will need towels to sop the excess water if you open the filter knob/handle. also you can shut the water off and do several spin/or drain cycles to get rid of most of what water is left in tub before begining as a lot of water in tub can cause several gallons of water to spill on floor ! this is the reason the factorty dosent want you to mess with it! unplug washer then take a small nail and insert in "hole"of round cover and push in just a little 1/4 inch and turn cover located at bottom right side of machine "front side of machine " you will see filter knob turn it to the left "counterclockw"
    clean it and replace and snug it up. eror E:04 says bad control board but that machine must be able to do the very basic operations such as unkinked drain hose,clean filter /good water pump,corect amount of soap ect.. to work right or you may get sporadic operation error codes that are not true!
    unplug it and start over!
    Apr 27, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
    Bosch dishwasher model SMU4052UC/14, Won't fill
    you need to check the water solenoid valve. if you follow the water line coming into the dishwasher you will find the valve(first spot in the water line with two wires coming from it) if you pull the wires off you should see 110 v when it is trying to fill with water if you do then test the valve for continuity.
    May 06, 2009 | Bosch 36 Inch Pyramid Chimney Hood - Black
    Help on ajusting the speakers
    If you have the factory stereo, push in the power button with the stereo on, and then turn it to adjust the balance between left and right. Then you can return it to the normal position. Then PULL out the same knob and when you turn it you will adjust the "fade" between front and rear speakers.
    Mar 27, 2009 | 1991 Volvo 740
    Dishwashers Logo
    63 people viewed this question
    Top Bosch Dishwashers Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
