Question about Euro-Pro Toaster Ovens
Who can I contact about mt toaster over heating
    Sergeant:
  • 290 Answers
Euro-Pro, of course. Toaster ovens are hot by nature. Never put anything on top of any. It may also just be in adequately insulated which is more likely on a cheaper model. For older appliances like toster overns and CRT TV (now even some LCD ones as people switch to LED) Goodwill is great source for quality items for dirt cheap. They are often more reliable then newer Chinese built junk. Personally, I always return any PC item made in China. Japan, Thailand, Singapore, Malaysia, even Korea (where most BBQ equipment is made except Weber and some VERY small brands as well as Hyundai and other large equipment). Even Samsung is Korean but uses part from all of Asia just like Toyota / Infinity / Acura / Honda. all make MUCH better equipment then Chinese junk. I'd much rather have something even made in Mexico then China these days. 95% of what they do does not last.
Posted on Apr 17, 2015
My black & decker tro964 is not heating
That may sound like a stupid question, but is it plugged in?
Have you tried to plug in the toaster on a different power outlet?
If there is a ground fault switch where the toaster is plugged in (that's those outlets which have 2 buttons on the front, one labeld "Test" the other usually labeled "Reset") unplug the toaster and push the "Reset" button and try the toaster again. To test, if the power outlet, were the toaster is usually plugged in, is working, try a hair dryer or any other device on that outlet.
Its most likely cheaper to replace the whole toaster than to replace the heating elements, for about 40 $ since that's the price of your toaster on some websites.
Jan 06, 2014 | Black & Decker TRO964 Toaster Oven
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
When I plug in my Oster 6248 toaster oven, it flashes error
This is caused by a bad contact on the heat sensor located on the top inside the oven...now if i could juste find the replacement part...
Mar 14, 2010 | Oster Toaster Ovens
Toaster does not work!!!
I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Toaster oven just stopped working...
With mine, the toaster function stopped working. The light lit, but the relay did not click. This happened about a year ago, but then it started working again. Now that my waranty expired, it seems permanent.
The relay requires 12V, but I only measure 5V (no audible click). When I pulled the relay, the drive went up to 12V, so the coil is loading down the source. Not sure whether the problem is the coil or the source. It would be nice to find a schematic. When I put the relay across a car battery, I heard the click indicating that the relay is working.
I cleaned the contacts, and get the same result.
Jul 22, 2007 | Cuisinart TOB-30 Toaster Oven with...
Toaster Ovens Logo
314 people viewed this question
Top Euro-Pro Toaster Ovens Experts
Dave
Dave
eyecam
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
