Question about Air Tools & Compressors
Will not shot
Full battery full fuilpull the trigger will not fire
    Top Expert:
  • 46,460 Answers
Check to see it the plunger is sticking out if so push it up a little with a flat screw driver then try many times we do not hold them down tight to what we nail and this happens often
Posted on Apr 17, 2015
On webley 928. Breaking gun ( empty) open the extractors work fine. But following shooting and then breaking open the left extractor never works.
The barrel selector sounds like it is not engaging correctly to the switch over of trigger to firing pin for the second shot if you don't get it repaired it may get worse and go off when unexpected
Jan 29, 2017 | Air Tools & Compressors
Why is my ant 3x14 nightvision scope switching of by itself after every shot thats been fired. I have to switch it on after every shot thats been fired
The recoil is triggering the switch off. Either the on/off button is over sensitive or the battery gets momentarily disconnected. Check the battery terminals. It might also be part of the circuit rubbing on the scope casing and shorting it.
Jul 03, 2016 | Winchester Optics
Gun fires 2 or 3 naiks everytime I pull trigger
Most nailers have two types of triggers available. One is a bump fire and the second is single shot that is activated by releasing the trigger, placing the contact foot against the work, then depress trigger. Bump fire trigger May fire two nails if you place then depress. Check your parts manual to determine which trigger is installed. (Some brands have built-in switch to activate bump) good luck
Jul 13, 2015 | Air Tools & Compressors
Trigger problem on my Yugoslavian SKS rifle. when the bolt and carrier are locked in the firing position it pushes down the pin on the trigger group and the hammer will not fire. If you pull the bolt...
I'm having trouble visualizing which pin (firing pin???) you're talking about. How sure are you that the rifle has been reassembled correctly? Could you post a picture so we can see how it's assembled? One shot (no pun) of the assembled trigger group would be good, then another shot of the bolt & carrier.
Aug 07, 2014 | Optics
Www.dewalt.com
Worn trigger valve orings will cause gun to fire twice, and /or attempting to single fire nail with bump-fire trigger. Easy test, look closely at firing pin under trigger. It should fit snuggly an not move from side to side in valve. If loose, replace valve. If your nailer has bump-fire trigger, do no attempt to place gun then fire one shot because the gun will most likely double fire. Good luck.
Oct 09, 2012 | Porter Cable Coil Roofing Nailer
NR90AE Nails jammed how to remove
New user will jam the gun/ nails because gun was most likely not bump fired. Placing the gun then depressing trigger will usually cause double fire in the hands of new user. New user should practice on scrap lumber bump firing at many angles till they get the idea; or give them a training period with a nailer that has a single shot trigger (they may develop bad habits with single shot however).
Nov 14, 2011 | Hitachi NR90AE Full Round Head Framing...
Squeeze trigger once and it fires 3x
if there is a 9 volt battery in the handle, there should be 3 to 5 small dip switchesright by the battery, your set on 3 shot burst, unhook the gas, turn all switches off, and test it, there is also a full auto setting, try different combinations untill you get single shot
Sep 15, 2010 | Tippmann 98 Custom Act Paintball Gun
I just bought a new tippmann 98 custom act platinum edition and it doesnt seem to be firing right. i upgrades the rear bolt and trigger and after a few shots the bolt lock in the firing position. if i pull...
I would look in to the bolt and check that it moves freely, also check that is properly lubed, and finally that your upgrade bolt does not need a different spring. I would also check the batteries on the grip if it is an E-trigger.
Mar 18, 2010 | Tippmann 98 Custom Act Paintball Gun
Air Tools & Compressors Logo
217 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
