After removal from fan, where do I insert the wires? In the numbered "pin holes" on top, or in the slots on the sides?
    Top Expert:
  • Computers & ... Master
  • 41,433 Answers
The instructions tell you what goes where at least they did when I was building pc's
Posted on Apr 17, 2015
How to change door opening to other side
Hi Eleanor,
Without a specific model number I can only give general information, but, Kenmore fridges are all about the same, so here we go. Take a close look at your unit. You should observe several small plugs inserted on the side of the doors that don't have the hinges currently mounted. These inserts cover threaded holes that are used to mount the hardware for the hinges. If your fridge has two doors one above the other. remove the top hinge hardware, lift the door up off of the bottom hinge pin. then remove the bottom hardware on the top door. Typically the mounting screws are either phillips head or 1/4" hex head machine screws. You should now see that there is now a threaded hole in the same position on that side as the plug in caps on the other side. remove the caps from the one side and insert them in their respective holes on the other side. the door hinges will attach to the now exposed holes on the side that the plugs were removed from. But not yet. First remove the top hinge hardware on the bottom door, lift the bottom door off of the bottom hinge, and then remove the bottom door hardware relocating the bottom hardware to the other side. Install the bottom door onto the hinge pin of the bottom door hinge. Close the door then install the top hinge on the bottom door. Next install the bottom hinge and hardware for the top door, set the top door on the installed hinge, close the door add install the top door top hinge and hardware next. Same with the door handles. All of this info applies to the doors and the fridge itself.
Jun 26, 2015 | Kenmore Refrigerators
Attach bagger to john deere d140
While standing at back of mower with the bagger hood in your hands. The black support arm is hanging down, positioned at the back of the mower. At the bottom of the black support arm are two tangs with a gap between them (gap is 2"-3"). The tangs will be inserted into two slots on the towing frame. That is the black panel of the back of the mower. They will not be centered; rather they will be offset to the right side of the tow frame, about mid way up the back.
Lower the hood support so the tangs are horizontal, or parallel to the ground. Once parallel to the ground they will slide into the slots. After they are in the slots, while holding the black support arm steady, raise the two swing arms up to the seat. After raising the swing arms (light brassy color, V shaped connecting rods) then raise the black support arm with the tangs held in the slots. As you raise the black support arm vertically the swing rods will move forward, over the top of the fender, and align with two retaining holes.When the hood is level with the top of the seat you will be able to insert the ends of the swing arms into the holes in the fenders. This will complete installation of the support for the bagging hood. Now follow the locking instructions below.
Note: prior to starting this procedure you may have to remove a spring clip and locking pin (about 6" long and 1/4" round) that runs through the black support arm. It runs right to left through two holes in the support arm, the spring clip locks it in. This pin may be supplied uninstalled. The function of the 6" locking pin is to keep the swing arm in the fender holes after you have everything in place. It must be removed to perform the above installation. After the installation is complete insert the lock pin, right to left, pointy end goes in first, above the swing arms where they meet the black support arm, then insert the locking spring clip in the tiny hole of the locking pin. This locks the swing arms in place.
Oct 12, 2014 | John Deere Garden
How to check fuel filter on 2008 ultra classic
If you need the instructions for removal of the top plate to get to the point of the following instructions post another request as it would be too long to add in here now.
Fuel Filter replacement instructions:
After you have removed the fuel tank top plate and find the ground wire spade terminal in the slot of the fuel filter shell. Then insert the tip of a small flat blade screwdriver through the window to depress a tang, and then pull the terminal from the slot and then gently raise the locking arm and pull the U-clip from the holes in the fuel filter shell and remove the fuel filter shell from the end cap and then also remove the o-ring and filter from the fuel filter shell. To reinstall a new filter in the fuel filter shell seat a new o-ring on the counterbore at the top of the filter and then install the fuel filter shell over the end cap, so that the slot in the fuel filter shell engages the index pin on the end cap and then. Holding the parts together, slide the U-clip through the holes on the locking arm side of the fuel filter shell and push the U-clip until its ends exit the holes on the opposite side and then retract U-clip until contact is made with the step in the locking arm. When that is done route the ground wire from top plate TORX screw around the index pin side of the end cap and install the spade terminal into the slot in the fuel filter shell and gently tug on the ground wire to verify that the terminal is locked in place. If the ground terminal does not lock in place properly use a thin flat blade,(like that on a hobby knife), to bend the tang outward slightly away from the terminal body. Then reinstall the top plate.
Jun 19, 2014 | 2008 Harley Davidson FLHT Electra Glide...
Where are the shipping blocks located
Instructions
    • 1 Locate the four hole plugs at the back of the washer. Pry the plugs out of the holes with a slotted screwdriver.
    • 2 Wrap the drain hose around left side of the back of the washer. Place two P-clamps around the hose near the bottom and top left-side holes.
    • 3 Insert a spacer into each of the holes located at the back of the washer. At the bottom and top left-side holes, guide the spacer through the holes in the P-clamps.
    • 4 Insert the bolts through the holes in the middle of the spacers. Use a socket wrench to tighten the bolts.
