Question about Garden
How to get brake drum off left side need to replace seal
    Top Expert:
  • Garden Master
  • 44,232 Answers
Sorry but we need make model and possible year to find this info . most lawn mowers do not have drum brakes tho
Posted on Apr 17, 2015
Left side brake will not release
new piston seal possibly not seated correctly and has rolled out of position not allowing piston to return to place once pressure is released.. remove and examine and check condition of seal.
Jan 12, 2016 | Cars & Trucks
87 toyota clutch wont engage after brakes were replaced
Brake and clutch are vacumme assisted and hard to start seems like vac hose left of of has leak
Nov 14, 2012 | Toyota Cars & Trucks
Bad rear wheel bearings
You do not say which side, but I can just about guarantee that it is the LEFT Rear thats bad. I've done 2 different EGGS w/ this problem. Seal goes out, leaks into the drum, wipes out brakes... bearing. I repeat, on both vans, only Left side was bad. I still have both vans w/ over 200k on ea. & have never had to do the right side bearing/seal on either.
!. buy a new wheel Bering & a new seal fir the left side. From the same auto parts store (ck 1st to see which one will allow this, then buy u'r parts from them) borrow a wheel puller / slap-hammer. 2. Jack-up left rear, & set this side of axle on stable jack stand. Leave other 3 wheels on ground, chock all 3 securely. 3. remove wheel, drum, brake shoes... etc. 4. Attach wheel puller to lug studs as instructed (just ask someone or get directions) You are going to be slamming the sliding weight back on the shaft to the hilt, repeatedly, until the other end of the axle pops out of the 3rd member. At that point remove the hammer, remove the shaft. leave van as is. 5. this is when U take the shaft & new bearing to a auto machine shop/parts house/repair shop/friend's place..... whatever... w/ the proper PRESS to remove the old bearing & instal the new. cost me $25 for this where I went. 6. Back @ the van, replace the b-Seal. try not to screw it up. use wood block (pice of 2x4 worked for me) lite coat of grease on o/s of seal heaps instal. Once seal is "tapped" into place, insert the axle w/ new bearing all the way until it seats into place. May require a firm stab to seat properly, do not hammer it at this point. 7. Replace brake shoes (if using new shoes, replace right side shoes also, just do ONE side @ a time so u have a guide in case u get mixed up reinstalling the shoes)
Worked 2 times for me..... or pay a Mechanic to do for U. This is Not that hard a Shade-tree fix. Luck :) gettocar
Jul 14, 2011 | 1992 Toyota Previa
Brake fluid leaking from left front caliper.what could be the cause?
The cause of leaking hydraulic fluids could be the caliper itself. For over years your using it dirt and dust might have accumulated in the seal and broke it.
Check also your brake pads it might be already worn and the caliper drum have moved to maximum and fluids came out.
There is a seal kit you could buy and replace the seal inside the caliper that is holding the caliper drum( a metal circular drum that pushes your brake pads when you brake ).
Pull down the caliper, remove the brake hose, using a high pressure a air would push out the caliper drum and you could see the rubber seal inside.
Hope that helps you out.
Thanks for using FixYa!
Jul 07, 2011 | 2003 Yamaha FJR 1300
After aplying E-brake, Left rear wheel is locked up?
The parking brake cable is not releasing, usually due to corrosion within the cable jacket or inside the drum if it has drum rear brakes. Put the rear end up on jack stands and have a helper push and release the parking brake and watch what the cable is doing on both sides. You should be able to see the hang up. If it is inside the brake drum you may want to try a bit of WD40 applied to the cable where it enters the backing plate. Do not go overboard with it as it will collect inside on the drum's braking surface.
Aug 11, 2010 | 2002 Dodge Neon
Left rear axle leaking - Dealer states $820 to fix due to many parts within the axle. Does this sound right?
fix same problem myself...these's' only 1 inner seal (differential output seal only-about 10$ each) that needs to be replace and new brake shoes (20$ part)..assumed u have rear drums and it leaked diff fluid on the brake shoes..but, i also replaced the brake cylinder (15$ part)-u have to disconnect brake cylinder to remove axle..look on internet for procedures..http://www.yotatech.com/f128/replacing-rear-axle-seals-3rd-gen-4runner-76339/..hope this helps..all dealers are ripoffs-worked at toyota for a year
Jul 31, 2010 | 1999 Toyota 4Runner
Rear brake drum leaking on my 1989 ford bronco 2 y did it happen and how do u fix it
The drum isn't leaking, either the wheel cylinder is leaking or the line is leaking
Oct 07, 2009 | 1989 Ford Bronco II
Left rear brake drum was smoking and i changed the shoes now they are leaking fluids . there was now fluid leaks before and i didnt break any lines open , any sugestions
you will need to replace the wheel cylinders. always replace both sides and the shoes will need to be replaced also on both sides due to brake fluid contamination. make sure you have the drums resurfaced also!! hope this helps you!
Sep 10, 2009 | 1995 Dodge Intrepid
1993 Ford F-150 drum brake problem
It appears the rear axle shaft seal is leaking. You will need to pull the axle and replace the seal. Then check the rear end for adequate gear oil. The iron filings I am not to sure about. It sounds as if something came loose from the brakes or brake hardware and got chewed up in the drum. You will need to replace the brake shoes and maybe the brake hardware kit. Always change the shoes or pads on both sides when working on brakes, rear or front. If the inside of the drum is not perfectly smooth it will need to be turned or replaced. If this were brake fluid leaking from the wheel cylinder the master cylinder would be low on fluid and your brake pedal would go down much further than normal.
Jul 18, 2009 | 1998 Ford F150 Regular Cab
Brake shoe positioning on -88 K2500
Short shoe goes towards front. Also: check for any contamination on shoes or hardware from either axle seal or wheel cyls. Any contamination will make vehicle pull when brake applied. Technically, if contaminated shoes need replacement but if not heavy, on new shoes I usually just give a light sanding on friction material and the remainder will usually burn off.
Feb 12, 2009 | 1988 Chevrolet K2500
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
