Question about Frigidaire Washing Machines
How do you remove the agitator on a Frigidaire washing machine model number FTW3014KW0
    Genius:
  • Frigidaire Master
  • 1,585 Answers
Dose the top part pull off or screw off
Posted on Apr 17, 2015
  • Anonymous Apr 17, 2015
    Not sure I can't get it to pop up. if I spin it clockwise it just spins.if I turn it counter clock wise it pops
  • tom cassidy
    tom cassidy Apr 18, 2015
    push and hold down firmly and turn at same time
aborcass
  • 2651 Answers
SOURCE: How do I remove Kitchenaid Washing machine agitator?
with the palm orhte heel of yuor hand smack the top of agitaor, hte fabric softener cup will release.it doenst seperate to clen any furthetr though reccommnd soaking in hot water to clean out. reach down and pull up the opaque cover from the center of agitatr and there you will fond a 7/16 bolt holding the agitator to the tranny shaft. remove bolt adn PULL up
Posted on Mar 12, 2008
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
  • 33 Answers
SOURCE: Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Posted on Dec 17, 2008
MNTECH
  • 1543 Answers
SOURCE: GE model number wdsr2080daww, machine will not
You should be able to just grab the agitator and hank it straight up and off. Sometimes you might have to slip a belt or rope under the agitator and fasten the rope to a 2x4 or similar and then hank up on the board. Remove the plastic part under where the agitator was (one 1/2 inch head bolt) . If it does not come off, break it off with a chisel. If the metal spline shaft under that turns freely by hand, you have a bad transmission. If it does not turn by hand, just install a new WH49X10042 air bell (agitator drive) and replace the agitator.
Posted on Mar 08, 2009
SOURCE: How to increase the water level of Front loading washing machine
I have used extra weight inside the tub. I have used bottle of water and also a plastic 2 or 5 pound weight.
Posted on May 05, 2010
Remove frigidaire agitator
I appreciate your inquiry, friend!
Based off the information you have provided you need to remove the agitator inside of your Frigidaire washer. Could you please provide me with your model number? I may be able to find additional information once I have that number. You should be able to locate the serial tag on the door frame of the washer. Once I have that information I would be happy to assist you. -Matt
Feb 22, 2015 | Frigidaire Washing Machines
Rusted agitator mounting bolt in frigidaire washing machine
Pour some oil on it, engine oil or AT oil will do, kitchen oil too but, becareful of colors so after you done with the cleaning, wipe the excess. Remember, since the bolts are rusted they require extra strenght hence get a tool that completely covers the bolt or else you will grind the corners of the bolt.
Hope this helps
Nov 28, 2013 | Frigidaire Washing Machines
How to remove agitator from Frigidaire washer - grime coming out from under agitator.
that most likely is coming from the tub seals and not dirt under the agitator,the tub seals are made from black rubber and metal.send the model number off of the washer or go to this site and look up your machine and it will have a breakdown on the agitator and you can see how to get it out.
http://www.searspartsdirect.com/partsdirect/index.action
Apr 07, 2013 | Frigidaire Washing Machines
How do I remove the agitator off the shaft of a Frigidaire top toading washer?
http://www.youtube.com/watch?v=n2mIiVNd_yk
If yours doesn't look like the one in the vid above give me the full model number from the machine.
Jan 27, 2013 | Frigidaire Washing Machines
How is the agitator removed for cleaning collected lint?
Hi, W/D here.
Remove the dispenser cup. Remove the cap below it. Then remove the bolt and washer. The agitator will lift out. Here's a link to a parts list and diagram that you can follow to help you:
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-Parts/Model-FWSB5700DS0/1428/0153200/R0402083/00002?blt=06&prst=&shdMod=
Best regards, --W/D-- Please feel free to rate this solution. Thanks.
Feb 18, 2011 | Frigidaire FWSB5700DS Top Load Washer
Need to remove washer agitator
Hi, Remove the rinse dispenser from the agitator and look inside it. See if there is a bolt holding the agitator in. I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Washing Machines
It eats my clothes
I would remove the agitator, checking to see whether the bolt that holds it to the drive shaft is securely tightened. If it is tight I would then check the agitator for a serial number, usually molded directly into the plastic agitator on the inside bottom. Use the internet to determine if the part is the correct agitator for your specific model of machine. I have seen the wrong agitator installed on machines before and it can do a number on clothes, especially sweaters.
Dec 14, 2007 | Frigidaire FWS833A Top Load Washer
Removing the agitator
Pull the top of the agitator off...there is a nut inside of it (ratchet and socket usually 5/8 and a long extension) pull agitator out.
Nov 18, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Washing Machines Logo
75 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
