Question about Air Tools & Compressors
I'm looking for the size of the paint booth 83-2448
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: looking for asembly instructions for a mid 80s semi down draft devilbis booth
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Posted on Mar 29, 2012
How much paint would it take to cover a thick coat on a 1984 ford f150
29.1. How much paint does it take to fully paint a car? It depends on the size of the vehicle, and the type of paint used. There are formulas for sq. ft. coverage, but in my experience are not always reliable. Let's take a 92 Cutlass Ciera for example, which would be a fairly common size. In a base coat /clear coat (BC/CC) application, I would mix 2 quarts of base coat, (perhaps one quart with an HVLP) which thinned to spraying consistency would give me a gallon of sprayable material, and should provide adequate coverage. However, some are more transparent than others, and additional or less material may be required. Paint booth lighting is essential to ensure proper coverage. After applying the base coat, I would mix two quarts of clear, which reduced would give me three quarts of sprayable material (two coats at approx 1 1/2 quarts per coat). An additional third coat could be applied if desired, but be sure to watch for excessive film build which can lead to dulling or solvent popping problems. If you don't have access to a paint mixing system, then buy more than you need. There is no way to fix a paint job that does not have adequate coverage except for repainting the entire car.
and this site might also help you.
http://www.learnautobodyandpaint.com/your-questions-answered/
Jan 22, 2016 | Ford Cars & Trucks
Do I really need a spray booth?
Many professional artists believe that a spray booth isn't a necessity in case you got an airbrush.
Feb 03, 2013 | Crafts & Hobbies
Is it important to clean the seamless spray booth after each use?
It is important to keep your booth clean after each use. This is why seamless booths are so special; they cut down on the difficult cleaning that comes with booths that aren't seamless.
Why do seamless spray booths have no seams?
A seamless booth has no seams which makes clean up easier. It is important to keep your booth clean after each use.
What is a seamless spray booth?
A seamless spray booth is a booth that artists who spray glaze or anything else that may be toxic use to help cut down on over-spray of the chemicals used.
Looking for asembly instructions for a mid 80s semi down draft devilbis booth
Jan 07, 2012 | Cars & Trucks
I want to short my picture size, example: from 202KB to less that 50KB. please help me out.
The easiest way is to reduce it's size by using Paint. Here is what to do:
- Open the picture you want to be in smaller size on Paint
- Look for the Image tab on paint and choose Resize and Skew. If you can't find it just press Ctrl+W.
- Be sure the box "Maintain aspect ratio" is checked. Then adjust the size you want for your picture and then click "save as" and choose a different name, so if you think it is too small or if ever you need your original file, it will still be there.
Hope this helped you! =)
May 18, 2011 | Computers & Internet
How to re-paint scaped and scuffed car bumpers and fenders
In my experience, it's good to get paint that is matched to the original manufacturer's color from a place like NAPA auto parts.
Ask about the 'flex' agent as well, as many bumpers are made of plastic which will need it for a satisfactory result.
Then, get an air brush or detail paint gun and an air compressor (small) that can power it.
Sand the affected area with coarse down to fine sandpaper until relatively smooth.
Spray grey or red primer on the masked off area.
Fill the canister with paint and spray the scuffed and scraped bumpers or fenders.
You can paint small areas outside or in a large dust free garage, or preferably in a paint booth that has down draft ventilation.
Wear proper apparel for painting when you do this.
New paint can fill many cracks on several coats.
Oct 07, 2010 | 2004 Toyota RAV4
The bumpers on my 95 Honda del Sol are moderately oxidized. I've tried everything from armor all to testing a patch with compound. Nothing brings the original paint back for long. Is there a more permanent...
Repainting is definitely the best solution, but a laminar-flow spray booth is the only way to get a great-looking finish, and they're expensive enough that only pros buy them. :(
Failing that, have you tried spraying on a "clear coat" of enamel after using whatever compound does the best temporary job? Auto-parts stores usually carry clear coat in spray cans, and that can extend the life of whatever original paint you have left...
Jul 14, 2009 | Honda del Sol Cars & Trucks
Air Tools & Compressors Logo
154 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