Read more: http://www.ehow.com/how_12007506_install-shipping-pins-frigidaire-affinity.html#ixzz2yOxdRTxN
Apr 08, 2014 | Frigidaire Washing Machines
I got from a customer VGC-RC310G, dont't bootup. alarm "abnormal cpu fan", on bios cpu rpm = 0 , but fan is running. One strange thing, cpu fan had 4 wires but is connected to a 3 pins plugs on...
Got from customer? Meaning what?
Nothing strange about a 4 wire CPU fan cable.
One wire is for a Positive connection. One wire is for a Negative connection.
One wire is for a sensor that reads the RPM's. The last wire is to regulate the fan speed.
3 wire connector has one Positive wire, one Negative wire, and one wire to read the fan speed.
Manufacturers of fans can put the wires in their connector in any order they wish.
Therefore the 4 wire fan's connections may not match up to the 3 pin connection on the motherboard.
Move the wires around after testing the pins on the mobo, (MOtherBOard), with a multimeter.
Use a needle to depress the lock tab for the metal terminal in the connector, so you can remove the wire.
To explain:
The wires go down into Socket holes of that fan's plastic connector.
The wires go down into the BACK of the plastic connector.
The wires end in a metal terminal. It is a type of Molex rounded female terminal.
A Molex Female Crimp Terminal Connector.
http://www.alibaba.com/product-gs/336134982/molex_female_crimp_terminal_connector.html
Left-click on the image in the rectangle. (Has powin.en.alibaba.com across the image)
Takes you to another page showing the metal terminal again. This time you can enlarge the image.
Click on the Zoom In icon at the top ( + )
Looking at the image, a wire comes in the Left side. The U shaped tangs you see are then crimped over the wire. The right side has the receptacle end for the pins on the motherboard. This end is in the Front of the fan's connector.
Come to the left partway on that round barrel shape, and view the tang that sticks out.
There is also one on the opposite side.
These tangs lock the female metal terminal in the plastic connector.
A needle is used on the Front of the connector, and is inserted up into one side of the socket hole.
Inserted up into one of the sides where a tang is.
Inserting the needle depresses the tang.
(You may also have to view the tang as best as you are able, and ensure that it is depressed. {Magnifying glass}
The needle is then inserted into the other side where the other tang is present.
This tang is depressed, then the wire, and metal terminal can be extracted out of the Back of the plastic connector.
Gently bend the tangs back out using the needle. Then after you have removed the wires, (With the metal terminals on their ends), you reinsert the wires into the plastic connector's socket holes, in the order you wish.
Don't use the sensor wire that regulates the fan speed for the 4 wire fan connector.
Use the Positive, Negative, and fan RPM wire.
Nov 01, 2010 | Sony VAIO® VGC-RC310G PC Desktop
IPhone 3GS how insert simcard
Hello, with your iPhone you get a small metal key tool that inserts into the top of your iphone. Look at the iPhone screen to you then turn it to look at the top. Next to the headphone insert, just to the right of it is a hatch with a small hole on its left hand side. Insert said key tool and pull. Insert sim into slot then return. If you cant find the key try a pin, safety pin or paperclip.
Hope this helps
Jim
Feb 09, 2010 | Apple iPhone Smartphone
Change low beam headlight
Open the hood.
If you need to change the headlight bulb on the driver’s side, remove the air intake cover (see below.)
Remove the electrical connector from the bulb by pulling the connector straight back.
Remove the rubber weather seal by pulling on the tab.
Unclip the end of the hold-down wire from its slot. Pivot it out of the way and remove the bulb.
Insert the new bulb into the hole, making sure the tabs are in their slots. Pivot the hold-down wire back in place and clip the end into the slot.
Install the rubber seal over the back of the headlight assembly. Make sure it is right side up; it is marked TOP.
Push the electrical connector onto the new bulb.
Turn on the headlights to test the new bulb.
(Driver’s side) Reinstall the air intake cover.
If you are working on the driver’s side: Remove the two pins holding the air intake cover by pulling the head on each pin (careful, I think these are the kind of heads that do not come all the way out, but only far enough so the pin can be removed) . Remove the air intake cover.
Hope this helps you.
Jan 08, 2010 | 2002 Honda Odyssey
I need to replace the bulb on the front headlamp, on a97 Honda oddesy
1. Open the hood. If you need to change a bulb on the passenger's side, remove the air intake cover (the air cleaner housing is on the passenger's side of the engine compartment. Remove the two pins holding the air intake cover by pulling the head on each pin, then remove the air intake cover).
2. Remove the electrical connector from the bulb by squeezing the connector on both sides to unlock the tab. Pull the connector straight off.
3. Remove the rubber weather seal by pulling on the tab.
4. Unclip the end of the hold-down wire from its slot. Pivot it out of the way and remove the bulb.
5. Insert the new bulb into the hole, making sure the tabs are in their slots. Pivot the hold-down wire back in place and clip the end into the slot.
6. Install the rubber seal over the back of the headlight assembly. Make sure it is right side up; it is marked "TOP".
7. Push the electrical connector onto the tabs of the new bulb. Make sure it locks in place. Turn on the headlights to test the new bulb.
8. (Passenger's side) Reinstall the air intake cover.
Nov 03, 2009 | 1996 Honda Odyssey
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
It is not cooling at the top
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question please let me know.
thanks,
Mar 24, 2009 | Bosch Refrigerators
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
